#91
Michael wrote:
ospam (Rosspilot) wrote So what are you saying? A plane flying in clouds has to be high-performance to be safe? What? A plane flying in clouds at subfreezing temperatures DOES have to be high performance to be reasonably safe. A low performance airplane will fall out of the sky too quickly when the ice starts building. Well, I found out one evening flying past Lake Erie that a Skylane will carry at least an inch of ice on the leading edge and struts and still fly very well ... just a little bit on the slow side. :-) It didn't "fall out of the sky", but I did have to descend from 11,000 to 9,000 before I could hold altitude with full throttle and the carb heat on (the air intake froze over almost immediately upon the ice encounter). Matt |
#92
![]() Steven Barnes wrote: I had an avionics guy tell me that my VOR head (localizer only, no GS) could be used if we added a GPS. A switch to toggle from receiving from VOR head or GPS would do it. That right? I have heard that that is sometimes the case. Depends on the VOR head and GPS. Do you have a NARCO VOR head? If so, that means mine might work that way, though mine has the GS needle. George Patterson If you want to know God's opinion of money, just look at the people he gives it to. |
#93
"G.R. Patterson III" wrote in message
... Steven Barnes wrote: I had an avionics guy tell me that my VOR head (localizer only, no GS) could be used if we added a GPS. A switch to toggle from receiving from VOR head or GPS would do it. That right? I have heard that that is sometimes the case. Depends on the VOR head and GPS. Do you have a NARCO VOR head? If so, that means mine might work that way, though mine has the GS needle. George Patterson If you want to know God's opinion of money, just look at the people he gives it to. Hmmm. It's a Bendix/King indicator hooked up to a 155. I can't remember the exact type. Books are at the airport. Looks like the more in-expensive way in is the Garmin 155XL. Although, I just did a bit of looking at the KLN94. Looks nice. Used is fine. Heh, used will probably be required to be affordable. |
#94
![]() Steven Barnes wrote: Heh, used will probably be required to be affordable. Yep. George Patterson If you want to know God's opinion of money, just look at the people he gives it to. |
#95
carry at least an inch of ice on the leading edge and struts and still fly very well ... just a little bit on the slow side. :-) It didn't "fall out of the sky", but I did have to descend from 11,000 to 9,000 before I could hold altitude with full throttle and the carb heat on (the air intake froze over almost immediately upon the ice encounter). I picked up about an inch of ice climbing out of Burlington, VT one April day in a rented Archer. Ice on windscreen and leading edge . . . plane simply stopped climbing at 6000 and tops were at 8. I could not get above it, and had to return to field which was 20 miles away. Wasn't sure I had time for a full approach so I took a radar surveillance approach and got down ok, but I could not see out the front--had to land looking out the side. It was one of those times I was pretty scared. www.Rosspilot.com |
#96
#97
Matt Whiting wrote
Well, I found out one evening flying past Lake Erie that a Skylane will carry at least an inch of ice on the leading edge and struts and still fly very well ... just a little bit on the slow side. :-) I concur. Do you believe you would have had the same result with a Skyhawk? I think you know better. It didn't "fall out of the sky", but I did have to descend from 11,000 to 9,000 before I could hold altitude with full throttle and the carb heat on (the air intake froze over almost immediately upon the ice encounter). Right. You had the engine power to cope with the (far from uncommon) conditions. A Skyhawk or Cherokee 140 would not. A Hawk XP or Archer probably would. A Skylane or Cherokee 235 definitely does. Thus my point - in a non-deiced high performance airplane, you can stick your nose in. There is still some risk, but it's a lot less than the risk of doing the same thing in a low performance airplane. On the other hand, the low performance airplane is likely slower, and thus can fly low VFR with a greater margin of safety. Is it such a stretch to believe that with given weather conditions, the choice of airplane determines whether going IFR or low VFR is the safer option? Michael |
#99
![]() Michael wrote: OK, so how much IFR in IMC involves neither subfreezing weather nor T-storms? In my experience, relatively little. Maybe where you are, but here on the northeast coast, we get frontal systems that stall out and won't move until another system comes in and shoves them offshore. The result is about a week of low ceilings and drizzle or rain, maybe fog. The choices are IFR or scud-run. Sometimes only IFR flight is possible. There's no convective activity after the first day and the freezing level (if there is one) is known and constant. This is followed by a few hours of very pretty weather and then all Hell breaks loose. George Patterson If you want to know God's opinion of money, just look at the people he gives it to. |
#100
Instrument Rating Checkride PASSED (Very Long) | Alan Pendley | Instrument Flight Rules | 24 | December 16th 04 02:16 PM |
Get your Glider Rating - Texas | Burt Compton | Aviation Marketplace | 0 | December 1st 04 04:57 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
Enlisted pilots | John Randolph | Naval Aviation | 41 | July 21st 03 02:11 PM |
