On Wednesday, August 14, 2019 at 7:39:56 PM UTC+3, Bob Kuykendall wrote:
My advice: Fill the tire with an air chuck that has a gauge at the beginning of the season, while the glider is standing on it. When you do that, look at how much it bulges at the bottom. As long as the tire looks about like it did when you filled it, it probably is about right. --Bob K. This is what most probably would do (me included). However, it's impossible to see if you have pressure little bit on low side. Flight manual tire pressure is not maximum number, it is THE recommended pressure. Tube chafes with tire if pressure is short of this. Enough pressure and you really do not suffer from flat tires, at least that is my experience. |
Lessons what I have learned: Never check the tyre pressure on the way to a
competition grid. Pump if obviously low and dangerous but otherwise leave well alone. In 2005 I did check the pressure at the 15s. Tyre went down and could not be re-inflated as valve was jammed. Valve could not be replaced. Had to replace the entire wheel. Got to the start, landed out in a penalty zone took 500 point penalty. Altogether a bad day! Jim |
As it turns out, I just recently addressed this issue for the JS3 tailwheel.. The retractable tailwheel is quite small. The air volume is such that any attempt to put a gauge on it will drop the pressure quit a lot. Also being so small, I found it hard to judge by eye.
The method I came up with uses a machinist outside caliper to measure tire bulge. It's easily understood with these pictures: https://photos.app.goo.gl/uyt8BgJWRSKKHuj6A There's a certain skill required to use the machinist caliper -- the key is zero spring pressure. Accuracy is about 5 PSI. I was able to accomplish the calibration without any reference to dimensional measurements (inches or mm). Since this was just devised a couple weeks before the OP came on with his question, it hasn't had much field testing. We'll see if this is a good solution after I've used it awhile. |
Steve Koerner wrote on 8/15/2019 4:59 PM:
As it turns out, I just recently addressed this issue for the JS3 tailwheel.. The retractable tailwheel is quite small. The air volume is such that any attempt to put a gauge on it will drop the pressure quit a lot. Also being so small, I found it hard to judge by eye. The method I came up with uses a machinist outside caliper to measure tire bulge. It's easily understood with these pictures: https://photos.app.goo.gl/uyt8BgJWRSKKHuj6A There's a certain skill required to use the machinist caliper -- the key is zero spring pressure. Accuracy is about 5 PSI. I was able to accomplish the calibration without any reference to dimensional measurements (inches or mm). Since this was just devised a couple weeks before the OP came on with his question, it hasn't had much field testing. We'll see if this is a good solution after I've used it awhile. Clever! But, are there solid tire wheels that could replace the pneumatic one? Or get it filled with foam? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 - "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm http://soaringsafety.org/prevention/...anes-2014A.pdf |
On Thursday, August 15, 2019 at 4:59:03 PM UTC-7, Steve Koerner wrote:
The air volume is such that any attempt to put a gauge on it will drop the pressure quit a lot. One of the best real-world application of the Observer Effect I've heard of in a while. --Bob K. |
Tire Pressure Monitoring Systems for Trailers | AS | Soaring | 6 | July 11th 18 04:00 AM |
PW-5 Main Tire Pressure? | JohnDeRosa | Soaring | 3 | June 23rd 13 09:38 AM |
Accurate tire pressure gage? | Kurt Thams | Soaring | 6 | September 25th 12 11:17 PM |
Tire tread wear vs inflation pressure | Ben Jackson | Owning | 22 | October 6th 06 04:35 AM |
Tire inflation pressure | Paul Lee | Home Built | 80 | November 19th 03 07:56 AM |
