#91
Really?? But you gotta be clear of cloud, surely!!!
Yes, you must be clear of cloud. Depending on the airspace, you must be certain distances away. However, in the US you do not need ground contact. You can fly VFR above a solid overcast. It may not be too bright to do so, depending on circumstances. However, it is legal, and often not a dumb thing to do. Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
#92
Mxsmanic wrote:
We are talking about flying VFR then entering cloud, right??? Charts are no good if you can't see where you're going! They are if you have instruments telling you where you are. if you are entering IMC while VFR, knowing where you are will be the least of your problem: you'll be dead before it matters one way or the other. --Sylvain |
#93
On Apr 3, 2:53 pm, Jose wrote:
Really?? But you gotta be clear of cloud, surely!!! Yes, you must be clear of cloud. Depending on the airspace, you must be certain distances away. However, in the US you do not need ground contact. You can fly VFR above a solid overcast. It may not be too bright to do so, depending on circumstances. However, it is legal, and often not a dumb thing to do. Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. Makes me laugh, just a little.. People here have been telling me how dangerous it is to fly without accurate fuel gauges coz you might have a fuel leak or something like that and here you guys are now telling me you can fly above a solid overcast.. What happens if you have an engine failure?? Or get to your destination and you can't get down?? I also wouldn't think you could navigate by using your map if you can't see the surface, so that means using VOR or GPS or something, which I was under the impression are supposed to be secondary to your map reading! But what do I know... :-) |
#94
On Apr 3, 2:56 pm, Sylvain wrote:
Mxsmanic wrote: We are talking about flying VFR then entering cloud, right??? Charts are no good if you can't see where you're going! They are if you have instruments telling you where you are. if you are entering IMC while VFR, knowing where you are will be the least of your problem: you'll be dead before it matters one way or the other. --Sylvain Isn't it something like 90 seconds life expectancy for a VFR pilot entering cloud ??? And as far as I am concerned, if you are a VFR pilot, if you enter IMC, it isn't suddenly IFR flying if you ain't got your IFR rating! |
#95
On 2 Apr, 23:41, DR wrote:
Bertie the Bunyip wrote: DR wrote : chris wrote: On Mar 30, 5:19 pm, Mxsmanic wrote: chris writes: None of the small aircraft I have ever flown has had TCAS.. Are you sure you got that right ??? By "often used," I meant "when present on small aircraft, this is the type usually used," because it's cheaper. I don't think TCAS is really present very much on small GA aircraft, but I don't have actual figures. Since good avionics represent a substantial portion of the total cost of an aircraft, it follows that one wouldn't see advanced avionics that often on aircraft that are not otherwise very expensive. Who would install $2 million of avionics on a $90,000 aircraft? -- Transpose mxsmanic and gmail to reach me by e-mail. I fear it's even worse than you think, at least in this country, where private aircraft ownership is quite rare. Most light a/c are either aero club owned, i.e. 172 / Cherokee, or commercial, like Senecas and the like.. And on the whole, avionics tends to get neglected. The vast majority of club a/c wouldn't have GPS, let alone glass cockpits or TCAS. I have seen inside some commercial operated light a/c like Senecas and Aztecs and you'd probably be horrified at how basic they are. Just a couple of ADFs and VORs and that's all they get. Maybe a DME thrown in for good measure... And don't think they get maintained either. If the a/c came with IFR gear and isn't being used for IFR, like at an aero club, when things like DME and VOR break down they don't get fixed, they just get placarded as inop. Same as fuel gauges. Of 9 planes at our club, only 4 have working fuel gauges!! The rest are just placarded u/s. And the only reason there are 4 planes that have gauges that work is 3 of them are brand new a/craft. The deal with fuel gauges is, we know the fuel burn and we have a stick to dip the tank on preflight, what do we need gauges for ??? Hi Chris, Doesn't the MEL in part 91.509 say that fuel gauges are required... Are you saying that the director CAA has deemed that working (not necessarily accurate) fuel gauges are not required in your club -what gives? Flown lots of airliners where gauges may be U/S provided that the tanks are dripped. This is not true of the current crop of airliners but you coudl do it on older 73's for instance. Hmm, that really surprises me (but then a lot of things do!). I guess the issue of a fuel leak would be moot... On the other hand, not having cockpit guages (or the PIC not checking them) would contribute to why that Canadian(?) heavy ran out of A1 awhile ago? That's right. It was not an allowable MEL item in that airplane. Not with the fault that they had, anyway, but they misread the MEL and took it and at the same time made some errors in calculating the uplift. There are restirctions as to what you can or cannot do with US fuel gauges, but I can't remember exactly what nor can I look it up cuz my current drive must have them to fly. Though we have drips, I.ve never ever used them on this airplane. Did lots of times on the 737 and a couple of others, though. Bertie |
