An interesting thought, but I see the same whether I'm using the
ClearNav or the ClearNav vario.Â* I doubt both could be experiencing the same fault at the same time.Â* It's really odd about the apparent time compression on the OLC display.Â* My flights score and appear just fine on skylines.aero. On 5/7/2019 8:21 AM, kinsell wrote: Looking at your flight logs on OLC, you have the last two that didn't validate, but others earlier this year that did. However, most of the altitude graphs are plotted with many hours of dead time, with the flight being compressed into the very right hand part of the graph. A very bizarre presentation. Perhaps your ClearNav has a hardware fault that is gradually getting worse? On 5/6/19 4:20 PM, Dan Marotta wrote: These dropouts never occur during engine run which normally only runs 10 minutes or less from engine start to shutdown after takeoff. Heating up the dielectric is something I didn't consider.Â* Maybe I should replace the antennae... On 5/6/2019 11:39 AM, kinsell wrote: On 5/6/19 10:32 AM, Dan Marotta wrote: I've also had drop outs with my Trig TN-70 and its antenna, though not as often as with my soaring GPSs. Do they correlate with the engine running?Â* If so, might be ignition noise. Yes, the wires are tiny, but it was pretty simple to desolder them from the puck, clip the cable to length, strip, tin, and solder.Â* I did that for 3 antennae and they generally work fine, but lately have acting up. It's easy to overheat the dielectric in the coax, causing loss of signal strength. I'm looking at THESE https://www.amazon.com/CIROCOMM-Antenna-Ceramic-25x25x2mm-Geekstory/dp/B078Y2WNY6?ref_=Oct_TopRatedC_3248676011_1&pf_rd_p =57ac2d87-b669-53fa-a2b6-2c15e8d66f28&pf_rd_s=merchandised-search-6&pf_rd_t=101&pf_rd_i=3248676011&pf_rd_m=ATVPDKIKX 0DER&pf_rd_r=GNQVSWJ3FAVNDTDDJJDS&pf_rd_r=GNQVSWJ3 FAVNDTDDJJDS&pf_rd_p=57ac2d87-b669-53fa-a2b6-2c15e8d66f28 as replacements.Â* Any comments?Â* I wonder if that IPEX connector is a push fit on the built in SMA connectors on the devices. I'm also considering replacing the modified antennae with factory new units and using the longer cables to mount them on opposite canopy rails in the Stemme.Â* Those should be about a meter apart. On 5/6/2019 9:44 AM, kinsell wrote: Jamming is directed skyward, they're not taking out car gps's in a 400 nm radius.Â* If you're getting bad time stamps just at liftoff, it's not likely caused by jamming. I'm suspicious of your cut-down gps cables, those are tiny wires to be working on. On 5/6/19 9:08 AM, Dan Marotta wrote: Yes, the GPS jamming usually centers around Alamogordo and ranges out to about 400 nm.Â* Moriarty is well within that area.Â* I've asked other local pilots and they don't report so many drop outs. Maybe there are just too many GPS antennae in my ship. I'll take a look at a divider for everything except the ADS-B WAAS GPS.Â* Its antenna is mounted aft of the engine in the Stemme. The rest are on or under the glare shield. On 5/5/2019 7:42 PM, JS wrote: On Sunday, May 5, 2019 at 3:43:24 PM UTC-7, Dan Marotta wrote: Thanks Tim I'll increase my time interval to 2 seconds and see if that helps. Strange that the igc file does not show GPS drop outs since my ClearNav screen went white with the caption (something like) No GPS. Zero satellites.Â* And the ClearNav vario said, "Warning no GPS". The PowerFlarm portable screen also went blank with a "Zero satellites" message. On 5/5/2019 1:05 PM, Tim Newport-Peace wrote: Dan, Open your file with a text editor and search for "B190338" This will put you in the right area. In each record, after the letter B, the next six bytes are the time. After B190339 the time jumps back toÂ* B190337, which is odd, and leads to there being two records with a time of 190338, and also 190339. Odd, but I have seen this before. Maybe you can avoid it in future by setting a longer fix interval, even 2 seconds might help, but no promises. I am not seeing any GPS outage around that time. This would be shown by the Letter "A" in the 25th byte changing to a "V". Although it does not help a lot, the sequence error seems to happen as you left the ground, so I guess you were not reversing turns? I'm not saying this is what OLC are complaining about, just that it is odd and it might be. Tim. -- Dan, 5J That smells of GPS jamming. Check this page. https://www.navcen.uscg.gov/pdf/gps/...terference.pdf I did not have a problem with the vario file today. My antenna has a shortened cable to a MECA divider, then a short SMA-SMA link cable. Jim -- Dan, 5J -- Dan, 5J |
On Tuesday, May 7, 2019 at 9:21:33 AM UTC-6, Dan Marotta wrote:
An interesting thought, but I see the same whether I'm using the ClearNav or the ClearNav vario.Â* I doubt both could be experiencing the same fault at the same time.Â* It's really odd about the apparent time compression on the OLC display.Â* My flights score and appear just fine on skylines.aero. On 5/7/2019 8:21 AM, kinsell wrote: Looking at your flight logs on OLC, you have the last two that didn't validate, but others earlier this year that did. However, most of the altitude graphs are plotted with many hours of dead time, with the flight being compressed into the very right hand part of the graph. A very bizarre presentation. Perhaps your ClearNav has a hardware fault that is gradually getting worse? On 5/6/19 4:20 PM, Dan Marotta wrote: These dropouts never occur during engine run which normally only runs 10 minutes or less from engine start to shutdown after takeoff. Heating up the dielectric is something I didn't consider.Â* Maybe I should replace the antennae... On 5/6/2019 11:39 AM, kinsell wrote: On 5/6/19 10:32 AM, Dan Marotta wrote: I've also had drop outs with my Trig TN-70 and its antenna, though not as often as with my soaring GPSs. Do they correlate with the engine running?Â* If so, might be ignition noise. Yes, the wires are tiny, but it was pretty simple to desolder them from the puck, clip the cable to length, strip, tin, and solder.Â* I did that for 3 antennae and they generally work fine, but lately have acting up. It's easy to overheat the dielectric in the coax, causing loss of signal strength. I'm looking at THESE https://www.amazon.com/CIROCOMM-Antenna-Ceramic-25x25x2mm-Geekstory/dp/B078Y2WNY6?ref_=Oct_TopRatedC_3248676011_1&pf_rd_p =57ac2d87-b669-53fa-a2b6-2c15e8d66f28&pf_rd_s=merchandised-search-6&pf_rd_t=101&pf_rd_i=3248676011&pf_rd_m=ATVPDKIKX 0DER&pf_rd_r=GNQVSWJ3FAVNDTDDJJDS&pf_rd_r=GNQVSWJ3 FAVNDTDDJJDS&pf_rd_p=57ac2d87-b669-53fa-a2b6-2c15e8d66f28 as replacements.Â* Any comments?Â* I wonder if that IPEX connector is a push fit on the built in SMA connectors on the devices. I'm also considering replacing the modified antennae with factory new units and using the longer cables to mount them on opposite canopy rails in the Stemme.Â* Those should be about a meter apart. On 5/6/2019 9:44 AM, kinsell wrote: Jamming is directed skyward, they're not taking out car gps's in a 400 nm radius.Â* If you're getting bad time stamps just at liftoff, it's not likely caused by jamming. I'm suspicious of your cut-down gps cables, those are tiny wires to be working on. On 5/6/19 9:08 AM, Dan Marotta wrote: Yes, the GPS jamming usually centers around Alamogordo and ranges out to about 400 nm.Â* Moriarty is well within that area.Â* I've asked other local pilots and they don't report so many drop outs. Maybe there are just too many GPS antennae in my ship. I'll take a look at a divider for everything except the ADS-B WAAS GPS.Â* Its antenna is mounted aft of the engine in the Stemme. The rest are on or under the glare shield. On 5/5/2019 7:42 PM, JS wrote: On Sunday, May 5, 2019 at 3:43:24 PM UTC-7, Dan Marotta wrote: Thanks Tim I'll increase my time interval to 2 seconds and see if that helps. Strange that the igc file does not show GPS drop outs since my ClearNav screen went white with the caption (something like) No GPS. Zero satellites.Â* And the ClearNav vario said, "Warning no GPS". The PowerFlarm portable screen also went blank with a "Zero satellites" message. On 5/5/2019 1:05 PM, Tim Newport-Peace wrote: Dan, Open your file with a text editor and search for "B190338" This will put you in the right area. In each record, after the letter B, the next six bytes are the time. After B190339 the time jumps back toÂ* B190337, which is odd, and leads to there being two records with a time of 190338, and also 190339. Odd, but I have seen this before. Maybe you can avoid it in future by setting a longer fix interval, even 2 seconds might help, but no promises. I am not seeing any GPS outage around that time. This would be shown by the Letter "A" in the 25th byte changing to a "V". Although it does not help a lot, the sequence error seems to happen as you left the ground, so I guess you were not reversing turns? I'm not saying this is what OLC are complaining about, just that it is odd and it might be. Tim. -- Dan, 5J That smells of GPS jamming. Check this page. https://www.navcen.uscg.gov/pdf/gps/...terference.pdf I did not have a problem with the vario file today. My antenna has a shortened cable to a MECA divider, then a short SMA-SMA link cable. Jim -- Dan, 5J -- Dan, 5J Dan, my ClearNav XC logger, when downloaded to the OLC, appears to display the same as yours(time compression to the right). I used my Flarm IGC logger and it appears normal for the OLC. Yet on Skyline aero, Cross-country aero and See you, the ClearNav logger displays and views as normal. The last several flights I have had experience GPS dropouts, which on Sunday seemed odd, and lasted only several minutes at a time(I fly out of KALM and the loss of signal was in numerous areas on Sunday). All the updates have been done, now several times over, yet the ClearNav logger and OLC just don't get along, yet the flight is scored and shows valid. Don't get an OLC speed when using the ClearNav. When you figure this out, let us know! Best. Tom #711 |
