If all midair collisions were eliminated...
Old February 9th 10, 07:05 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.soaring
Jim Logajan
Default If all midair collisions were eliminated...
If all GA midair collisions were eliminated, ~99% of GA aircraft fatalities
would still happen.
From Nall Report analysis of U.S. NTSB records:
Total fixed wing GA fatalities:
2002: 518
2003: 555
2004: 510
2005: 491
2006: 488
Total: 2562
Fatalities due to midair collision:
2002: 5
2003: 7
2004: 6
2005: 5
2006: 4
Total: 27
http://www.aopa.org/asf/publications/03nall.pdf
http://www.aopa.org/asf/publications/04nall.pdf
http://www.aopa.org/asf/publications/05nall.pdf
http://www.aopa.org/asf/publications/06nall.pdf
http://www.aopa.org/asf/publications/07nall.pdf
Old February 10th 10, 12:59 AM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.soaring
Mxsmanic
Jim Logajan writes:
would still happen.
If all GA midair collisions were eliminated, 27 people would still be alive,
based on your own cited statistics. Is saving lives not a sufficient
justification for eliminating midair collisions? Is there are threshold of
deaths below which efforts to eliminate midair collisions are not justified?
What cost is there in attempting to eliminate midair collisions that offsets
the loss of life that they entail?
Old February 10th 10, 01:41 AM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.soaring
cavelamb[_2_]
Mxsmanic wrote:
Jim Logajan writes:
would still happen.
Oh man...
Excuse me for biting a troll, guys.
mx?
Exactly HOW do you think you can prevent ANY midair?
The ONLY way I can see is to ground everybody.
That'd work!
Richard Lamb
http://www.home.earthlink.net/~cavelamb/
"The clock of life is wound but once, and no man has the power
to tell just when the hands will stop, at late or early hour...
Now is the only time you own. Live, love, toil with a will.
Place no faith in time. For the clock may soon be still."
Old February 10th 10, 11:02 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.soaring
Mxsmanic
cavelamb writes:
Training, standardization, caution, discipline, and other techniques can
greatly reduce the incidence of midair collisions.
Old February 11th 10, 12:15 AM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.soaring
cavelamb[_2_]
Mxsmanic wrote:
cavelamb writes:
Well, if you have been following the other posts in this thread
you'd understand that they already ARE doing just that.
Richard Lamb
Old February 11th 10, 12:32 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.soaring
Mxsmanic
cavelamb writes:
Yes. Who said otherwise?
Old February 11th 10, 04:58 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.soaring
Harry K
On Feb 10, 4:15*pm, cavelamb wrote:
Mxsmanic wrote:
cavelamb writes:
Richard Lambhttp://www.home.earthlink.net/~cavelamb/
Place no faith in time. *For the clock may soon be still."
Not only doing it but have done it down to the point of not only
_diminishing_ returns but almost zero additional benefit.
Harry K
Old February 10th 10, 01:57 AM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.soaring
Westbender
On Feb 9, 6:59*pm, Mxsmanic wrote:
Jim Logajan writes:
would still happen.
Where exactly in his post did he suggest we should be satisfied with
low numbers of fatalities due to mid-air collisions?
I find that information extremely interesting and I'm glad he posted
it. Thanks Jim!
Old February 10th 10, 07:11 AM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.soaring
Matt Herron Jr.
I also find this interesting. I wonder if the ratio of 100/1 would be
the same if one only considered glider-involved accidents. My guess
is we have a disproportionate number of mid-airs. Any way to check?
Matt
Old February 10th 10, 07:55 AM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.soaring
Darryl Ramm
On Feb 9, 11:11*pm, "Matt Herron Jr." wrote:
I also find this interesting. *I wonder if the ratio of 100/1 would be
the same if one only considered glider-involved accidents. *My guess
is we have a disproportionate number of mid-airs. *Any way to check?
Matt
Matt
You can do the research...
http://www.ntsb.gov/aviationquery/index.aspx
You can select on Injury Severity and Category (Glider, etc.). Play
with trying "collision" etc. in the event details box (but obviously
you need to check the results/misses).
Darryl
Mid Air Collisions Sukumar Kirloskar Soaring 2 July 3rd 08 02:42 PM
FAA Soaring Forecasts being eliminated? David Neptune Soaring 6 July 15th 06 05:47 AM
Kids and Aviation records. I thought these were supposed to be eliminated. Roger Halstead Piloting 2 September 27th 04 07:20 PM
Mid-Air Collisions JJ Sinclair Soaring 26 April 19th 04 08:52 AM
MID AIR COLLISIONS Vorsanger1 Soaring 2 April 16th 04 04:17 AM
