#91
C,
You continue to say this even though the manual does not. The manual actually prohibits attempts at normal recovery and requires immediate deployment of the BRS. You're right (how's that?!). I apparently had access to an outdated manual, which said differently. -- Thomas Borchert (EDDH) |
#92
![]() "Matthew Chidester" wrote in message news:rDX4d.16430$He1.12412@attbi_s01... Also he was close on the operation limits and if he was heavy (overloaded) he could have easily gone in a stall/spin including heavy turbulence Why? He was (as has been pointed out in other posts in this thread) almost 3 miles AGL. If he was losing airspeed, point the nose down. Why would he stall? I've been in a lot of turbulence (I live on the Colorado Front Range) and it has never caused the airplane to come close to stall speed. Michael |
#93
Michael 182 wrote:
"Matthew Chidester" wrote in message news:rDX4d.16430$He1.12412@attbi_s01... Also he was close on the operation limits and if he was heavy (overloaded) he could have easily gone in a stall/spin including heavy turbulence Why? He was (as has been pointed out in other posts in this thread) almost 3 miles AGL. If he was losing airspeed, point the nose down. Why would he stall? I've been in a lot of turbulence (I live on the Colorado Front Range) and it has never caused the airplane to come close to stall speed. Michael Well, I can't claim to have ever flown in severe turbulence, but my sense is not that the turbulence causes you to lose airspeed and stall, but that the correct way to handle this situation is to slow down enough that you are likely to stall if a gust is severe enough to stress the airframe. That's not to suggest that you want to end up in a spin, but it seems preferable to stall and spin at altitude then to have parts of the plane get ripped off. If I'm in a thunderstorm I'm going to make sure my airspeed stays below Va. -- David Rind |
#94
exactly you're in a climb for some reason and heavy turbulence hits - woops
late response wrong rudder input you could do it.. not likely but i've flown and climbing at vx or even vy and you hit a gust, stall alarm goes and if you are THAT high - on a hot day you could get in a stall (I think anyway) |
#95
C,
Sounds an awful lot like "won't recover from a spin and has never demonstrated recovery from a spin" to me. Well, that's a world apart from your earlier categorical statement. Elegant retreat, though. -- Thomas Borchert (EDDH) |
#96
Javier,
B) It's being spun again for certification overseas. Where? In Europe, it is now certified with the chute. -- Thomas Borchert (EDDH) |
#97
C,
Who says I am anti-Cirrus? ROFL. The Cirrus manual says the airplane cannot recover from a spin except by deploying CAPS. Again: It does in NO WAY say that. -- Thomas Borchert (EDDH) |
#98
"C J Campbell" wrote in message
... "Spins The SR22 is not approved for spins, and has not been tested or certified for spin recovery characteristics. The only approved and demonstrated method of spin recovery is activation of the Cirrus Airframe Parachute System (See CAPS Deployment, this section). Because of this, if the aircraft "departs controlled flight," the CAPS must be deployed." I figure that's like saying "The maximum demonstrated crosswind is 17 knots. Because if this, you must not land in crosswinds of greater than 17 knots". Ok, there's the "must not" bit and the "approved bit" but saying "Don't do it" is not the same as saying it can't be done. There's been a big debate about the spin characteristics of my plane, the Scottish Aviation Bulldog. It can get into a mode where it is very difficult to recover using "normal" or "recommended" techniques. It was found by one of the former British aerobatic champions that giving a blip of throttle made the plane recover from this type of spin pretty much immediately. A large outcry followed saying this wasn't approved technique and non-standard recoveries should not be attempted, etc. The RAF "thou shalt" if the plane got into this mode of spin was to jetison the canopy and jump out. Paul |
#99
... "Spins The SR22 is not approved for spins, and has not been tested or certified for spin recovery characteristics. The only approved and demonstrated method of spin recovery is activation of the Cirrus Airframe Parachute System (See CAPS Deployment, this section). Because of this, if the aircraft "departs controlled flight," the CAPS must be deployed." OK, well, from the JAA certification testing: Results. The aircraft recovered within one turn in all cases examined. Recovery controls were to reduce power, neutralize ailerons, apply full rudder opposite to spin, and to apply immediate full forward (nose down) pitch control. Altitude loss from spin entry to recovery ranged from 1,200 to 1,800 feet. Detail results can be found in the above referenced reports. The "above referenced report" is a largish pdf file you can download from, among other places, the COPA website. -jav |
Cirrus Deploys Chute Safely | m alexander | Home Built | 40 | September 28th 04 12:09 AM |
Cirrus SR22 Purchase advice needed. | C J Campbell | Piloting | 122 | May 10th 04 11:30 PM |
Another Cirrus BRS deployment: | Dan Luke | Piloting | 111 | April 19th 04 04:34 AM |
Cirrus BRS deployment | Dan Luke | Piloting | 37 | April 14th 04 02:28 PM |
New Cessna panel | C J Campbell | Owning | 48 | October 24th 03 04:43 PM |
