Implausible Time Records
Old May 6th 19, 05:04 PM posted to rec.aviation.soaring
Tim Newport-Peace[_6_]
Default Implausible Time Records
Not necessarily related, but I noticed that your Firmware is dated
10-Feb-2017. I feel sure that there have been updates since then.
At 15:08 06 May 2019, Dan Marotta wrote:
Yes, the GPS jamming usually centers around Alamogordo and ranges out to
about 400 nm.ツ* Moriarty is well within that area.ツ* I've asked other
local pilots and they don't report so many drop outs.
Maybe there are just too many GPS antennae in my ship.ツ* I'll take a look
at a divider for everything except the ADS-B WAAS GPS.ツ* Its antenna is
mounted aft of the engine in the Stemme.ツ* The rest are on or under the
glare shield.
On 5/5/2019 7:42 PM, JS wrote:
On Sunday, May 5, 2019 at 3:43:24 PM UTC-7, Dan Marotta wrote:
Thanks Tim
I'll increase my time interval to 2 seconds and see if that helps.
Strange that the igc file does not show GPS drop outs since my
ClearNav
screen went white with the caption (something like) No GPS.ツ* Zero
satellites.ツ* And the ClearNav vario said, "Warning no GPS".ツ* The
PowerFlarm portable screen also went blank with a "Zero satellites"
message.
On 5/5/2019 1:05 PM, Tim Newport-Peace wrote:
Dan,
Open your file with a text editor and search for "B190338"
This will put you in the right area.
In each record, after the letter B, the next six bytes are the time.
After B190339 the time jumps back to B190337, which is odd, and
leads
to
there being two records with a time of 190338, and also 190339.
Odd, but I have seen this before. Maybe you can avoid it in future by
setting a longer fix interval, even 2 seconds might help, but no
promises.
I am not seeing any GPS outage around that time. This would be shown
by
Letter "A" in the 25th byte changing to a "V".
Although it does not help a lot, the sequence error seems to happen
as
you
left the ground, so I guess you were not reversing turns?
I'm not saying this is what OLC are complaining about, just that it
is
odd
and it might be.
Tim.
Dan, 5J
That smells of GPS jamming.
Check this page.
https://www.navcen.uscg.gov/pdf/gps/...terference.pdf
I did not have a problem with the vario file today. My antenna has a
shortened cable to a MECA divider, then a short SMA-SMA link cable.
Dan, 5J
Old May 6th 19, 05:34 PM posted to rec.aviation.soaring
Dan Marotta
You're correct, Tim.ツ* I just checked and the latest firmware for the
vario is dated 5/10/18.ツ* I'll download that today.ツ* Still, I'm getting
the same error message from OLC for the ClearNav II computer with the
latest firmware installed.
about 400 nm.テつ* Moriarty is well within that area.テつ* I've asked other
Maybe there are just too many GPS antennae in my ship.テつ* I'll take a look
at a divider for everything except the ADS-B WAAS GPS.テつ* Its antenna is
mounted aft of the engine in the Stemme.テつ* The rest are on or under the
glare shield.
Thanks Tim
ClearNav
screen went white with the caption (something like) No GPS.テつ* Zero
satellites.テつ* And the ClearNav vario said, "Warning no GPS".テつ* The
message.
Dan,
leads
to
promises.
by
as
you
is
odd
and it might be.
Tim.
Dan, 5J
Check this page.
Dan, 5J
Dan, 5J
All US Records are Now Motor Glider Records Tango Eight Soaring 99 March 23rd 17 12:07 PM
OT 4 airport round robin - time lapsed / real time with ATC COMS -video A Lieberma[_2_] Owning 0 August 30th 09 12:26 AM
OT 4 airport round robin - time lapsed / real time with ATC COMS -video [email protected] Instrument Flight Rules 0 August 30th 09 12:26 AM
4 airport round robin - time lapsed / real time with ATC COMS - video [email protected] Piloting 0 August 30th 09 12:25 AM
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap tim liverance Military Aviation 0 August 18th 03 12:18 AM
Copyright ゥ2004-2025 AviationBanter.
