Having landed a 1-26 in a place local hang glider pilots said was that unlandable (one HG pilot showed up at our field, having his kidlets learn, he mentioned, I stated as fact since I was the 1-26 pilot involved), yes a ASW-20a in "full dump it mode" (landing flap, full brakes) has a L/D of a homesick brick.....
Good planning allows a lot of glass ships into small places....what do you practice? A 20-a can go into very small spots, a 20-c needs a bit more. VERY sharp in a no -flapped ship......sorry, not the same.... General flying, nut behind the stick is likely 85% of the equation, forget flaps unless high speed or short off field. |
Trying to get back to your original question, while it is important to
remember that there are considerable differences between different gliders (and generations of glider) some of the practical differences that you might encounter include: (1) Increased workload on the ground run (some flapped gliders need a change from negative to positive flaps to prevent a wing dropping) (2) Easier unstick once in a positive flap setting. Only really a factor if launching from a short airfield or behind a low power tug. (3) Lower thermaling speeds, particularly when heavy (so generally better climb rates) (4) Reduced roll control in positive flap settings, particularly in older designs. This can be a factor when manoeuvring in a busy thermal and/or lower down. In my experience not a major factor in more modern types (4) Higher workload in flight (you need to consider what flap setting you need) (5) Steeper approach attitude, so better visibility and potential to land shorter (very type specific) (6) Increased workload on the landing run (some, particular older, flapped gliders need a move to negative flap on the ground run to maintain roll control Some are positive, some negative, but if used properly, you will definitely get a performance benefit on most cross country days, provided you get the flap settings right. The price of the performance increase is a higher workload. In my view, whether this trade off is worthwhile is sometimes as much about you and your capacity/experience as the other factors. |
More flaps? | WingFlaps | Piloting | 36 | May 26th 08 07:33 AM |
flaps again | Kobra | Piloting | 107 | January 5th 08 04:31 PM |
flaps | Kobra[_4_] | Piloting | 84 | July 16th 07 06:16 PM |
flaps | Kobra[_4_] | Owning | 85 | July 16th 07 06:16 PM |
FLAPS | skysailor | Soaring | 36 | September 7th 05 05:28 AM |
