https://en.wikipedia.org/wiki/Focke-Wulf_Fw_190
--- https://nationalinterest.org/blog/bu...d-war-ii-41382 The Focke-Wulf Fw 190 Würger (English: Shrike) is a German single-seat, single-engine fighter aircraft designed by Kurt Tank in the late 1930s and widely used during World War II. Along with its well-known counterpart, the Messerschmitt Bf 109, the Fw 190 became the backbone of the Luftwaffe's Jagdwaffe (Fighter Force). The twin-row BMW 801 radial engine that powered most operational versions enabled the Fw 190 to lift larger loads than the Bf 109, allowing its use as a day fighter, fighter-bomber, ground-attack aircraft and, to a lesser degree, night fighter. The Fw 190A started flying operationally over France in August 1941, and quickly proved superior in all but turn radius to the Royal Air Force's main front-line fighter, the Spitfire Mk. V, particularly at low and medium altitudes. The 190 maintained superiority over Allied fighters until the introduction of the improved Spitfire Mk. IX. In November/December 1942, the Fw 190 made its air combat debut on the Eastern Front, finding much success in fighter wings and specialised ground attack units called Schlachtgeschwader (Battle Wings or Strike Wings) from October 1943 onwards. The Fw 190 provided greater firepower than the Bf 109 and, at low to medium altitude, superior manoeuvrability, in the opinion of German pilots who flew both fighters. The Fw 190A series' performance decreased at high altitudes (usually 6,000 m (20,000 ft) and above), which reduced its effectiveness as a high-altitude interceptor. From the Fw 190's inception, there had been ongoing efforts to address this with a turbosupercharged BMW 801 in the B model, the much longer-nosed C model with efforts to also turbocharge its chosen Daimler-Benz DB 603 inverted V12 powerplant, and the similarly long-nosed D model with the Junkers Jumo 213. Problems with the turbocharger installations on the -B and -C subtypes meant only the D model would enter service, doing so in September 1944. While these "long nose" versions gave the Germans parity with Allied opponents, they arrived far too late in the war to have any real effect. The Fw 190 was well-liked by its pilots. Some of the Luftwaffe's most successful fighter aces claimed a great many of their kills while flying it, including Otto Kittel, Walter Nowotny and Erich Rudorffer. Design concepts At the time, the use of radial engines in land-based fighters was relatively rare in Europe, as it was believed that their large frontal area would cause too much drag on something as small as a fighter. Tank was not convinced of this, having witnessed the successful use of radial engines by the U.S. Navy, and felt a properly streamlined installation would eliminate this problem. The hottest points on any air-cooled engine are the cylinder heads, located around the circumference of a radial engine. In order to provide sufficient air to cool the engine, airflow had to be maximized at this outer edge. This was normally accomplished by leaving the majority of the front face of the engine open to the air, causing considerable drag. During the late 1920s, NACA led development of a dramatic improvement by placing an airfoil-shaped ring around the outside of the cylinder heads (the NACA cowling). The shaping accelerated the air as it entered the front of the cowl, increasing the total airflow, and allowing the opening in front of the engine to be made smaller. Tank introduced a further refinement to this basic concept. He suggested placing most of the airflow components on the propeller, in the form of an oversized propeller spinner whose outside diameter was the same as the engine. The cowl around the engine proper was greatly simplified, essentially a basic cylinder. Air entered through a small hole at the centre of the spinner, and was directed through ductwork in the spinner so it was blowing rearward along the cylinder heads. To provide enough airflow, an internal cone was placed in the centre of the hole, over the propeller hub, which was intended to compress the airflow and