Tow plane types/mods for high density altitude glider towing
Old August 13th 19, 04:38 AM posted to rec.aviation.soaring
son_of_flubber
Default Tow plane types/mods for high density altitude glider towing
On Monday, August 12, 2019 at 11:04:05 PM UTC-4, Papa3 wrote:
They used to have 450hp Stearman at Stroudsburg. It wasn't a tow so much as being dragged vertically into the air.
P3
I once saw Jim Parker take off and tow a glider behind a Pitts Special... at 100 knots. They towed XC to an air show.
Old August 13th 19, 05:14 AM posted to rec.aviation.soaring
[email protected][_1_]
Dennis Tito tows with a turbine Cessna 206 or 207. Perlan is using a turbine Grob. I have towed behind a turbine Ag Cat. Agree on the “being dragged skyward” comment. Was at 2K agl at the end of the runway..
I Have towed a loaded SGS 2-32 and loaded Janus out of Aspen, CO dozens of times with a 180 Cub. Not recommended.....
The 260 and 235 Pawnee, C-188, or big engine 182, 180, 185 have all worked well at Ely and Parowan and other high desert sites for decades.
Old August 13th 19, 11:21 AM posted to rec.aviation.soaring
James Metcalfe
At 08:07 13 August 2019, Peter F wrote:
I've seen a tow behind a Pilatus Turboporter at Gap Tallard
I've *had* a tow behind a Pilatus at Gap-Tallard. My pupil had no trouble
flying the 2-seat glider ... but the Pilatus pilot (disappointingly?) used
significantly reduced power!
Old August 13th 19, 07:57 PM posted to rec.aviation.soaring
Frank Whiteley
On Monday, August 12, 2019 at 7:38:43 PM UTC-6, son_of_flubber wrote:
What are your favorite aircraft types (and modifications) for glider towing in high density altitude and/or short runways?
Mark Keene once told me about towing with one of these at Uvalde making a 2000ft tow and return in under three minutes. https://en.wikipedia.org/wiki/SIAI-Marchetti_SM.1019
28 variants on the US registry.
Frank Whiteley
Old August 13th 19, 08:42 PM posted to rec.aviation.soaring
Frank Whiteley
I towed behind Mark in my '28. We had 2000 feet in 1:40. He told me he was using 40% power.
UH
Old August 13th 19, 09:39 PM posted to rec.aviation.soaring
Frank Whiteley
Frank Whiteley
UH
Now that I think about it, I believe Mark said his tow cycle time was 2.5 minutes. Must have been an interesting view from the glider;^)
Frank
Old August 13th 19, 09:08 PM posted to rec.aviation.soaring
JS[_5_]
Regarding mods, the eTug deserves mention.
A Pawnee with a 350 cubic inch Chevy LS1 running on Mogas. Early experiments provided too steep a climb angle, so the original 4-blade prop was adjusted to decrease the climb rate. Now it has a different prop.
I've hooked many gliders up to eTug, yet to tow behind it.
https://www.glidingclub.org.au/membe...aircraft/etug/
These days a crate LS3 engine can be purchased for about $8000 and produces 430HP on Mogas. Car engines require a PSRU (speed reduction).
https://www.gmperformancemotor.com/p... AhPlEALw_wcB
Not much concern about shock cooling or leaded Avgas going away.
Old August 13th 19, 09:25 PM posted to rec.aviation.soaring
Nigel Pocock[_2_]
prop
produces
https://www.gmperformancemotor.com/parts/19370416.html?
gclid=Cj0KCQjwv8nqBRDGARIsAHfR9wC30A7wF3SFSrhYOBoL dkinr_7M
GZMpHxignUEhA1qfW5iBSSEbHwAaAhPlEALw_wcB
A Zlin Z-137t would seam to do the job. This is turbine powered and
there is a video on U tube of one towing 9 x L13 Blanics in one tow.
Old August 14th 19, 03:33 PM posted to rec.aviation.soaring
Dan Marotta
That is super!
Was there any difficulty with your CAA or was the GFA authorized to make
those mods?
Dan, 5J
Perlan High Altitude Tow Plane Frank Whiteley Soaring 32 August 25th 18 01:32 PM
Martin B-57 Canberra pics [19/20] - NASA High Altitude Plane.jpg (1/1) Miloch Aviation Photos 0 August 26th 16 12:34 AM
High Altitude simulator accuracy in X-Plane Ghazan Haider Simulators 2 August 16th 05 06:01 PM
Pressure Altitude or Density Altitude john smith Piloting 3 July 22nd 04 10:48 AM
Copyright 2004-2025 AviationBanter.
