TOW PLANE Accident
Old March 19th 19, 07:40 PM posted to rec.aviation.soaring
Default TOW PLANE Accident
On Wednesday, February 20, 2019 at 7:58:56 AM UTC-8, Paul Agnew wrote:
NTSB Report
https://www.ntsb.gov/_layouts/ntsb.a...FA006 &akey=1
Final report:
https://app.ntsb.gov/pdfgenerator/Re...Final&IType=FA
  #92
Old March 19th 19, 11:54 PM posted to rec.aviation.soaring
Someone died....sucks for the reason......truley......
As to high tow vs. low tow.....I have my preference, but will wait until REAL NUMBERS show a difference.
I will NOT say the US needs to go low tow (again, I am biased....), I will wait on numbers.
I shall say, many peeps I have flown with are improperly trained on low tow......sorta described by posts in this thread.
Yes, as mentioned by some peeps (posted or to me via email/PM), "out of control is out of control....".
I agree with out of control.......
I am out of "keeping a fine eye" on tow, but one comment I had was......."who the F makes a glider (mostly SGS-xx) that climbs on tow?
Frankly....(waiting until we fly in the NE US....)....I will pay for tows in.......
SGS-2-33
SGS-1-26
ASK-21
ASW-2xxx
My thought......is there enough forward trim to maintain EITHER tow position?
Frankly, from what I vaguely remember......a thumb behind the stick on ANYTHING is enough to maintain vertical position.
A "death grip" on the stick blows out many minor sensor inputs to correct tow flying......
I am waiting until our club flies.....I will pay for tows in quite a few ships to see.......I will report back.......
If nothing else, I learn something.......
Maybe everyone will learn something.......
As stated before.....this conversation is a ****ing match, until hard numbers, still a ****ing match...
  #93
Old March 20th 19, 01:31 AM posted to rec.aviation.soaring
On Tuesday, March 19, 2019 at 7:54:52 PM UTC-4, Charlie M. (UH & 002 owner/pilot) wrote:
It may be different for heavier pilots than me, but with me solo in the 2-33, even with the ballast brick (can't fly without it), and of course with the trim full forward, I still need to push the stick forward on tow so hard that I use both hands. That is a situation that can turn tragic in a moment of distraction. Even with another person of my weight in the other seat it still requires a major stick-forward force.
  #94
Old March 20th 19, 01:56 AM posted to rec.aviation.soaring
On Wednesday, March 13, 2019 at 8:15:43 PM UTC-4, Charlie Quebec wrote:
T8 You’ve made it perfectly clear you will stick to your view, regardless of the obvious extra risk you put your tow pilots in. Ive read plenty thanks and the facts are clear to me,
as are the physics. Let’s put it really simply for you, we don’t have kiting incidents from low tow. Even you should understand that..
T8 is a switched on pilot and very safety conscious. I find it funny when online pilot opinions differences devolve into accusations of the 'obviously wrong' pilot being an unsafe cowboy.
As for the original question does cracking a whip from a lower position give you more time to stop the resulting force? And wouldn't you end up with more total energy in a whip cracked from a lower position? Is it even possible to uncrack a whip once energy input has reached a certain level?
  #95
Old March 20th 19, 12:09 PM posted to rec.aviation.soaring
RR
My takeaway from this mostly useful discussion is:
Low tow might provide an air "rumble strip" as the pilot is losing position, "wake him up" (pun intented) before he gets too far out of position.
I dont think these accidents are caused by a winch style rotation to the kite, but more a lack of attention that by the time it is detected, you are too far out of position (or control) to recover. A "stick shaker" at the very start of the event, might well prevent most of these accdents.
Well that and T8 is a cowboy, I have seen him in leather boots ;-)
RR
  #96
Old March 20th 19, 04:24 PM posted to rec.aviation.soaring
Tango Eight
It's worth trying to understand these accidents and being ware of "solutions" that don't address the root cause. I think I've worked harder on this than many, so I'll share my summary. For those that don't know me, I've been instructing for 3 years and have about 2000 hours in gliders and towplanes since 1986. I am not timid (thanks Rick :-)).
The Skyline accident is an outlier. Video evidence shows that the glider deck angle never gets out of normal limits. It was not a kiting event. However, it's perfectly clear that the glider PIC lost situational awareness for several seconds and left the normal tow position at very low altitude (~200' iirc). The video + audio suggest that it is likely that the towplane's elevator authority was compromised before tow separation. Although this cannot be established with certainty, we do know that the tow line angle was unusually steep and that the tension became high enough to break the rope without a slack line event. I'll bet a year's worth of tow fees you can't break a rope in this manner without compromising the tug.
