Ventus rigging advice, please?
Old July 22nd 19, 02:44 AM posted to rec.aviation.soaring
Steve Bralla
Default Ventus rigging advice, please?
On Sunday, July 21, 2019 at 11:15:05 AM UTC-7, John McLaughlin wrote:
Thanks everyone - I think I've got it cracked now - right wing first, tape
it.
Then, the big thing I've learnt is to feel inside the battery rack below
spars. I can now tell, by feel whether the second wing is too high or too
low
and knowing that makes all the difference.
Not the way I do it but if it works for you.... Practice is the most important thing. Enjoy your Ventus. I'm enjoying mine.
Steve
Old July 22nd 19, 07:35 PM posted to rec.aviation.soaring
John McLaughlin
'Not the way to do it'
Why not?
Old July 22nd 19, 09:04 PM posted to rec.aviation.soaring
He said not the way "I" do it. Quite a difference.
Dan
Why not?
Old July 22nd 19, 05:00 PM posted to rec.aviation.soaring
2G
it.
low
I put reference marks on the spar butt ends and inside the fuselage that indicate when the correct dihedral angle is achieved. I also using my index finger to feel for a mismatch between the main pin bushings while adjusting the height of the fuselage jack (start low and gradually go up). You can feel even the slightest misalignment.
Tom
Old August 3rd 19, 10:05 PM posted to rec.aviation.soaring
On Tuesday, June 25, 2019 at 5:00:05 AM UTC-4, John McLaughlin wrote:
I've recently started flying a Ventus2. I can't rig the thing without a lot
of
struggle. The trouble is, there's a cover above the spars and you can't see
anything once the first wing is in.
I struggle to get the second wing to fit, never knowing whether it's a bit
too
high or a bit too low. The ground is uneven and sloping, which doesn't
help.
I hope some Ventus owners can give me some tips, please?
Old August 3rd 19, 10:08 PM posted to rec.aviation.soaring
of
too
help.
Having read the entire string of postings I am surprised to see that nowhere is lubrication mentioned. All the tips are great, but a little grease goes a long way in taking a little of the hassle out of rigging S-H sailplanes.
Old August 4th 19, 04:47 AM posted to rec.aviation.soaring
A clean set of pins and some lube goes a long way in rigging......period......
Old August 7th 19, 05:09 PM posted to rec.aviation.soaring
On Saturday, August 3, 2019 at 9:47:38 PM UTC-6, Charlie M. (UH & 002 owner/pilot) wrote:
+1 for my Ventus B. I spent a year or two trying to figure out why, with all things to the best of my knowledge the same, sometimes the wings would protest and sometimes not. Fresh lube each rigging has provided the answer.
Old August 8th 19, 02:02 AM posted to rec.aviation.soaring
2G
....and you simultaneously figured out how to align the wings to the fuse. Don't believe me? Misalign the wings and see if they still go on. Alignment is the key (I have had no problem assembling gliders w/o ANY lube)...
Old August 8th 19, 04:30 PM posted to rec.aviation.soaring
Nope. Rather, I'm sure it is that you mistakenly attribute your success in rigging to alignment rather than that you're now properly lubing (see how useless a comment like that is? We could go back and forth forever...)
ventus rigging visual clues [email protected] Soaring 13 May 3rd 18 12:08 PM
Ka-6 Rigging vontresc Soaring 19 August 14th 08 04:55 AM
Ventus C rigging James Hamilton Soaring 8 July 7th 06 08:30 AM
Ventus C rigging James Hamilton Soaring 0 July 6th 06 07:41 PM
ski rigging Drew Dalgleish Home Built 3 December 3rd 03 04:16 AM