#96
On 2 Apr, 21:48, "chris" wrote:
On Apr 2, 4:43 pm, DR wrote: chris wrote: On Mar 30, 5:19 pm, Mxsmanic wrote: chris writes: None of the small aircraft I have ever flown has had TCAS.. Are you sure you got that right ??? By "often used," I meant "when present on small aircraft, this is the type usually used," because it's cheaper. I don't think TCAS is really present very much on small GA aircraft, but I don't have actual figures. Since good avionics represent a substantial portion of the total cost of an aircraft, it follows that one wouldn't see advanced avionics that often on aircraft that are not otherwise very expensive. Who would install $2 million of avionics on a $90,000 aircraft? -- Transpose mxsmanic and gmail to reach me by e-mail. I fear it's even worse than you think, at least in this country, where private aircraft ownership is quite rare. Most light a/c are either aero club owned, i.e. 172 / Cherokee, or commercial, like Senecas and the like.. And on the whole, avionics tends to get neglected. The vast majority of club a/c wouldn't have GPS, let alone glass cockpits or TCAS. I have seen inside some commercial operated light a/c like Senecas and Aztecs and you'd probably be horrified at how basic they are. Just a couple of ADFs and VORs and that's all they get. Maybe a DME thrown in for good measure... And don't think they get maintained either. If the a/c came with IFR gear and isn't being used for IFR, like at an aero club, when things like DME and VOR break down they don't get fixed, they just get placarded as inop. Same as fuel gauges. Of 9 planes at our club, only 4 have working fuel gauges!! The rest are just placarded u/s. And the only reason there are 4 planes that have gauges that work is 3 of them are brand new a/craft. The deal with fuel gauges is, we know the fuel burn and we have a stick to dip the tank on preflight, what do we need gauges for ??? Hi Chris, Doesn't the MEL in part 91.509 say that fuel gauges are required... Are you saying that the director CAA has deemed that working (not necessarily accurate) fuel gauges are not required in your club -what gives? Cheers MC- Hide quoted text - - Show quoted text - They have fuel gauges.. they just don't work :-)- Hide quoted text - Well, there's only one thing you can rely on for a fuel gauge to tell you anyway. That it's in the panel. That's it. You must check at least one other way that you have sufficient in any airplane except a glider.. Bertie |
#97
On 2 Apr, 22:26, "chris" wrote:
On Apr 3, 5:56 am, Mxsmanic wrote: Dylan Smith writes: Why is it therefore deemed not only acceptable but entirely normal that there is no in-flight fuel cross check in the form of a gauge that at least gives a reasonable indication of how much fuel you have left? Some pilots apparently love aviation so much that they're willing to die in the cockpit. -- Transpose mxsmanic and gmail to reach me by e-mail. That's a rather negative way to look at it!!! In a few days I will be flying for 2 1/2 hours on a cross country. I will have 4 1/2 hours fuel. That doesn't sound reckless to me!!! You won't be flying. you won't be on a cross coutry and you won't have fuel, Jesus boi. Oh and BTW, How do you know Jesus didn't **** like a bunny? Bertie |
#98
On 3 Apr, 01:07, Dave Doe wrote:
In article , says... chris writes: That's a rather negative way to look at it!!! Better safe than sorry, I say. In a few days I will be flying for 2 1/2 hours on a cross country. I will have 4 1/2 hours fuel. That doesn't sound reckless to me!!! If you really have the fuel you think you have, and if you really consume it as slowly as you think you do, perhaps not. Say 32 litres and hour, plus or minus a few - ain't gonna make much difference. Or to rephrase, how can a 32l/hr plane consume say twice that? We know you're not a real pilot - He's not even an unreal pilot. Bertie |
#99
to your destination and you can't get down?? Those are good considerations that would enter into your go/no-go decision. If you have an instrument rating and the aircraft is IFR capable, and there isn't ice in the undercast, and you are on flight following, it is probably not a big deal to get an IFR flight plan on the fly and descend through the cloud deck in an emergency. Or even not in an emergency - I have flown many flights VFR above a broken or overcast layer and gotten a pop-up instrument approach at the end. (I and the plane were instrument rated). Doing it this way allows a much more direct routing, and that can cut the need for a fuel stop. Engines themselves are pretty reliable (though nothing is perfect) - most engine failures are due to fuel mismanagement. Be extra careful with fuel if you are planning a trip over an undercast. Ditto for extended overwater flight. I also wouldn't think you could navigate by using your map if you can't see the surface, so that means using VOR or GPS or something... True. No navigation system does everything. Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
#100
Why Screeners Miss Guns and Knives (and why pilots miss planes and airports) | cjcampbell | Piloting | 2 | January 3rd 06 04:24 AM |
Junk Yards | NVArt | Home Built | 5 | July 13th 05 07:35 PM |
FS Aviation Junk | Jim | Aviation Marketplace | 1 | February 11th 05 10:57 PM |
Space Junk & GPS Reliability | Doug Carter | Instrument Flight Rules | 9 | July 11th 03 01:38 PM |
Space Junk & GPS Reliability | Dan R | Piloting | 7 | July 11th 03 01:38 PM |