allow a smaller opening to be used. In theory, the tight-fitting cowling also provided some thrust due to the compression and heating of air as it flowed through the cowling. As to the rest of the design philosophy, Tank wanted something more than an aircraft built only for speed. Tank outlined the reasoning: The Messerschmitt 109 [sic] and the British Spitfire, the two fastest fighters in world at the time we began work on the Fw 190, could both be summed up as a very large engine on the front of the smallest possible airframe; in each case armament had been added almost as an afterthought. These designs, both of which admittedly proved successful, could be likened to racehorses: given the right amount of pampering and easy course, they could outrun anything. But the moment the going became tough they were liable to falter. During World War I, I served in the cavalry and in the infantry. I had seen the harsh conditions under which military equipment had to work in wartime. I felt sure that a quite different breed of fighter would also have a place in any future conflict: one that could operate from ill-prepared front-line airfields; one that could be flown and maintained by men who had received only short training; and one that could absorb a reasonable amount of battle damage and still get back. This was the background thinking behind the Focke-Wulf 190; it was not to be a racehorse but a Dienstpferd, a cavalry horse. Role Fighter Manufacturer Primarily Focke-Wulf Flugzeugbau AG, but also AGO, Arado, Fieseler, Mimetall, Norddeutsche Dornier and others Designer Kurt Tank First flight 1 June 1939 Introduction August 1941 Retired 9 May 1945 (Luftwaffe) 1949 (Turkey) Primary users Luftwaffe Hungarian Air Force Turkish Air Force Produced 1941–45; 1996: 16 reproductions Number built Over 20,000 Variants Ta 152 The Fw 190 participated on every major combat front where the Luftwaffe operated after 1941, and did so with success in a variety of roles. Luftwaffe pilots who flew both the Fw 190 and the Bf 109 generally felt that, with the exception of high altitude capability, the Fw 190 was superior. Specifications (Fw 190 A-8) General characteristics Crew: 1 Length: 9.00 m (29 ft 5 in) Wingspan: 10.51 m (34 ft 5 in) Height: 3.95 m (12 ft 12 in) Wing area: 18.30 m² (196.99 ft²) Empty weight: 3,200 kg (7,060 lb) Loaded weight: 4,417 kg (9,735 lb) Max. takeoff weight: 4,900 kg (10,800 lb) Powerplant: 1 × BMW 801 D-2 radial engine, 1,250 kW (1,700 PS, 1,677 hp) Performance Maximum speed: 656 km/h (408 mph) at 19,420 ft (5,920 m) Range: 800 km (500 mi) Service ceiling: 11,410 m (37,430 ft) Rate of climb: 15 m/s (2,953 ft/min) Wing loading: 241 kg/m² (49.4 lb/ft²) Power/mass: 0.29–0.33 kW/kg (0.18–0.21 hp/lb) Armament Guns: 2 × 13 mm (.51 in) synchronized MG 131 machine guns with 475 rounds per gun 4 × 20 mm MG 151/20 E cannon with 250 rpg, synchronized in the wing roots and 140 rpg free-firing outboard in mid-wing mounts. ---- Specifications (Fw 190 D-9) General characteristics Crew: 1 Length: 10.20 m (33 ft 5½ in) Wingspan: 10.50 m (34 ft 5 in) Height: 3.35 m (11 ft 0 in) Wing area: 18.30 m² (196.99 ft²) Empty weight: 3,490 kg (7,694 lb) Loaded weight: 4,270 kg (9,413 lb) Max. takeoff weight: 4,840 kg (10,670 lb) Powerplant: 1 × Junkers Jumo 213A 12-cylinder inverted-Vee piston engine, 1,287 kW (1,750 PS, 1,726 hp) or 1,508 kW (2,050 PS, 2,022 hp) with boost (model 213E) Performance Maximum speed: 685 km/h (426 mph) at 6,600 m (21,655 ft), 710 km/h (440 mph) at 11,000 m (36,000 ft) Range: 835 km (519 mi) Service ceiling: 12,000 m (39,370 ft) Rate of climb: 17 m/s (3,300 ft/min) Wing loading: 233 kg/m² (47.7 lb/ft²) Power/mass: 0.30–0.35 kW/kg (0.18–0.22 hp/lb) Armament Guns: (all synchronized to fire through propeller arc) 2 × 13 mm (.51 in) MG 131 machine guns with 475 rpg 2 × 20 mm MG 151 cannons with 250 rpg in the wing root Bombs: 1 × 500 kg (1,102 lb) SC 500 bomb (optional) * |
Miloch wrote in
