Fatal Towplane Accident 5-9-20
Old May 17th 20, 03:10 PM posted to rec.aviation.soaring
Default Fatal Towplane Accident 5-9-20
LOL Jonathan that last part got me laughing, me too lol.
Dan
Old May 17th 20, 03:29 PM posted to rec.aviation.soaring
LOV2AV8
Applebay tow hook used on the Zuni and I've heard of it installed on ASW 20's we I'll not allow a very high kiting excursion.
Randy "AV8"
Old May 17th 20, 06:37 PM posted to rec.aviation.soaring
AS
Wouldn't it be easier to design an electrical detach of tow rope by a button on the stick or throttle. This way the tow pilot decides and it would take a fraction of a second to activate. As stated before, helicopters use both a stick mounted electronic release and a stick mounted Manuel release.. Full disclaimer, I am not a tow pilot, not a mechanic, can afford new tape each time I assemble, and I don't unbuckle to stand up in flight to untangle yaw strings. A few days ago I would have thought that was normal, now I am confused.
Hi Jonathan,
there was an attempt to discuss just a solution like that in the 'KGARS - Kiting Glider Automatic Release System' thread on May 15 but it got buried in the chatter.
I think that an electrically triggered system utilizing a capped switch (uncapped (armed) at the beginning of the launch, capped (secured) after the glider has released) has merits over some complicated self-releasing mechanism with all sorts of electronics, which harbors the potential of inadvertently dumping a glider on the other side of the airport fence. Apply the KISS-principle.
Uli
'AS'
Old May 18th 20, 11:19 AM posted to rec.aviation.soaring
On Sunday, 17 May 2020 09:03:07 UTC+1, John Foster wrote:
On Saturday, May 16, 2020 at 11:26:06 PM UTC-6, Mike Schumann wrote:
On Saturday, May 16, 2020 at 9:44:41 PM UTC-5, wrote:
Matt, great that you have successful patents. I actually have two of my own. But you probably need to answer your own question, namely when is there enough existing technology? The schweizer and tost have been working successfully for more than 60 years with millions of tows to their credit. Maybe the problem is the modern guy behind the stick and not the “antiquated” technology. Maybe the problem needs to be addressed at the source and not put another bandaid on the festering wound. Taking your analogy and applying it to it’s ridiculous conclusion; why have any aviation training at all? Lets just use engineering to solve every problem of airmanship. Folks the problem is not with the metal (tow hitch) it is with the “mental”!
As for operating with no tow hitch at all, let me tell you, there are guys I would be totally comfortable with towing them with the rope tied to my tail spring (been there-done that), and there are others I wouldn’t tow with the most highly engineered “fail safe” contraption you could possibly design.
Accidents like this can happen to anyone, regardless of their training, reputation, or experience. There are all kinds of scenarios that can trigger a kiting event. One particular danger, given the demographics of our glider pilots, is sudden pilot incapacitation, such as having a heart attack or a stroke.
Having an automatic release mechanism sounds like a reasonable safety enhancement that should be relatively doable from a technology perspective. There are number of approaches, including a simple mechacable, co system based on pulling all the way back on the tow plane stick, or some mechanical or electronic mechanism that can detect an upward force on the tow hook that exceeds the elevator authority of the tow plane.
I think a simple mechanical device like a lever arm or cage that extends behind the towplane for a few inches may enhance safety significantly. Something that the tow rope would press against at a particular angle that would activate a lever arm that automatically opens the tow hook and releases the ring. How hard would that be to make? It would be independent of the tow pilot, where if the tow rope under tension pulled at greater than a particular angle to the towplane, it would move the lever back and open the tow hook, releasing the ring.
On Sunday, 17 May 2020 13:23:21 UTC+1, Jonathan St. Cloud wrote:
On Saturday, May 16, 2020 at 9:10:01 AM UTC-7, Rhubarb wrote:
I believe that full up elevator is what the towpilot will instinctively do in a kite siuation. This device will detect that and hopefully not give any false positives
release logic something like:-
1) GPS groundspeed ~60kmh for for ~5 seconds (so its not an engine test)
2) engine throttle ~80% for ~5 seconds (so its a take-off)
3) full up elevator (for more then ~0.2 second to filter out a knock)
when 1) and 2) are satisfied the system is "armed". A low groundspeed or Landing flaps could disarm it
I have chosen a low groundspeed in 1) to accomodate a strong head wind
GPS groundspeed and full elevator are easy to measure. Throttle a little trickier - maybe one could use flaps instead. tweak as necessary
Manual override, arm and disarm switches in the cockpit of course. some LEDs.
a simple embedded CPU costing 1$ can easily handle this and is very reliable. The BOM could be under 50$. This can be built by a hobbyist.
The tricky bit is
* Mounting the sensors
* triggering the release if its not electical
Peter
A parallel discussion has arisen on the UK version of this forum.
