Singapore down selects three fighters...
Old October 25th 03, 12:20 AM
John Cook
On Sun, 19 Oct 2003 04:00:52 -0400, "John Keeney"
"John Cook" wrote in message
In short stealth is nice but lots of other factors come into play, eg
Aircraft A is 100% invisible, but aircraft B has a 100% effective
defensive decoy system.
Who wins??
The stealth plane, because he's got a cannon and you can't
decoy ballastic rounds. ;-)
Wrong....
The guns are radar guided, and the actual projectile is explosive and
therefor has to be triggered by something spoof either and that fits
in with a 100% effective decoy system.
The only caveat is in the real world nothing is 100%..
Cheers
John Cook
Any spelling mistakes/grammatic errors are there purely to annoy. All
opinions are mine, not TAFE's however much they beg me for them.
Email Address :-
Spam trap - please remove (trousers) to email me
Eurofighter Website :-
http://www.eurofighter-typhoon.co.uk
  #92
Old October 25th 03, 02:01 AM
Nele_VII
Wrong wrong
A -laser- or, simply, colimator "guided" (in the terms of distance/track or
whatever) gun and simple ballistic (read steel, lead)round would make a nice
30 mm hole in aircraft B. It does things to high-velocity turbofan/jet
engines when it contacts turbine blades, y'know...
Unless aircraft b is invisible )))))
Nele
NULLA ROSA SINE SPINA
John Cook wrote in message ...
Who wins??
Wrong....
Cheers
John Cook
Email Address :-
  #93
Old October 25th 03, 09:16 AM
Paul J. Adam
In message , John Keeney
writes
Who wins??
Don't decoy the round, screw with the sight: that cannon is aimed by a
predictor system that needs target range and velocity data. Not hard at
all to have the gunsight generate the wrong pointing data. (And the
chance of a hit without a working sight is pretty minimal: not something
to bet an airframe and a mission on)
This also presupposes that you're able to get into parameters for a guns
shot... far from a given.
When you have to kill a man, it costs nothing to be polite.
W S Churchill
Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk
  #94
Old October 25th 03, 05:16 PM
phil hunt
writes
Who wins??
Very, very difficult, assuming it's a passive sensor. A visual or IR
sensor can see the target -- a decoy would have to be the same size
and shape to work, at the rangres we're talking about. And the sight
could use a rangefinder to measure distance (e.g. 2 sights, one at
the ewnd of each wing, giving the parallax). This would be very
difficult to spoof.
"It's easier to find people online who openly support the KKK than
people who openly support the RIAA" -- comment on Wikipedia
(Email: , but first subtract 275 and reverse
the last two letters).
  #95
Old October 25th 03, 11:37 PM
Scott Ferrin
On Sat, 25 Oct 2003 09:16:05 +0100, "Paul J. Adam"
writes
Who wins??
And it's assuming you don't get a dual mode seeker coming after you.
One of the Standards has both semi-active radar AND IR and they'd
kicked around the idea of putting one on Sparrow. Wouldn't be too
difficult to pull of if they felt it necessary. For example say an
F-22 identifies the enemy aircraft at position X and launches an
AMRAAM equiped with an active radar / IIR seeker that looks for a
return that has both a radar return AND an image somewhat resembling
an aircraft, it seems like it would be difficult to decoy. Granted
their isn't such a missile in service to my knowledge but it wouldn't
be particularly difficult to come up with one if they felt the need.
  #96
Old October 26th 03, 12:34 PM
Paul J. Adam
In message , phil hunt
writes
On Sat, 25 Oct 2003 09:16:05 +0100, Paul J. Adam news@jrwlync
A passive sensor won't give you range and rate information, just bearing
(and you can get that from the pilot's eyeball). A laser rangefinder
will get you range and radial velocity, but not crossing velocity: while
you can use it to drive a gyro gunsight, that requires a tracking shot.
If you want an accurate snapshot capability (rather than spray-and-pray)
you're looking at radar.
A visual or IR
difficult to spoof.
All this for a fixed-axis, thousand-yard maximum range weapon?
W S Churchill
  #97
Old October 26th 03, 12:45 PM
Paul J. Adam
In message , Scott Ferrin
writes
Does offer complications, however. Which sensor is in charge and which
is the backup? (It's thoroughly feasible, but has a few wrinkles in the
implementation: sensor fusion is a tricky art)
For example say an
Being done for antiship missiles at the moment; it complicates defensive
soft-kill but isn't invincible.
W S Churchill
  #98
Old October 27th 03, 09:12 AM
Urban Fredriksson
is the backup?
Neither. Or the one which sees only a single target is in
charge.
Urban Fredriksson http://www.canit.se/%7Egriffon/
A boundary between the known and the unknown always exists.
  #99
Old October 27th 03, 10:25 PM
phil hunt
writes
Multiple measurements will give you this.
while
A visual or IR
difficult to spoof.
If it works, why not?
  #100
Old October 28th 03, 07:32 AM
Paul J. Adam
writes
On Sun, 26 Oct 2003 12:34:30 +0000, Paul J. Adam news@jrwlyn
Sure, but this takes *time*, which you don't have by definition for a
snapshot. You can in theory use passive acoustics to track aircraft,
given enough time, but theoretical possibility hasn't translated yet
into useful application.
Cost, weight, and the fact that you usually die before you get to use
it?
W S Churchill
B-17s Debut, RAF Wellingtons Bomb & Fighters Sweep at Zeno's Video Drive-In zeno Instrument Flight Rules 0 October 30th 04 06:20 PM
B-17s Debut, RAF Wellingtons Bomb & Fighters Sweep at Zeno's Video Drive-In zeno Home Built 0 October 30th 04 06:19 PM
Why don't all fighters have low Wing Loading? Chad Irby Military Aviation 6 September 22nd 03 10:52 PM
US (Brit/Japanese/German/USSR) Use of Gun Cameras in Fighters?? ArtKramr Military Aviation 3 July 17th 03 06:02 AM
Scrambling fighters John Doe Military Aviation 7 July 2nd 03 09:26 PM
