Coordinated turns without rudder, and autopilots
Old May 28th 07, 01:44 AM posted to rec.aviation.piloting
Mxsmanic
Default Coordinated turns without rudder, and autopilots
How do autopilots make coordinated turns even when they cannot control the
rudder?
Old May 28th 07, 02:34 AM posted to rec.aviation.piloting
Dan[_1_]
rudder?
If they don't control the rudder, they do not make coordinated turns!
--Dan
Old May 28th 07, 02:11 PM posted to rec.aviation.piloting
Ron Natalie
rudder?
--Dan
Boy we have the blind leading the blind here.
The whole point of that big vertical slab of metal sticking out of the
ass-end of your airplane is to provide a natural tendency for the
aircraft to fly coordinated. The pedals are just there for the
outlying conditions (low speed, high AOA for example) and fine
adjustment.
Old May 28th 07, 02:58 PM posted to rec.aviation.piloting
Matt Whiting
control the
rudder?
--Dan
adjustment.
And now we have the three blind mice...
Old May 28th 07, 04:59 PM posted to rec.aviation.piloting
Luke Skywalker
rudder?
--Dan
adjustment.
Ron...
oh my goodness...get some time with a good book on the subject and
then a CFI.
Robert
Old May 28th 07, 06:26 PM posted to rec.aviation.piloting
Andrew Sarangan
rudder?
--Dan
adjustment.
Ron...
then a CFI.
Robert- Hide quoted text -
Ron is correct. The vertical fin makes the airplane weather-vane into
the wind, and that's what co-ordination is all about. The rudder is
there only to help the vertical stab do this job.
A perfect airplane will not need rudder.
Old May 28th 07, 08:12 PM posted to rec.aviation.piloting
Dan[_1_]
rudder?
--Dan
adjustment.
Ron...
then a CFI.
A perfect airplane will not need rudder.- Hide quoted text -
- Show quoted text -
So where is this perfect airplane? I don't know about you, but I need
the rudder pedals to fly the aircraft.
--Dan
Old May 28th 07, 11:25 PM posted to rec.aviation.piloting
Matt Whiting
rudder?
--Dan
adjustment.
Ron...
then a CFI.
Not true. The vertical fin can only provide a weather-vane affect when
a slip or skid has been induced. In coordinated flight there is no slip
or skid and hence the fin provides no lateral force. When you begin a
turn, most airplanes will induce adverse yaw and the rudder can counter
than before a skid occurs. The fixed fin can only act once an
uncoordinated condition has been induced. Sure, it does mitigate the
skid or slip, but it absolutely can't prevent it as it can't provide a
force until uncoordinated flight is already established. The rudder can
do this and is why it is included.
The rudder isn't there to help the vertical stab do its job, it is there
to do a job that the vertical stab can't do.
Matt
Old May 29th 07, 01:02 AM posted to rec.aviation.piloting
Luke Skywalker
rudder?
--Dan
adjustment.
Ron...
then a CFI.
No he is not. Mark W...said the word.
Robert
Old May 29th 07, 11:40 AM posted to rec.aviation.piloting
Ron Natalie
Ron...
then a CFI.
Robert
I have plenty of good books and practice on the subject.
You should find an aeronautical engineer and find out how
planes are designed to work.
Question: Standard rate turns, constant rate turns, and airspeed Robert Barker Piloting 5 April 15th 07 04:47 PM
Coordinated turns and the little ball Mxsmanic Piloting 51 October 11th 06 10:17 PM
Is rudder required for coordinated turns? Mxsmanic Piloting 41 September 24th 06 06:40 PM
DGs and Autopilots Andrew Gideon Products 11 April 14th 05 06:04 PM
Coordinated turning stall and spins Chris OCallaghan Soaring 20 November 18th 03 08:46 PM