The similar accident I am aware of is the Sugarbush takeoff accident in 1999.
It's similar to the Skyline accident in that it involves a reasonably experienced pilot in a modern nose hook equipped glider giving in to a cockpit distraction on departure (open canopy) and allowing the glider to fly well outside normal positional limits. It's unclear to me if this became a kiting event or not, but it's clear that the towplane's elevator authority was badly compromised. Observers stated that the tow rope was "vertical" prior to separation. The towplane was forced into the ground and came to rest inverted.
We don't have an easy way to collect statistics on the gliders involved in upset accidents and incidents. The glider type is generally not mentioned in an accident report concerning a towplane, unless the glider is also wrecked. The anecdotes I know of suggest it's most often Schweizer iron, with the 2-33 figuring prominently. The anecdotes generally suggest a kiting event as described in the work of Rollings, et al.
It's easy to see why. The stick pressure on tow cannot be trimmed out in any 2-33 I've flown. The forward stick force required to maintain formation with the tug is substantial. The departure from normal tow position (high or low, doesn't matter), should you momentarily release forward pressure for any reason, will be extreme and potentially catastrophic for the tow pilot.
  #98
Old March 20th 19, 06:38 PM posted to rec.aviation.soaring
son_of_flubber
What is Glider Deck Angle?
  #99
Old March 20th 19, 07:44 PM posted to rec.aviation.soaring
Dan Marotta
It's like the angle of the floor or the water line.* Basically
level(ish) flight.
Dan, 5J
  #100
Old March 21st 19, 02:54 PM posted to rec.aviation.soaring
Ernst
On Wednesday, March 20, 2019 at 11:24:28 AM UTC-5, Tango Eight wrote:
This an important discussion and I can agree with a lot of the statements being made.
But I also get the feeling that there is some resignation. These are preventable accidents as longs as there are no mechanical or pilot incapacitation issues.
In response to some of Evan’s statements:
Unfortunately, no.
Yes, but there was no recording when the glider got out of normal tow position, because the camera was off and the PIC got distracted checking on it and switching it on again.
You can quickly get out of normal tow position without “kiting”.
The fact is, these accidents are rare.
Unfortunately, no.
Here is a list of tow plane upset accidents from the NTSB database going back to 2000 (which I could find):
26 Apr 2002, PA 18-150, SGS 2-33, USAFA, Colorado Springs, CO (DEN02GA039)
[Please go to the docket and read the PIC’s written testimony.]
21 Aug 2011, Callair A-9B, SGS 2-33, Marshall, MI (CEN11LA585)
[Tragically, the PIC of the glider was killed in a crash with his Quickie Q200 two months later.]
6 Sep 2014, PA 25-235, SGS 2-33, Warner Springs, CA (WPR14LA367)
As with Walt’s incidents, there are certainly more tow plane upsets that are not ending in a disaster and are never reported. I am aware of a CA 150-150 being pulled nose down by a transition glider pilot with only few solo flights in a glider. The tow pilot could not release the Schweizer hook, the tow rope broke and the tow pilot was able to pull out with only a few hundred feet left.
It was also a SGS 2-33. While I agree that the 2-33 requires a lot of elevator push down on tow, this can’t be the root cause for such events. As with the two accidents discussed here, it happens with other gliders types as well.
The PIC of a glider in tow has to be able to stay consistently in the normal tow position. Flawlessly boxing the wake, not only on a quiet morning or evening, is a good indicator if you can handle abnormal tow positions. And no distractions from cameras, flight computers, passengers, canopy opening, objects falling down and so on, especially below 1,000 ft.
Ernst
Fatal glider/tow plane accident, France Sean F2 Soaring 44 May 22nd 12 07:11 PM
Tow plane / glider accident, Adrian MI? Sean Fidler Soaring 5 August 23rd 11 03:39 PM
F-35: Second test plane powers up, but first plane stays grounded Mike[_7_] Naval Aviation 1 October 29th 07 09:40 PM
Float Plane Accident Mike Schumann Piloting 8 October 31st 06 05:15 PM
Walmart heir dies in light plane accident Allen Piloting 1 June 30th 05 11:01 AM