: https://en.wikipedia.org/wiki/Focke-Wulf_Fw_190 --- https://nationalinterest.org/blog/bu...g-or-zero-was- best-fighter-plane-during-world-war-ii-41382 Story I heard was the success of the 109 left a lot of radial engines piled up in warehouses, with no fugure. Tank was ordered take all these radials and build an airplane around them. A backup to the 109 that everyone thought invincable. The rest of the Luftwaffe inventory were all liquid cooled machines, so he started from an assumption of failure. When the winter of 1941 hit the Russian front and the Fw 190 was the only plane (beside the other radial engine plane, the Ju52) they could get into the air he was vindicated. The Focke-Wulf Fw 190 Würger (English: Shrike) is a German single-seat, single-engine fighter aircraft designed by Kurt Tank in the late 1930s and widely used during World War II. Along with its well-known counterpart, the Messerschmitt Bf 109, the Fw 190 became the backbone of the Luftwaffe's Jagdwaffe (Fighter Force). The twin-row BMW 801 radial engine that powered most operational versions enabled the Fw 190 to lift larger loads than the Bf 109, allowing its use as a day fighter, fighter-bomber, ground-attack aircraft and, to a lesser degree, night fighter. The Fw 190A started flying operationally over France in August 1941, and quickly proved superior in all but turn radius to the Royal Air Force's main front-line fighter, the Spitfire Mk. V, particularly at low and medium altitudes. The 190 maintained superiority over Allied fighters until the introduction of the improved Spitfire Mk. IX. In November/December 1942, the Fw 190 made its air combat debut on the Eastern Front, finding much success in fighter wings and specialised ground attack units called Schlachtgeschwader (Battle Wings or Strike Wings) from October 1943 onwards. The Fw 190 provided greater firepower than the Bf 109 and, at low to medium altitude, superior manoeuvrability, in the opinion of German pilots who flew both fighters. The Fw 190A series' performance decreased at high altitudes (usually 6,000 m (20,000 ft) and above), which reduced its effectiveness as a high-altitude interceptor. From the Fw 190's inception, there had been ongoing efforts to address this with a turbosupercharged BMW 801 in the B model, the much longer-nosed C model with efforts to also turbocharge its chosen Daimler-Benz DB 603 inverted V12 powerplant, and the similarly long-nosed D model with the Junkers Jumo 213. Problems with the turbocharger installations on the -B and -C subtypes meant only the D model would enter service, doing so in September 1944. While these "long nose" versions gave the Germans parity with Allied opponents, they arrived far too late in the war to have any real effect. The Fw 190 was well-liked by its pilots. Some of the Luftwaffe's most successful fighter aces claimed a great many of their kills while flying it, including Otto Kittel, Walter Nowotny and Erich Rudorffer. Design concepts At the time, the use of radial engines in land-based fighters was relatively rare in Europe, as it was believed that their large frontal area would cause too much drag on something as small as a fighter. Tank was not convinced of this, having witnessed the successful use of radial engines by the U.S. Navy, and felt a properly streamlined installation would eliminate this problem. The hottest points on any air-cooled engine are the cylinder heads, located around the circumference of a radial engine. In order to provide sufficient air to cool the engine, airflow had to be maximized at this outer edge. This was normally accomplished by leaving the majority of the front face of the engine open to the air, causing considerable drag. During the late 1920s, NACA led development of a dramatic improvement by placing an airfoil-shaped ring around the outside of the cylinder heads (the NACA cowling). The shaping accelerated the air as it entered the front of the cowl, increasing the total airflow, and allowing the opening in front of the engine to be made smaller. Tank introduced a further refinement to this basic concept. He suggested placing most of the airflow components on the propeller, in the form of an oversized propeller spinner whose outside diameter was