#91
Steven P. McNicoll wrote:
But if you fly IFR or use flight following you'll get an altimeter setting when you check in with a new controller. Understood. I don't have an instrument rating and didn't get far enough on that training to have run into this. I have a personal dislike of flight following, so I don't take advantage of this service. George Patterson There's plenty of room for all of God's creatures. Right next to the mashed potatoes. |
#92
aaronw wrote:
When I've asked for a Bravo clearance, and they have to check with another controller, they'll sometimes come back with something like the above... Just directions that would be take me into the Bravo without the explicit 'cleared into the bravo'. I'll usually read those back with 'understand cleared into the bravo' appended to the end so there is no mistaking things. Good idea. I'll remember that if I get in that situation again. George Patterson There's plenty of room for all of God's creatures. Right next to the mashed potatoes. |
#93
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1 A Lieberman wrote: On Sat, 07 May 2005 02:02:40 GMT, George Patterson wrote: Since I am quoting the regulations, I'd suspect that your New York ATC folks may want to take a look at the above ATC chapter. Climbing instructions you received is clearly not a clearance into Bravo airspace. You absolutely must hear the words Cleared into Bravo. It's required that ATC clears you AND you are required to read back this clearance. Thank you. This is EXACTLY what I've been trying to get at all along in this thread. You *MUST* hear 'Cleared into Class Bravo Airspace' to be allowed to enter Bravo airspace. That is your clearance into it. Even the FARs state it: Sec. 91.131 - Operations in Class B airspace. (a) Operating rules. No person may operate an aircraft within a Class B airspace area except in compliance with ?91.129 and the following rules: (1) The operator must receive an ATC clearance from the ATC facility having jurisdiction for that area before operating an aircraft in that area. Some people just fail to understand that. Even more than that, if they tell you to remain outside of Bravo airspace, or any airspace, and give you a reason, pilots are requested to read that back. ATC is going to expect a readback. If not, they will repeat it. If no readback is given, they aren't going to *ASSUME* anything. They aren't going to think 'oh, he heard it, let me worry about separating my aircraft flying into JFK, LAS', or any major field, they are going to get that readback from you, or send up the F18s to escort you down/shoot you down, depending on how grave the situation is. Class C, on the other hand, requires 2-way comunication. When that is established, unless told otherwise, you have clearance through Class C airspace. If ATC tells you to not enter it, for whatever reason, you don't enter it. In short, once again, if the 2-way communication is established between pilot and ATC, the clearance into/through Class C airspace is implied, and pilots may fly through. BL. - -- Brad Littlejohn | Email: Unix Systems Administrator, | Web + NewsMaster, BOFH.. Smeghead! ![]() PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.1 (GNU/Linux) iD8DBQFCfaenyBkZmuMZ8L8RAo8mAJ0YD2GknK74PvdX7Cm/K8rJKChdewCfabzG jEXlfKI0s5Qsa7EN0TXr5I0= =g9hJ -----END PGP SIGNATURE----- |
#94
"George Patterson"
Understood. I don't have an instrument rating and didn't get far enough on that training to have run into this. I have a personal dislike of flight following, so I don't take advantage of this service. Lordy, why? VFR in low ceilings means that almost everyone is flying just below the clouds. Why wouldn't you want to have flight following in those conditions? It's free. What's the issue? moo |
#95
![]() I often listen to the tower at Pease tradeport (and National Guard base) across the bay. Professional pilots regularly thank the tower, and routinely say "G'day" upon departing the Delta airspace. If I am flying through the airspace low and slow for a tour of Great Bay, I call upon leaving the Class D to give my position and altitude and to say "Thank you Pease!" Perhaps things are more formal in Charlie airspace; I don't know. -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net In Search of Lost Time: www.readingproust.com |
#96
On Sat, 07 May 2005 20:48:12 GMT, "Steven P. McNicoll"
wrote: Correct, unless otherwise indicated. Some control zones require Mode C. We don't have control zones in the US, haven't had them for almost twelve years now. When we did have them none of them required Mode C. Well, we have Mode C zones! There's a big ring around Boston that I generally avoid, though I am legal to fly through it without a transponder. -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net In Search of Lost Time: www.readingproust.com |
#97
On Sat, 07 May 2005 21:23:35 GMT, "Steven P. McNicoll"
wrote in et:: "Happy Dog" wrote in message ... As I said in a previous post, I'm from Canada. You'd probably do well to make that distinction when you post. Mr. Dog does make his location reasonably known. If you look at the 'From' header of his articles: From: "Happy Dog" You'll note the domain of his e-mail address is: sympatico.ca You're probably aware that '.ca' domain names indicate their location to be Canada. |
#98
On Sun, 08 May 2005 02:32:08 GMT, George Patterson
wrote in ISefe.3205$EC6.1616@trndny06: I have a personal dislike of flight following, so I don't take advantage of this service. The thought of ATC's intrusion into the reverie of our aerial operations is displeasing. But anyone who fails to avail themselves of Radar Traffic Advisory Service in the Los Angeles basin just doesn't appreciate the magnitude of aerial congestion in the vicinity. I have a personal dislike for scanning for traffic, but it is preferable to a MAC. |
#99
Cub Driver wrote:
On Sat, 07 May 2005 20:48:12 GMT, "Steven P. McNicoll" wrote: Correct, unless otherwise indicated. Some control zones require Mode C. We don't have control zones in the US, haven't had them for almost twelve years now. When we did have them none of them required Mode C. Well, we have Mode C zones! There's a big ring around Boston that I generally avoid, though I am legal to fly through it without a transponder. The Mode C veil existed at the same time control zones existed. When the airspace was "alphabetized" the term control zone was deleted in lieu of the term "surface area of controlled airspace designated for an airport" (which is pretty close to the old definition of the control zone with a lot of the flaky differences removed). |
#100
ink.net Altimeter settings don't tend to vary a great deal from one controller to the next. If you're issued one that differs by more than a few points from the previous then it's a good idea to check on it. This is true. However, one of the exceptions I remember was back when the remains of hurricane/tropical storm Ivan were rumbling around my flight path. The low pressure system definitely caused a very significant change in altimeter settings from one sector to the next - so much so that I thought I misunderstood her call the first time. ![]() -- John T http://tknowlogy.com/TknoFlyer http://www.pocketgear.com/products_s...veloperid=4415 ____________________ |
What F-102 units were called up for Viet Nam | Tarver Engineering | Military Aviation | 101 | March 5th 06 03:13 AM |
