OT - Video Card Question(s)
Old November 19th 06, 01:38 PM posted to rec.aviation.piloting
Jay Honeck
Default OT - Video Card Question(s)
Okay, this thread isn't totally off-topic, as my questions are related
to making the piloting experience more real in the sim. It's time to
upgrade the Kiwi!
(See it he http://alexisparkinn.com/the_kiwi_is_born.htm ).
I want to add a second monitor (dedicated for the panel), and use the
104" projection screen for the "out-the-window-world-view" only. This
means that I need a video card with two video outputs. "Lesser" models
seem to have a single DVI output and a single VGA (AKA: D-Sub) output,
while "better" models have two DVI outputs.
Our flight sim PC is a Dell Optiplex GX260, Pentium 4, with a gig of
RAM -- but only an AGP slot for video card upgrade. The current card
is a Radeon 7000, with just 32 mb of on-board memory, and a single VGA
port. This Dell system "only" has a 250 watt power supply, which --
along with the AGP slot -- pretty much eliminates the "latest &
greatest" video cards, all of which need a bigger power supply and/or
require a PCI-Express expansion slot.
Compatibility with an older system like this is obviously a problem. I
tried installing an ATI X1600 today (from Worst Buy), with 512 MB
on-board, and the PC wouldn't even boot up with it installed! I
obviously had pushed my older computer past its limits.
So, I'm aiming a bit lower, and looking at the EVGA GEForce 6600LE. See
it he
http://www.newegg.com/Product/Produc...82E16814130262
It's reasonably priced, seems to have decent specs that are within the
limits of my PC, and is in-stock. Anyone have any experience with this
board? Anyone got a better idea?
I've spent five hours dinking around with this, between trips to Best
Buy and time researching on-line, and I'm starting to go cross-eyed!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old November 19th 06, 02:32 PM posted to rec.aviation.piloting
Martin Hotze
it he
according to the manufacturer:
http://www.evga.com/products/moreinf...0-TX&family=17
---snip
Requirements
Minimum of a 300 Watt power supply.
(Minimum recommended power supply with +12 Volt current rating of 18 Amp
Amps.)
---snap
and I'd look into a card with passive cooling - _if_ possible.
#m
Enemy Combatant http://itsnotallbad.com/
Old November 19th 06, 03:09 PM posted to rec.aviation.piloting
Jay Honeck
---snip
Requirements
Amps.)
---snap
Nuts. I was afraid of something like that.
Any suggestions?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old November 19th 06, 03:20 PM posted to rec.aviation.piloting
Jose[_1_]
Any suggestions?
Well, considering how far you've gone with this fruit, you might
consider getting a new machine (computers are practially disposable
nowadays) and dedicating it to the kiwi. Get one with four (or more!)
video outputs, and dedicate the other two to side windows. A few spare
monitors and you'd have a simulator that would even get Mx to visit you
from France.
Jose
"Never trust anything that can think for itself, if you can't see where
it keeps its brain." (chapter 10 of book 3 - Harry Potter).
Old November 19th 06, 10:32 PM posted to rec.aviation.piloting
Jim Burns
"Jay Honeck"
Any suggestions?
New (larger) power supply for the MB & daughter cards.
Save the second one, install it "somewhere", buy a normally open relay, wire
it to the first power supply and you now have all the power you'll ever
need. Run the MB from the new larger supply and the HD's and other junk
from the second.
It works pretty good, this is the way I"ve got my old PC set up and I've
never had a power issue.
Old November 19th 06, 04:24 PM posted to rec.aviation.piloting
Jim Macklin
You must use compatible video cards, be sure to check the
specs to be sure that you can run two monitors with
completely different outputs. Often you just split the
desktop, you need two independent outputs.
You may want to look into one of the new computers with a
dual core CPU, PCIe video and plenty of power and cooling.
