#91
link.net... "John Mazor" wrote in message ... Up until tonight, no, but McNicoll's increasingly blatant attempts to do so now make it clear that that in fact is happening here. McNicoll made no attempt to cover any controller asses here, there's no controller's ass to cover because the controller made no error. I rest my case. Let's see... my repeated statements here, in clear, blunt, unmistakable language that "the crew screwed" up" are part of a clever attempt to deflect attention away from the crew. Wow, I never woulda known that if you hadn't pointed it out to me. I thought they were a clear, blunt, unmistakable admission that the principal initiating event was pilot error. No, it was your implication that the controller failed to prevent this accident that was a not-so-clever attempt to deflect attention away from the crew. The controller was otherwise occupied, and I never stated or implied that if he had not been otherwise occupied, the controller *would* have prevented the accident. Furthermore, I have made clear that even if there had been the two controllers there and the lone controller had not been responsible for working both positions, he would not have committed any error if he had failed to notice the pilot error and warn them. He *might* have, yes, but that goes to redundancy, one of the safety concepts that I have contributed to these discussions and which you have ignored in your determined but unneccesary obsession with ensuring that no one attributes any controller error to this accident. To the extent that other factors such as airport layout and markings, etc. are shown to have contributed a link in the accident chain, every one of those links is a failure point in the complex, interlocking array of safety protections that have been built into the system. Each and every one of them has to be identified and fixed if we want to avoid a repeat of a similar accident scenario. So if you think that my calling attention to this aspect of the investigation is some attempt to cover up or absolve any human error by the crew, you still don't understand how aviation safety works. Jon, do you have any background at all in aviation? What makes you think you have any understanding of how aviation safety works? My many explanations here of how the investigation process and safety system work, none of which you have acknowledged, let alone refuted. |
#92
"Sam Spade" wrote in message
news ![]() John Mazor wrote: So the crew "deliberately" acted in a way that represented a "failure to use even the slightest amount of care" in an issue that had a reasonable expection that it would result in a fatal accident? Really? First of all, if they really were failing to exercise the least amount of care, then why did they properly perform so many other safety checks and procedures as required? Second, since this recklessness and disregard for safety included the reasonable expectation that they, or at least the other pilot ("others"), would die in the predictable outcome, please cite evidence that they both were indifferent to the likely prospect that one or both of them also would die as a result of their actions. "Willful disregard"? Again, if they performed the other numerous safety checks and procedures as required, why would they choose to "willfully disregard" the ones related to taking the proper runway? If, in fact, they correctly completed all required company check lists and other procedures, then the company has a systemic problem in not requiring that runway heading be set on the heading bug. Each airline has its own FAA-approved procedures and lists, and none of them is exactly the same. (And it's not uncommon for the airline to change a procedure after an accident.) The fact that it all is approved by the FAA is a good starting point in a defense against charges of gross negligence and willful disregard. It's not an absolute defense, but it can help. And, in fact, if they correctly completed all required checks, then went on to commit a terribily illegal and irresonsible act; i.e., to takeoff on an unlighted runway (that HAD to be willful, John), then their prior conduct of preflight is irrelevant and not in any sense mitigating of that willfully terrible act. "Willful" has many definitions. The only one that matters is the legal one, when it is coupled with "disregard". Of course they didn't think they were going to die. They nonetheless willfully took on an unlighted runway, which is contrary to any modicum of professional flight crew conduct. That's not always an absolute rule. The NTSB probably won't go there, although they should. So should the FAA and the local D.A. Horse puckey. I'll call your "horse puckey" and raise you. "Horse puckey" is a good indicator you've run out of ideas to keep these jerks from having acted in a grossly negligent manner. If I had just stopped at "horse puckey" and not elucidated with the examples of what "gross negligence" in the cockpit might really look like, and then go on to make a comparison, you'd be right. But since I didn't, I wasn't out of ideas, so you're wrong. Examples of "willful disregard" by pilots do exist. Take the situation of the two pilots who were discovered nearly naked in the cockpit in flight. If an accident had occurred while they were in that condition, any attorney could make a good case for willful disregard. Or the Russian airliner crash where the captain allowed his son (IIRC) to sit in his seat and operate the aircraft. From what we know so far, this accident doesn't come even close to crossing that line. I couldn't disagree more. Your cites are different types of idiotic conduct. So what does that mean? That they don't rise to the level of "willful disregard"? Your self-appointed task here is to show that the Comair crew's behavior rises to the legal definitions of gross negligence and willful disregard. I'm not a lawyer, so I'm just musing here, but I would think that a key factor has to be examining the patterns of behavior both during and surrounding the alleged acts of willful disregard. Many accidents involve similar patterns: crew performs flawlessly up until the action in question, which leaves everyone shaking their head and asking "How did they miss that?" or "Why did they do that?" To my knowledge, these don't normally result in successful claims of "gross negligence" or "willful disregard". Furthermore, the absence of demonstrable gross negligence or willful disregard doesn't prevent anyone from making a successful tort claim (or negotiating a settlement), it just sweetens the