Another thought:Â* Richard Kellerman advised me to snug the connectors
with a wrench.Â* Mine are probably only hand tight. Another small task... On 5/6/2019 4:20 PM, Dan Marotta wrote: These dropouts never occur during engine run which normally only runs 10 minutes or less from engine start to shutdown after takeoff. Heating up the dielectric is something I didn't consider.Â* Maybe I should replace the antennae... On 5/6/2019 11:39 AM, kinsell wrote: On 5/6/19 10:32 AM, Dan Marotta wrote: I've also had drop outs with my Trig TN-70 and its antenna, though not as often as with my soaring GPSs. Do they correlate with the engine running?Â* If so, might be ignition noise. Yes, the wires are tiny, but it was pretty simple to desolder them from the puck, clip the cable to length, strip, tin, and solder.Â* I did that for 3 antennae and they generally work fine, but lately have acting up. It's easy to overheat the dielectric in the coax, causing loss of signal strength. I'm looking at THESE https://www.amazon.com/CIROCOMM-Antenna-Ceramic-25x25x2mm-Geekstory/dp/B078Y2WNY6?ref_=Oct_TopRatedC_3248676011_1&pf_rd_p =57ac2d87-b669-53fa-a2b6-2c15e8d66f28&pf_rd_s=merchandised-search-6&pf_rd_t=101&pf_rd_i=3248676011&pf_rd_m=ATVPDKIKX 0DER&pf_rd_r=GNQVSWJ3FAVNDTDDJJDS&pf_rd_r=GNQVSWJ3 FAVNDTDDJJDS&pf_rd_p=57ac2d87-b669-53fa-a2b6-2c15e8d66f28 as replacements.Â* Any comments?Â* I wonder if that IPEX connector is a push fit on the built in SMA connectors on the devices. I'm also considering replacing the modified antennae with factory new units and using the longer cables to mount them on opposite canopy rails in the Stemme.Â* Those should be about a meter apart. On 5/6/2019 9:44 AM, kinsell wrote: Jamming is directed skyward, they're not taking out car gps's in a 400 nm radius.Â* If you're getting bad time stamps just at liftoff,Â* it's not likely caused by jamming. I'm suspicious of your cut-down gps cables, those are tiny wires to be working on. On 5/6/19 9:08 AM, Dan Marotta wrote: Yes, the GPS jamming usually centers around Alamogordo and ranges out to about 400 nm. Moriarty is well within that area.Â* I've asked other local pilots and they don't report so many drop outs. Maybe there are just too many GPS antennae in my ship. I'll take a look at a divider for everything except the ADS-B WAAS GPS.Â* Its antenna is mounted aft of the engine in the Stemme. The rest are on or under the glare shield. On 5/5/2019 7:42 PM, JS wrote: On Sunday, May 5, 2019 at 3:43:24 PM UTC-7, Dan Marotta wrote: Thanks Tim I'll increase my time interval to 2 seconds and see if that helps. Strange that the igc file does not show GPS drop outs since my ClearNav screen went white with the caption (something like) No GPS. Zero satellites.Â* And the ClearNav vario said, "Warning no GPS". The PowerFlarm portable screen also went blank with a "Zero satellites" message. On 5/5/2019 1:05 PM, Tim Newport-Peace wrote: Dan, Open your file with a text editor and search for "B190338" This will put you in the right area. In each record, after the letter B, the next six bytes are the time. After B190339 the time jumps back toÂ* B190337, which is odd, and leads to there being two records with a time of 190338, and also 190339. Odd, but I have seen this before. Maybe you can avoid it in future by setting a longer fix interval, even 2 seconds might help, but no promises. I am not seeing any GPS outage around that time. This would be shown by the Letter "A" in the 25th byte changing to a "V". Although it does not help a lot, the sequence error seems to happen as you left the ground, so I guess you were not reversing turns? I'm not saying this is what OLC are complaining about, just that it is odd and it might be. Tim. -- Dan, 5J That smells of GPS jamming. Check this page. https://www.navcen.uscg.gov/pdf/gps/...terference.pdf I did not have a problem with the vario file today. My antenna has a shortened cable to a MECA divider, then a short SMA-SMA link cable. Jim -- Dan, 5J -- Dan, 5J |
All US Records are Now Motor Glider Records | Tango Eight | Soaring | 99 | March 23rd 17 12:07 PM |
OT 4 airport round robin - time lapsed / real time with ATC COMS -video | A Lieberma[_2_] | Owning | 0 | August 30th 09 12:26 AM |
OT 4 airport round robin - time lapsed / real time with ATC COMS -video | [email protected] | Instrument Flight Rules | 0 | August 30th 09 12:26 AM |
4 airport round robin - time lapsed / real time with ATC COMS - video | [email protected] | Piloting | 0 | August 30th 09 12:25 AM |
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap | tim liverance | Military Aviation | 0 | August 18th 03 12:18 AM |
