Setting altimeters with no radio
Old November 12th 06, 01:11 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Setting altimeters with no radio
Since it is possible to fly without voice radio equipment, and given
that (if I understand correctly) pilots are supposed to have their
altimeters set correctly to a reference located not more than 100
miles from their position, how does an aircraft without a radio keep
its altimeter properly set as it travels?
Old November 12th 06, 01:40 AM posted to rec.aviation.piloting,rec.aviation.student
TxSrv
For VFR, an adjustable altimeter is not required. Therefore, such
a 100 mile rule doesn't exist.
F--
Old November 12th 06, 09:53 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
TxSrv writes:
OK. But in that case how do VFR flights maintain specific altitudes?
Old November 12th 06, 04:20 PM posted to rec.aviation.piloting,rec.aviation.student
Steven P. McNicoll[_1_]
"TxSrv" wrote in message
For VFR, an adjustable altimeter is not required. Therefore, such a 100
What aircraft altimeter is not adjustable? IFR flight requires a sensitive
altimeter adjustable for barometric pressure, VFR flight simply requires an
altimeter. But even altimeters that cannot be adjusted for barometric
pressure are adjustable. My Champ' came with a single-needle altimeter,
once around the dial was 10,000 feet. I hated it, the needle never seemed
to move. But there was an adjustment knob that rotated the dial so the
needle would point to field elevation.
The regulation requires aircraft without radios to set the altimeter to the
elevation of the departure airport or an appropriate altimeter setting
available before departure.
Old November 12th 06, 04:10 AM posted to rec.aviation.piloting,rec.aviation.student
BT
you cant
"Mxsmanic" wrote in message
Old November 12th 06, 04:31 AM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
GPS, even a $100 hikers model will solve the problem. But I
just say, look at the ground, you can judge 1,000 feet
pretty well and you only need to apply the hemisphere rule
above 3,000 AGL.
"BT" wrote in message
| you cant
have their
than 100
a radio keep
Old November 12th 06, 07:16 AM posted to rec.aviation.piloting,rec.aviation.student
Peter Duniho
"Jim Macklin" wrote in message
No, it won't.
Old November 12th 06, 12:07 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
they give altitude, accurate to within a few feet. just set
the altimeter to read the same. then you know adjusted
pressure. considering the legal requirements, it is
perfectly adequate.
see http://mtp.jpl.nasa.gov/notes/altitude/altitude.html
"Peter Duniho" wrote in
message ...
| "Jim Macklin" wrote
in message
| No, it won't.
Old November 12th 06, 12:38 PM posted to rec.aviation.piloting,rec.aviation.student
Stefan
NO, dont' do this. The whole aviation system (airspace, separation...)
is based on pressure altitude, not geometric altitude.
Stefan
Old November 12th 06, 02:52 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
"Jim Macklin" writes:
Unfortunately, no, they do not. GPS is accurate for lateral
navigation, not vertical navigation. GPS altitudes can easily be off
by as much as 200 feet at ground level in comparison to a correctly
set altimeter, and at altitude the disparity can reach 500 feet.
The reason for this is that the angles used for triangulation of
lateral positions are large and permit a high level of precision, but
the angles for triangulation of altitude are very small and it's very
easy to be off by a wide margin. GPS was designed to measure lateral
positions accurately, but it performs poorly for altitude. It is
typically much less accurate than an altimeter for altitude, and the
computed altitude constantly changes (significantly) as the satellites
move, in a way that is, for aviation purposes, practically random.
... just set the altimeter to read the same.
This is a good way to fly into a mountain, or another aircraft, or the
runway.
... then you know adjusted
perfectly adequate.
No, it is not. It's especially dangerous for RVSM flight, but it's so
inaccurate that it should never be used for anything, except as a last
resort (if the altimeters disintegrate, or whatever).
I Hate Radios Ron Wanttaja Home Built 9 June 6th 05 05:39 PM
(sorta OT) Free Ham Radio Course RST Engineering Piloting 43 January 24th 05 08:05 PM
1944 Aerial War Comes to Life in Radio Play Otis Willie Military Aviation 0 March 25th 04 10:57 PM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 03:30 AM