pot if you can prove it. I may be wrong, since I don't follow the ensuing liability suits as closely, but that's my take on it. Here's the real bottom line: gross negligence and willful disregard are whatever a judge or jury find them to be. Just as the armchair quarterbacking here on the accident is meaningless until the NTSB report comes out, the real proof will come when the liability suits are tried. As to the unauthorized son in the captain's seat I can assure you I have personally witnessed more than a few ALPA members do about the same thing, admittedly more in the 1960s and early 1970s than later years. It certainly was a different era then, eh? I remember when I was about 8, being put alone on a Connie for a trip. About halfway into the flight, the FA asked if I wanted to see the cockpit and escorted me there, where I chatted with the crew (standing, not sitting!) for a good five minutes, with the cockpit door wide open all the time. But that doesn't excuse parental seat-swapping, even then. If it happened now, the odds are pretty good that the crew would be hearing from the chief pilot real soon, and there'd be at least one ASRS report filed. Anyone familiar with airline ops probably can write a book on "stupid pilot tricks". |
#93
ink.net... "John Mazor" wrote in message ... So you do get it. Of course I get it. I've been trying to help you get it. How? By your incessant mantra that there was no controller error - which I already have stated repeatedly here, just as I have repeatedly noted that there is demonstrable crew error. So what is it that you're trying to make me "get"? And here must lie McNicoll's agenda. He is obsessed with ensuring that no one give even the slightest hint of controller *error* in this accident. There is no hint of controller error in this accident. I rest my case. Of course, no one has done that here - You have done that here. And I repeat my request that you show even one example of me accusing the controller of any error. You haven't, because you can't. the controller broke no rules in his actions - but he still thinks that someone is out to spread the "blame" to the controller by suggesting that he, too, "screwed up". Since McNicoll has accused me of acting as an agent for the pilots, You have no connection to ALPA? Irrelevant. You just blew right past my umpteenth confirmation that the controller broke no rules - when are you going to admit that and stop accusing me of something I never said? I now feel free to wonder if he is actually a controller, whose only goal is to protect his own kind at all costs. I am a controller, frequent users of these forums are aware of that. I have no goal of protecting controllers at all costs, the controller's union does that. Just as the pilot's union does it for pilots. Then why are you trying to protect the controller at all costs? I've admitted numerous times that there is crew error involved. Stephen, you sound more and more like you are a controller. Not that it's relevant to the worthiness of your arguments, which like mine, must stand on their own merits. So to the extent that it matters here (which isn't much), that means that it's up to our readers to judge the merits of the case we present. And, as I have said before, that's not even an important goal for me here. I'm trying to explain that any accident investigation, if it is to do any good at all, must extend well beyond any obvious finding of human or mechanical failure. And, as it would now appear, a minor secondary goal for me is to point out that instead of educating others on the much wider framework of how accident investigation and the interlocking system of safety checks and balances work (as I have done), virtually all of his arguments have been aimed at the extremely limited goal of protecting the controller at all costs. Jon, you may be in a position to educate others on unionism, you are not in a position to educate others on aviation matters. Your true goal here is quite clear. A comparison of the body of information that the two of us have contributed to the discussion of this accident will show that I have provided far more information to educate readers than you have. So do tell us, what is my "true goal" here? To exonerate the crew? "The crew screwed up" - how many times have I said that? "The controller committed an error" - how many times have I said that? (Never.) "The controller committed no error" - how many times have you said that? (I've lost count.) I never killfile anyone, but unless you have something new to contribute beyond your hollow mantras and UseNet dodges, I see no point in responding to any more of your "nanner, nanner, are so!" whining. Let us know if and when you want to contribute anything substantive. |
#94
![]() "John Mazor" wrote in message ... I have. Show us one instance where I've stated or even intimated that the controller made any error. I didn't say you stated it, I said you implied it. Do you want me to post quotes of you implying it, or should I just post the definition of "imply"? All I've ever said is that because the FAA violated its own staffing rules, he had to work two positions and therefore, the possibility that he might have seen the crew take the wrong runway and warn them was mooted. Actually, he was probably working about six positions at the time. Clearance delivery, ground control, local control, all normal tower positions, plus probably two radar positions and perhaps a flight data position normally found in the TRACON. FAA policy was not to have all tower and TRACON positions combined, that's what was violated. Had the policy been adhered to then all tower positions would have been worked by one controller in the tower, and all TRACON positions would have been worked by a second controller physically in the TRACON or in the tower. Jon and most other laymen have concluded that the policy required two controllers to be in the tower, that was not the case. The second controller could have been in the windowless TRACON and thus not able to see the Comair at any point. The staffing situation is much like that in a 24-hour supermarket. At 2 PM all checkout aisles may be needed to handle the customer traffic. At 2 AM one checkout is enough, so staffing is appropriately reduced and all checkout positions are combined at one aisle with no reduction in service to the customer. Reports on the LEX accident do not mention any other aircraft being worked by the lone controller, either on the field or in the airspace delegated to the TRACON. So regardless what hat the controller was wearing at the time, clearance delivery, ground control, local control, etc., the controller still had only one customer at any moment. You're sucking wind at this point, McNicoll, running like hell to try to evade my points. If you review the thread, you'll see that I've addressed all of your relevant "points" at least once. We've apparently reached the point where all you can do is delete my points and toss out some feeble UseNet dodges in lieu of offering constructive rebuttals or information. You still don't get it. |