"Jay Honeck" wrote in message
are related
It's time to
| upgrade the Kiwi!
| (See it he
and use the
only. This
"Lesser" models
D-Sub) output,
with a gig of
current card
a single VGA
supply, which --
"latest &
supply and/or
a problem. I
512 MB
installed! I
GEForce 6600LE. See
| it he
are within the
trips to Best
cross-eyed!
| Thanks,
| Jay Honeck
| Iowa City, IA
| Pathfinder N56993
Old November 19th 06, 07:44 PM posted to rec.aviation.piloting
Martin Hotze
On Sun, 19 Nov 2006 10:24:48 -0600, "Jim Macklin"
the good thing of those core 2 duo machines is that they didn't use this
much power anymore (350W PSU are OK, depending on graphics and other
accessories) and don't produce that much heat than the prescott modells
did. And they also produce less noise, too.
my suggestion:
- motherboard with either raid on board or a extra raid controller
(fasttrack has cheap and good ones)
- 2 S-ATA harddrives with raid 1 mirroring. If you lose one drive you can
still work (fly) and can get yourself a new drive, so you save yourself
setting up the machine again. samsung!
- intel core 2 duo cpu
- min. 1 gig ram, the faster the better (ddr2 667mhz, samsung ... *yammi*)
- graphic card with DVI out (you'll buy new monitors later and will have
DVI-IN), ~256mb ram.
- optical drive (samsung)
- floppy (yes, you'll need one for the raid controller, external usb will
not be recognised by windows during install)
IMHO, RAID will save you a lot of time and hassle, because you'll lose one
drive the monemt you will like it the least (according to Murphy's law).
#m
Old November 19th 06, 08:11 PM posted to rec.aviation.piloting
john smith
Another way to increase speed... look at installing Western Digital
RAPTOR HD (spins at 10,000 rpm). Watch the specs to make certain the PS
can handle them.
Old November 20th 06, 12:33 AM posted to rec.aviation.piloting
Jay Honeck
my suggestion:
What is your opinion of this system set-up? Would a system like this
make FSX fly? If not, what would you change?
INTEL CORE DUO PROCESSORS E6600 CORE 2 DUO 2.40 GHZ 4M / 1066 FSB
$416.00
INTEL CORE DUO MOTHERBOARDS INTEL DQ965GF DDR2 MOTHERBOARD
$153.39
DDR2 MEMORY 2 GB DDR2 667 MEMORY $426.00
IDE HARD DRIVES MAXTOR 160GB 7200RPM 8MB SATA HARD DRIVE $78.63
CD-ROM DRIVES LITE-ON 16X DVD 52X32X52 CD-RW BLK COMBO $60.00
PCI-EXPRESS VIDEO CARDS EVGA 7800 GT 256MB PCI-E VIDEO CARD $348.00
SOUND CARD CREATIVE SOUND BLASTER PCI 128 $19.00
FLOPPY DRIVES SONY 1.44 FLOPPY DRIVE WHT $13.68
MID TOWER CASES EVERCASE WITH FRONT USB2/1394 400W $68.50
POWER SUPPLY INCLUDED (UNLESS DESCRIPTION SAYS NO PS) $0.00
CASE FANS TWO EXTRA YATE LOON CASE FANS $20.00
OPERATING SYSTEMS MICROSOFT WINDOWS XP HOME OEM SP2 $99.00
WARRANTY THREE YEARS PARTS & LABOR
SYSTEM PRICE $1702.20
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old November 20th 06, 12:46 AM posted to rec.aviation.piloting
Jim Macklin
MS is dropping support on XP Home before long, but will
continue support for XP Pro. You should be sure to get the
Vista upgrade coupon, too.
Be sure the game allows you to split out the portion of the
display you want, it sounds as though you want to have just
the panel on one display and the outside world on the other.
Be sure that the video cards are designed for independent
output and are compatible with each other and the software.
A DVD RW 16x dual layer drive also does CDs, being able to
record a 8.5 GB DVD might be useful.
I would be sure the sound card will run a 5.1 system if you
want the "best" sound effects.
PCIe video cards may not work in the standard PCIe slots,
they have PCIe 16x slots for video, be sure about what slot
the mobo has for the second video card.
| my suggestion:
controller
like this
1066 FSB
| $416.00
MOTHERBOARD
| $153.39
$78.63
$60.00
CARD $348.00
$0.00
$99.00
| Jay Honeck
| Iowa City, IA
| Pathfinder N56993
MSFS 2004 Video frame rate very slow Greg Brown Simulators 1 November 11th 05 07:24 PM
Video Card problem David Morley Simulators 3 March 11th 04 06:47 AM
Video and Memory Card upgrade? Dave Schwartz Simulators 3 January 3rd 04 12:14 PM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 09:25 AM
