Wing Contour?
Old August 2nd 19, 01:34 AM posted to rec.aviation.soaring
Bob Kuykendall
Default Wing Contour?
On Thursday, August 1, 2019 at 4:26:22 PM UTC-7, wrote:
...I know, and have used Bondo to that depth on other things, but aircraft?
Thank you for the insight and expertise you have shown in the answers you have give.
There are a variety of fillers you can use. I'd suggest a mix of glass microballoons and laminating epoxy resin. Before you start the actual work, make a few test batches of filler to see how dry you can mix it before it does not spread properly. You want it as dry and light as you can practically work.
You'll want to sand the wing somewhere around 120 to 220 grit before applying filler to get a good bonding surface. Degrease the surface before applying filler with acetone to rid it of contaminants.
One common technique is to use your templates to cast in place a series of raised ribs of microballoons. Then apply and sand your filler between the raised ribs.
--Bob K.
Old August 2nd 19, 02:07 AM
Delta8 Delta8 is offline
Member
First recorded activity by AviationBanter: Apr 2019
--Bob K.
http://www.archive.jimphoenix.com/ar...UP%20wing.html
Is this the technique you were referring to ? Would be curious as to how his finish held up as it appears he used filler over old Gelcoat .
Also seems he went full chord with the templates . Overkill?
Bob
Youth soaring program looking for wing wheel for large-chord wing Jay[_2_] Soaring 1 September 17th 14 02:44 AM
ASW-20A Left Wing or Inboard Wing Skin Needed Coucked Soaring 0 August 29th 10 02:43 PM
Soft field landings - low wing vs high wing aircraft Justin Gombos Piloting 19 May 23rd 07 05:21 AM
Books on Military Rotary Wing to Civilian Fixed Wing Transition? Greg Copeland Piloting 5 May 2nd 07 03:23 AM
Mylar tape wing seals - effect on wing performance Simon Waddell Soaring 8 January 1st 04 03:46 PM