the same as the engine. The cowl around the engine proper was greatly simplified, essentially a basic cylinder. Air entered through a small hole at the centre of the spinner, and was directed through ductwork in the spinner so it was blowing rearward along the cylinder heads. To provide enough airflow, an internal cone was placed in the centre of the hole, over the propeller hub, which was intended to compress the airflow and allow a smaller opening to be used. In theory, the tight-fitting cowling also provided some thrust due to the compression and heating of air as it flowed through the cowling. As to the rest of the design philosophy, Tank wanted something more than an aircraft built only for speed. Tank outlined the reasoning: The Messerschmitt 109 [sic] and the British Spitfire, the two fastest fighters in world at the time we began work on the Fw 190, could both be summed up as a very large engine on the front of the smallest possible airframe; in each case armament had been added almost as an afterthought. These designs, both of which admittedly proved successful, could be likened to racehorses: given the right amount of pampering and easy course, they could outrun anything. But the moment the going became tough they were liable to falter. During World War I, I served in the cavalry and in the infantry. I had seen the harsh conditions under which military equipment had to work in wartime. I felt sure that a quite different breed of fighter would also have a place in any future conflict: one that could operate from ill-prepared front-line airfields; one that could be flown and maintained by men who had received only short training; and one that could absorb a reasonable amount of battle damage and still get back. This was the background thinking behind the Focke-Wulf 190; it was not to be a racehorse but a Dienstpferd, a cavalry horse. Role Fighter Manufacturer Primarily Focke-Wulf Flugzeugbau AG, but also AGO, Arado, Fieseler, Mimetall, Norddeutsche Dornier and others Designer Kurt Tank First flight 1 June 1939 Introduction August 1941 Retired 9 May 1945 (Luftwaffe) 1949 (Turkey) Primary users Luftwaffe Hungarian Air Force Turkish Air Force Produced 1941–45; 1996: 16 reproductions Number built Over 20,000 Variants Ta 152 The Fw 190 participated on every major combat front where the Luftwaffe operated after 1941, and did so with success in a variety of roles. Luftwaffe pilots who flew both the Fw 190 and the Bf 109 generally felt that, with the exception of high altitude capability, the Fw 190 was superior. Specifications (Fw 190 A-8) General characteristics Crew: 1 Length: 9.00 m (29 ft 5 in) Wingspan: 10.51 m (34 ft 5 in) Height: 3.95 m (12 ft 12 in) Wing area: 18.30 m² (196.99 ft²) Empty weight: 3,200 kg (7,060 lb) Loaded weight: 4,417 kg (9,735 lb) Max. takeoff weight: 4,900 kg (10,800 lb) Powerplant: 1 × BMW 801 D-2 radial engine, 1,250 kW (1,700 PS, 1,677 hp) Performance Maximum speed: 656 km/h (408 mph) at 19,420 ft (5,920 m) Range: 800 km (500 mi) Service ceiling: 11,410 m (37,430 ft) Rate of climb: 15 m/s (2,953 ft/min) Wing loading: 241 kg/m² (49.4 lb/ft²) Power/mass: 0.29–0.33 kW/kg (0.18–0.21 hp/lb) Armament Guns: 2 × 13 mm (.51 in) synchronized MG 131 machine guns with 475 rounds per gun 4 × 20 mm MG 151/20 E cannon with 250 rpg, synchronized in the wing roots and 140 rpg free-firing outboard in mid-wing mounts. ---- Specifications (Fw 190 D-9) General characteristics Crew: 1 Length: 10.20 m (33 ft 5½ in) Wingspan: 10.50 m (34 ft 5 in) Height: 3.35 m (11 ft 0 in) Wing area: 18.30 m² (196.99 ft²) Empty weight: 3,490 kg (7,694 lb) Loaded weight: 4,270 kg (9,413 lb) Max. takeoff weight: 4,840 kg (10,670 lb) Powerplant: 1 × Junkers Jumo 213A 12-cylinder inverted-Vee piston engine, 1,287 kW (1,750 PS, 1,726 hp) or 1,508 kW (2,050 PS, 2,022 hp) with boost (model 213E) Performance Maximum speed: 685 km/h (426 mph) at 6,600 m (21,655 ft), 710 km/h (440 mph) at 11,000 m (36,000 ft) Range: 835 km (519 mi) Service ceiling: 12,000 m (39,370 ft) Rate of climb: 17 m/s (3,300 ft/min) Wing loading: 233 kg/m² (47.7 lb/ft²) Power/mass: 0.30–0.35 kW/kg (0.18–0.22 hp/lb) Armament Guns: (all synchronized to fire through propeller arc) 2 × 13 mm (.51 in) MG 131 machine guns with 475 rpg 2 × 20 mm MG 151 cannons with 250 rpg in the wing root Bombs: 1 × 500 kg (1,102 lb) SC 500 bomb (optional) * |
