One of these days I will need to do a "top end" and wondering if higher
compression cylinders would be a way to go. That way I would feel more comfortable using 100LL since my source of 80 octane is no longer available here. Would I also expect a little more horse power? Thanks Larry |
"Boelkowj" wrote in message ... One of these days I will need to do a "top end" and wondering if higher compression cylinders would be a way to go. That way I would feel more comfortable using 100LL since my source of 80 octane is no longer available here. Would I also expect a little more horse power? Thanks Larry The later casting cylinders are better for higher compression. You may recall that timing was retarded to 24 degrees on older cylinders. You can check up on all that with part numbers and the manual. Compression may be raised by using C-85 pistons and the better casting stock cylinders. Other mods, like a hotter cam, may also be done to improve performance, but of course your engine can no longer be certified or keep its data plate if modified. Don't turn your engine over 2750 rpm. Don't use 100LL in an O-200 without an additive to leach out the lead. Talk to the guys who modify their engines for racing at Reno. See this service bulletin from TCM: http://www.sacskyranch.com/tcmtime.pdf |
"Boelkowj" wrote in message ... One of these days I will need to do a "top end" and wondering if higher compression cylinders would be a way to go. That way I would feel more comfortable using 100LL since my source of 80 octane is no longer available here. Would I also expect a little more horse power? Thanks That's one of the engines that run's OK on Mogas, no need for using avgas unless it's cheaper than mogas or you need to fly higher than 5,000 feet. Another consideration is your fuel system, if it's designed so badly that you get vapour lock with mogas then you'll have to stick to avgas, plays hell on your oil, you get a gray sludge from the lead content. -- --- Cheers, Jonathan Lowe. / don't bother me with insignificiant nonsence such as spelling, I don't care if it spelt properly / Sometimes I fly and sometimes I just dream about it. :-) Larry |
On Fri, 12 Dec 2003 13:02:56 -0500, "Larry Smith"
wrote: Don't use 100LL in an O-200 without an additive to leach out the lead. bull**** I run 100/130 leaded avgas in my O-200 with not a single problem. it is a bog standard unmodified engine with one exception. I use REM38E plugs instead of the standard REM40E plugs. it runs as sweet as a well oiled swiss watch. oil is BP D100 made in america. oil I used before the local BP stopped being sold it by Shell was AeroShell D100. oil is changed every six months or every year, doesnt seem to make much difference I think because I try to keep each engine run to something over an hour. on the other side of australia the supply is 100LL. I've never noticed a difference in the running characteristics with either fuel. engine has 550 hours on it now. I'd say that proves the combination. I think you are referring to the problems with the early phillips multigrade oil arent you? the O-200 itself has no problems with the fuel if you use the appropriate plugs. Stealth Pilot Western Australia |
| Thread Tools | |
| Display Modes | |
| 0-320 cylinders | Drew Dalgleish | Home Built | 9 | December 8th 03 05:25 PM |