#95
link.net... "John Mazor" wrote in message ... I have. Show us one instance where I've stated or even intimated that the controller made any error. I didn't say you stated it, I said you implied it. Do you want me to post quotes of you implying it, or should I just post the definition of "imply"? All I've ever said is that because the FAA violated its own staffing rules, he had to work two positions and therefore, the possibility that he might have seen the crew take the wrong runway and warn them was mooted. Actually, he was probably working about six positions at the time. Clearance delivery, ground control, local control, all normal tower positions, plus probably two radar positions and perhaps a flight data position normally found in the TRACON. FAA policy was not to have all tower and TRACON positions combined, that's what was violated. Had the policy been adhered to then all tower positions would have been worked by one controller in the tower, and all TRACON positions would have been worked by a second controller physically in the TRACON or in the tower. Jon and most other laymen have concluded that the policy required two controllers to be in the tower, that was not the case. The second controller could have been in the windowless TRACON and thus not able to see the Comair at any point. The staffing situation is much like that in a 24-hour supermarket. At 2 PM all checkout aisles may be needed to handle the customer traffic. At 2 AM one checkout is enough, so staffing is appropriately reduced and all checkout positions are combined at one aisle with no reduction in service to the customer. I don't have the airport's flight schedule, but I'm under the understanding that around 6 a.m. is when the departure activity picks up. That's not a criticism, just an observation that 6 a.m. may not be as dead as 2 a.m. there. Reports on the LEX accident do not mention any other aircraft being worked by the lone controller, either on the field or in the airspace delegated to the TRACON. So regardless what hat the controller was wearing at the time, clearance delivery, ground control, local control, etc., the controller still had only one customer at any moment. You're sucking wind at this point, McNicoll, running like hell to try to evade my points. If you review the thread, you'll see that I've addressed all of your relevant "points" at least once. We've apparently reached the point where all you can do is delete my points and toss out some feeble UseNet dodges in lieu of offering constructive rebuttals or information. Thank you for the constructive information. I read it with great interest. (Really.) As to what you think I implied, not only did I never intend to imply controller error, but nothing I said could reasonably be interpreted as such. You are being overly sensitive on that. However, neither of us is going to change our opinion on that point so there is no point continuing it. We (the newsgroup collectively) have beaten certain issues to death here, but additional information is always wecome for discussion. You still don't get it. We all get it, let's move on. |
#96
John Mazor wrote:
Of course they didn't think they were going to die. They nonetheless willfully took on an unlighted runway, which is contrary to any modicum of professional flight crew conduct. That's not always an absolute rule. What is that? Taking an unlighted runway or professional flight crew conduct? |
#97
John Mazor wrote:
Don't you get it? Yes, in any accident there will be some big, fat smoking gun that anyone can see - usually a human or mechanical failure. But before, during, and after the main event, there are other links in the chain, all of which are not only sufficient, but *necessary* for this chain to continue unbroken until the accident actually occurs. Every one of those links is a failure point in the complex, interlocking array of safety protections that have been built into the system. Each and every one of those failures contributed to the accident. Each and every one of them has to be identified and fixed if we want to avoid a repeat of a similar accident scenario. If you think that this part of the investigation is some attempt to cover up or absolve any human error by anyone, you just don't understand the principles of aviation safety. I understand the chain of events principle quite well. I will readily concede that a series of events could cause an aircraft to get lined up on the wrong runway. But, I simply cannot and will not accept that, once lined up on the incorrect runway, a Part 121 flight crew would disregard the lack of runway lights. Unless some hard evidence sufraces to explain how that could happen short of willful disregard of safety/legal operating requirements, the conclusions I have formed in my mind will remain unchanged. Having said that, I would be happy to be shown the error of my conclusions to date. I understand they did a "rolling takeoff." Well, okay, but once lined up and rolling it should have become quite apparent, early on in the roll, "Hey, this runway is dark!" That would have been enough for me to have "broken the chain" by immediately performing an abort. |
#98
![]() Sam Spade wrote: But, I simply cannot and will not accept that, once lined up on the incorrect runway, a Part 121 flight crew would disregard the lack of runway lights. Unless some hard evidence sufraces to explain how that could happen short of willful disregard of safety/legal operating requirements, the conclusions I have formed in my mind will remain unchanged. On the day of the accident, there was a NOTAM that the centerline lights on the long runway were OTS. A misinterpretation of the NOTAM could have led the crew not to question the absence of lights. Just a thought. It could have been another possible link in the chain. John Galban=====N4BQ (PA28-180) |
#99
#100
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Home Built | 3 | May 14th 04 11:55 AM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Aerobatics | 0 | May 11th 04 10:43 PM |
