Tow plane types/mods for high density altitude glider towing
Old August 14th 19, 05:34 PM posted to rec.aviation.soaring
Craig Funston[_3_]
Default Tow plane types/mods for high density altitude glider towing
On Wednesday, August 14, 2019 at 7:33:57 AM UTC-7, Dan Marotta wrote:
That is super!
Was there any difficulty with your CAA or was the GFA authorized to make
those mods?
On 8/13/2019 2:08 PM, JS wrote:
Regarding mods, the eTug deserves mention.
A Pawnee with a 350 cubic inch Chevy LS1 running on Mogas. Early experiments provided too steep a climb angle, so the original 4-blade prop was adjusted to decrease the climb rate. Now it has a different prop.
I've hooked many gliders up to eTug, yet to tow behind it.
https://www.glidingclub.org.au/membe...aircraft/etug/
These days a crate LS3 engine can be purchased for about $8000 and produces 430HP on Mogas. Car engines require a PSRU (speed reduction).
https://www.gmperformancemotor.com/p... AhPlEALw_wcB
Not much concern about shock cooling or leaded Avgas going away.
Dan, 5J
Akaflieg Stuttgart just flew their concept of an optimized towplane. Congratulations to all the students and their mentors.
https://akaflieg.hg.stuvus.uni-stutt...EvgsGCyBGeZLCI
Craig
Old August 14th 19, 06:03 PM posted to rec.aviation.soaring
John Foster
That is super!
those mods?
Dan, 5J
Craig
That looks promising. Now to make them "affordable".
Old August 14th 19, 06:33 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
That is super!
make those mods?
prop.
reduction).
https://www.gmperformancemotor.com/parts/19370416.html?
gclid=Cj0KCQjwv8nqBRDGARIsAHfR9wC30A7wF3SFSrhYOBoL dkinr_7MGZMpHxignUEhA1qfW5iBSSEbHwAaAhPlEALw_wcB
Dan, 5J
https://akaflieg.hg.stuvus.uni-stutt...erstflug-fs35-
harpyie/?
fbclid=IwAR1rgq8zp1xdRFvQTqvAQGbklVeiF76CE0bKvKbdx jlFvEvgsGCyBGeZLCI
I remember a couple of specialist tow planes appearing a few years ago,
apparently to disappear without trace a bit later. One came from an
Akaflieg and was dual purpose: two seat aerobatic aircraft and tow-plane.
The other was from the Finnish Akaflieg equivalent - the PIK-27.
Are either in use as tow-planes now?
Has more than the prototype of either type been built?
Martin | martin at
Gregorie | gregorie dot org
Old August 15th 19, 04:39 AM posted to rec.aviation.soaring
JS[_5_]
That is super!
those mods?
Dan, 5J
The original LS1-mod Pawnee, VH-CUR is EXP. Don't think they've certified one yet.
Old August 14th 19, 03:26 PM posted to rec.aviation.soaring
Dan Marotta
Leave it to the Italians.Â* A Bird Dog with panache!
On 8/13/2019 12:57 PM, Frank Whiteley wrote:
On Monday, August 12, 2019 at 7:38:43 PM UTC-6, son_of_flubber wrote:
What are your favorite aircraft types (and modifications) for glider towing in high density altitude and/or short runways?
Mark Keene once told me about towing with one of these at Uvalde making a 2000ft tow and return in under three minutes. https://en.wikipedia.org/wiki/SIAI-Marchetti_SM.1019
28 variants on the US registry.
Frank Whiteley
Dan, 5J
Old August 15th 19, 05:44 PM posted to rec.aviation.soaring
Bob Youngblood
The C-188 300 constant speed prop is a great towplane. I am already planning to make one my next project.
Old August 15th 19, 09:35 PM posted to rec.aviation.soaring
Don't do it if you have neighbors. Second loudest tug I've seen, behind only a 650 Agcat.
UH
Old August 15th 19, 09:57 PM posted to rec.aviation.soaring
Hmmmm.....not sure if our field.....remember a short time tug that was great, but maybe 75% throttle lit up the local PoPo....
Yeah.....not many tows, but they were fun......
Old August 16th 19, 02:20 AM posted to rec.aviation.soaring
eTugs are now certified in Australia and are in production. Tow costs are half avgas powered PA25 - 235 tugs.
Michael
Old August 16th 19, 03:59 AM posted to rec.aviation.soaring
Craig Funston[_3_]
Michael
Michael, are they producing a two seat version of the eTug?
Cheers,
Craig
Perlan High Altitude Tow Plane Frank Whiteley Soaring 32 August 25th 18 01:32 PM
Martin B-57 Canberra pics [19/20] - NASA High Altitude Plane.jpg (1/1) Miloch Aviation Photos 0 August 26th 16 12:34 AM
High Altitude simulator accuracy in X-Plane Ghazan Haider Simulators 2 August 16th 05 06:01 PM
Pressure Altitude or Density Altitude john smith Piloting 3 July 22nd 04 10:48 AM
