C172 crash at Coney Island
Old May 21st 05, 09:33 PM
Gary Drescher
Default C172 crash at Coney Island
Four people died aboard a 172 that crashed at Coney Island today
(http://www.nytimes.com/2005/05/22/ny...2crash.html?hp).
According to witness descriptions, the plane approached the shore at low
altitude, turned sharply, and then plummeted vertically. The witnesses had
the usual confusion about "stalling" and interpreted the crash as a loss of
power, but it sounds like it may have been a classic stall resulting from
inadequate airspeed during a steep turn. Coney Island is close to a section
of airspace where the Class B has a floor just above 500', so it may be that
the plane hadn't climbed much above that altitude, and tried to turn
abruptly away from the shore in order to avoid overflying a built-up area
too low.
--Gary
Old May 21st 05, 09:43 PM
Ben Hallert
The class B floor is 500? Sounds like a recipe for some sort of
airspace version of scud running, which in turns sounds like a great
way to have unrecoverable stalls/engine outs, controlled flight into
terrain/water.
Most unfortunate, my best wishes to the families affected.
Old May 21st 05, 09:50 PM
Gary Drescher
"Ben Hallert" wrote in message
terrain/water.
It's a twelve-mile-stretch of the Long Island shore, just a few miles south
of JFK. It's actually quite fun to fly there at that altitude--I've done it
several times. An engine failure wouldn't be especially bad because there's
a beach to land on (or you can ditch just offshore if the beach is too
crowded). You do, of course, need to avoid stalling (or especially
spinning).
--Gary
Old May 21st 05, 10:40 PM
terrain/water.
Actually over Coney Island the floor of Class B space is at 1500 ft
(I'm looking at my NY chart). It's hard to tell from the ground how
high the airplane is. Unfortunately it sounds like a classic
stall/spin.
You can see the tail number in the NYT photo..
Yes. Very sad
....richie
Old May 21st 05, 10:54 PM
Gary Drescher
Right, but just nearby the Class B is 500'(+). If the plane came from there,
it might still have been quite low (or it might've been low anyway just to
get a better view).
--Gary
Old May 22nd 05, 12:07 AM
Ernest C. Evans
I'm not a pilot but I was wondering why this plane went down "nose first"
??? I'm thinkin', don't these things have some gliding ability ???
i guess the pilot must've been too low to recover ..... Having an engine
quit on you is bad enough luck ..... but having it happened when you just
happen to be at a low altitude is even worse luck ! (
there, it might still have been quite low (or it might've been low anyway
just to get a better view).
--Gary
Old May 22nd 05, 12:17 AM
Gary Drescher
"Ernest C. Evans" wrote in message
Actually, having an engine quit would *not* cause a plane to fall. As you
say, it would just glide instead.
What does cause a plane to fall--whether the engine is running or not--is
pulling back too far on the control wheel, which causes the plane to slow
down too much (at least, that's the simplified explanation). When that
happens, witnesses who are not familiar with aerodynamic principles often
perceive the incident as an engine failure, which is then how the press
reports it initially.
You're right too that when a plane stops flying (the technical term is
"stalling", but that's confusing because it has nothing to do with the
*engine* stalling), you can recover if you have enough altitude, but being
lower makes recovery harder. Stall recovery shouldn't take much more than
100 feet, but there's a particularly bad type of stall--called a spin--that
can take more than 1000 feet to recover from.
--Gary
Old May 22nd 05, 02:42 AM
Matt Whiting
Are you sure the engine quit?
Matt
Old May 22nd 05, 01:58 AM
Ron Natalie
terrain/water.
The airspace below is over open water. It's perfectly reasonable.
Old May 22nd 05, 05:18 AM
Ron Garret
terrain/water.
Actually, significant parts of the 500' floor are over densely populated
areas of New Jersey. (Wow, what a hairy-assed chunk of airspace.
There's a teeny weeny triangle of 500' floor wedged in between a section
with an 800' floor and the EWR central core. That's gotta be the
smallest separately charted chunk of controlled airspace in the world.)
rg
C172 Plane crash Orlando, FL CFLav8r Piloting 25 January 15th 05 08:54 PM
Long Island Crash - Kite String? Neb Okla Rotorcraft 5 September 3rd 04 05:43 PM
Navy releases names of 4 killed in island crash Otis Willie Military Aviation 0 August 14th 04 11:21 PM
Madeline Island and Richard I. Bong Museum PIREP Jay Honeck Piloting 3 July 20th 04 03:21 AM
Soviet Submarines Losses - WWII Mike Yared Military Aviation 4 October 30th 03 03:09 AM