There have been some memories of tests at one club years ago, deliberately simulating the problem at a safe height.
One thing that two of us remembered is that the tug pilot said it was impossible to pull the release hard enough to let go the rope.
They swapped out the Schweizer hooks and fitted Tost.
I did a search for Schweizer tow hook, and found this, which graphically explains what that difficulty might have been
https://www.soaringsafety.org/learni...ges/Image20.gi
f
https://www.soaringsafety.org/learni...onnecting.html
Also, a separate comment just above that picture says that sometimes
the ring can go forward and obstruct the release.
I've seen that once, a tug intentionally dropping a rope near the launch point but it didn't fall off. I walked up and found the ring looped forward over the top of the release arm.
In all these discussions about feasibility of designing an automatic release method, first it might be worth reconsidering the tow hook, whether it will let go when the command is issued. Also, will a guillotine definitely work?
Old May 18th 20, 10:35 PM posted to rec.aviation.soaring
Nick Kennedy[_3_]
After reading all the secondary type release options I think I'm with AS.
Either have a Tost Release or a inverted Schweitzer release that could very quickly be operated electrically from a switch on the yoke or control stick..
These kiting accidents happen very fast.
If the Tow pilot IMHO had a electric switch he could actuate by either a button on a switch to dump the rope this could help.
I would imagine it would be fairly easy to engineer a pulling electric solenoid that is attached to the existing release cable, sister-ed on to it. When the tow pilot decides hes had enough, touch the button or slide his hand to activate a switch and release the rope quickly.
Use the existing system your tug has now, just add to it. This system seems so easy maybe I could even build it in a day. Don't try and cut the rope, just release it, very quickly.
Good idea?
Nick
T
Old May 18th 20, 11:11 PM posted to rec.aviation.soaring
2G
Good idea?
Nick
T
A big factor in an electric actuator is the force required to open the tow hook. It will be far more than normal, but how much? And how long of a pull? Solenoids are highly non-linear in their pulling force (it increases geometrically as the gap is reduced). I concluded that a linear actuator would be better. To speed it up just drive it with a higher voltage (it wouldn't have to run for very long). I would junk the Schweitzer hooks altogether and switch to a Tost hook.
Tom
Old May 19th 20, 12:07 AM posted to rec.aviation.soaring
Come to think of it, if one agrees with the energy loss via the tow rope being the main issue, one could have a very reliable mechanical solution.
Mount the hook on a shock-absorbed sled, sled slides back enough, the release is pulled. One might have to be able to tune the compression and spring reloading based on what you're towing, but that's a very reliable solution.
Not sure how many tow-pilots would realize what's happening fast enough.
Old June 5th 20, 03:07 PM posted to rec.aviation.soaring
On Sunday, May 10, 2020 at 7:57:01 AM UTC-7, Paul Agnew wrote:
Very sad to read this tragic news this morning.
http://www.kathrynsreport.com/2020/0...fatal.html?m=1
Comments (anonymous) on the webpage indicate kiting may have been a significant factor.
Sincere condolences to the family of the tow pilot and to the members of the club.
Paul Agnew
Jupiter, FL
This reminds me of the saying "an experienced pilot is one who no longer makes small mistakes".
Old June 5th 20, 07:52 PM posted to rec.aviation.soaring
Tango Eight
Just last year, while acting as ground crew for a winch launch, I watched the PIC announce on the radio "canopy locked, spoilers locked", while the spoilers were quite clearly not locked and not fully closed. We didn't launch him until the defect was corrected, but the point is: the radio call can be fake news. All you know for sure is that it clutters the frequency.
Your procedures must be based on **actions**. It isn't wring to recite the checklist, but you need to be performing the action of checking that e.g. the spoilers are locked and the canopy is locked.
T8
Old June 12th 20, 04:06 PM posted to rec.aviation.soaring
Nick Kennedy[_3_]
Last Tuesday evening Cindy Brickner hosted a SSA Webinar " Aero towing",
it was very well put together and presented with a powerpoint presentation and a review of the accident that started this thread.
Cindy is a good public speaker and its easy to listen to.
I think it should be required watching for for all glider pilots IMHO every spring.
It clearly shows how in a very short 2-3 seconds the situation can get out of control and the tow pilot gets killed.
It should be up on the SSA webpage in a few days under Webinars.
Thank you Cindy for your time and effort into producing this Webinar.
Fly safe in 2020
Nick
T
Towplane-Baron accident Jp Stewart Soaring 58 June 11th 18 10:03 PM
Fatal accident in Scotland Ian Soaring 51 September 6th 07 10:55 AM
Another fatal accident Mike the Strike Soaring 0 September 20th 06 11:50 PM
Fatal accident in Italy 2cernauta2 Soaring 1 April 4th 06 05:50 PM
Hawaii Fatal Accident Rocky Rotorcraft 0 July 25th 03 03:01 PM
