Ventus rigging advice, please?
Old June 28th 19, 07:54 PM posted to rec.aviation.soaring
Default Ventus rigging advice, please?
On Tuesday, June 25, 2019 at 5:00:05 AM UTC-4, John McLaughlin wrote:
I've recently started flying a Ventus2. I can't rig the thing without a lot
of
struggle. The trouble is, there's a cover above the spars and you can't see
anything once the first wing is in.
I struggle to get the second wing to fit, never knowing whether it's a bit
too
high or a bit too low. The ground is uneven and sloping, which doesn't
help.
I hope some Ventus owners can give me some tips, please?
All about technique
https://www.youtube.com/watch?v=bcRipsiPgdk
UH
Old June 28th 19, 10:27 PM posted to rec.aviation.soaring
Mike C
of
too
help.
All about technique
UH
That was impressive!
Mike
Old June 29th 19, 04:47 AM posted to rec.aviation.soaring
It gets better. I've been solo rigging almost every time since 1982 when I built my first WingMate for my LS-3, knowing my mother would never make it thru a full Nationals crewing for me without some help.
But my REAL first solo rigging was with some foam pads, one conventional wingstand, and the hood of our car. My father wasn't around to help me assemble our Libelle 201--or to stop me from experimenting. I can't recall whether I told him what I'd done or not.
Chip Bearden
JB
Old June 29th 19, 08:29 AM posted to rec.aviation.soaring
Jonathon May
without a
lot
of
you can't
see
whether it's a
bit
too
which doesn't
help.
All about technique
UH
Mike
`````````remember this!
https://youtu.be/Huk_WOxk1oc
Old June 29th 19, 03:08 PM posted to rec.aviation.soaring
Dan Marotta
That was really fun to watch!Â* ...But I would personally want to wiggle
everything before launching...
without a
lot
of
you can't
see
whether it's a
bit
too
which doesn't
help.
All about technique
UH
Mike
Dan, 5J
Old June 30th 19, 04:25 PM posted to rec.aviation.soaring
Ernst
Poisitve control check?
Old June 30th 19, 11:14 PM posted to rec.aviation.soaring
"The trouble is, there's a cover above the spars and you can't see
anything once the first wing is in."
On mine, the cover slides back further to fit behind the spars.
Might be worth making sure there is no gap behind your's.
Old July 21st 19, 07:12 PM posted to rec.aviation.soaring
John McLaughlin
Thanks everyone - I think I've got it cracked now - right wing first, tape
it.
Then, the big thing I've learnt is to feel inside the battery rack below
spars. I can now tell, by feel whether the second wing is too high or too
low
and knowing that makes all the difference.
Old July 21st 19, 07:27 PM posted to rec.aviation.soaring
John McLaughlin
And maybe next time, I should proof read my posting!
John McLaughlin
ventus rigging visual clues [email protected] Soaring 13 May 3rd 18 12:08 PM
Ka-6 Rigging vontresc Soaring 19 August 14th 08 04:55 AM
Ventus C rigging James Hamilton Soaring 8 July 7th 06 08:30 AM
Ventus C rigging James Hamilton Soaring 0 July 6th 06 07:41 PM
ski rigging Drew Dalgleish Home Built 3 December 3rd 03 04:16 AM