In article , Mitchell Holman
says... Miloch wrote in : https://en.wikipedia.org/wiki/Focke-Wulf_Fw_190 --- https://nationalinterest.org/blog/bu...g-or-zero-was- best-fighter-plane-during-world-war-ii-41382 Story I heard was the success of the 109 left a lot of radial engines piled up in warehouses, with no fugure. Tank was ordered take all these radials and build an airplane around them. A backup to the 109 that everyone thought invincable. The rest of the Luftwaffe inventory were all liquid cooled machines, so he started from an assumption of failure. When the winter of 1941 hit the Russian front and the Fw 190 was the only plane (beside the other radial engine plane, the Ju52) they could get into the air he was vindicated. I've tried twice this morning to upload a 160M video on the history of the FW but Newsguy seems to have a problem with it... It's a youtube vid https://www.youtube.com/watch?v=lBq4aBbPbZ0 It's worth the download if you want more history of the 190. * |
On 2019-01-14 15:28:58 +0000, Miloch said:
https://en.wikipedia.org/wiki/Focke-Wulf_Fw_190 This was a visitor to Paso Robles from "Planes of Fame" back in 2012 at the Warbirds Over Paso show. I shot about 1,600 images that day. -- Regards, Savageduck |
Savageduck wrote in
news:2019011417283629094-Savageduck1@REMOVESPAMmecom: On 2019-01-14 15:28:58 +0000, Miloch said: https://en.wikipedia.org/wiki/Focke-Wulf_Fw_190 This was a visitor to Paso Robles from "Planes of Fame" back in 2012 at the Warbirds Over Paso show. I shot about 1,600 images that day. Great shots, well done. |
In article 2019011417283629094-Savageduck1@REMOVESPAMmecom, Savageduck says...
This is a multi-part message in MIME format. On 2019-01-14 15:28:58 +0000, Miloch said: https://en.wikipedia.org/wiki/Focke-Wulf_Fw_190 This was a visitor to Paso Robles from "Planes of Fame" back in 2012 at the Warbirds Over Paso show. I shot about 1,600 images that day. You seem to be using an NIKON D300S...I'm a big Nikon CoolPix fan with four different models...currently carry an A900 during my daily constitution but my pics are never as good as yours. * |
On 2019-01-15 02:26:44 +0000, Miloch said:
In article 2019011417283629094-Savageduck1@REMOVESPAMmecom, Savageduck says... This is a multi-part message in MIME format. On 2019-01-14 15:28:58 +0000, Miloch said: https://en.wikipedia.org/wiki/Focke-Wulf_Fw_190 This was a visitor to Paso Robles from "Planes of Fame" back in 2012 at the Warbirds Over Paso show. I shot about 1,600 images that day. You seem to be using an NIKON D300S...I'm a big Nikon CoolPix fan with four different models...currently carry an A900 during my daily constitution but my pics are never as good as yours. Yup! That was my Nikon D300S. However, I haven't used it in over 18 months, as I have made a move to Fujifilm with my current workhorse an X-T3. Sorry no FW190 shot with that, but here PoF had their P-38L at the 2018 Santa Maria Air Show. -- Regards, Savageduck |
On Mon, 14 Jan 2019 17:28:36 -0800, Savageduck
wrote: This the honest-to-gosh retsored FW-190A owned and operated by the Flying Heritage Combat Armor Museum at Paine Field, WA. |
| Thread Tools | |
| Display Modes | |
| Focke-Wulf Fw 187 pics 2 [6/6] - focke-wulf-fw-187-falke-1940-CPJF98.jpg (1/1) | Miloch | Aviation Photos | 0 | November 8th 18 04:03 PM |
| Focke-Wulf Fw 187 pics 2 [5/6] - focke-wulf-fw-187-falke-1940-CPJF9B.jpg (1/1) | Miloch | Aviation Photos | 0 | November 8th 18 04:03 PM |
| Focke-Wulf Ta 154 pics 2 - focke-wulf-ta154-moskito-4-3.jpg ... | Miloch | Aviation Photos | 0 | May 31st 18 02:19 PM |
| Focke-Wulf Ta 154 pics [8/9] - focke-wulf-ta-154a-0-moskito.png (1/1) | Miloch | Aviation Photos | 0 | May 31st 18 02:18 PM |
| Focke-Wulf Fw 190 pics [09/20] - focke-wulf-fw-190a-wallpapers.jpg (1/1) | Miloch | Aviation Photos | 0 | June 28th 16 04:07 PM |
