Spinner strobing as a "Bird Strike Countermeasure"
Old December 5th 07, 01:12 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Mxsmanic
Default Spinner strobing as a "Bird Strike Countermeasure"
cavelamb himself writes:
Or else I won't Like You any nore.
I'm not looking for friends. I'm only here to discuss aviation.
  #92
Old December 5th 07, 01:23 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
cavelamb himself[_4_]
No. I don't think so.
I think you are here to taunt people and be a nusance.
  #93
Old December 5th 07, 01:47 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Jim Logajan
[Note: nonstandard attribution layout.]
Beryl wrote:
Entertaining thread this turned into. Anyway, here's a nice illusion.
http://img408.imageshack.us/img408/8067/imagegm1.gif
Concentrate on the + in the middle.
An illusory green dot soon appears.
Moments later, pink dots seem to disappear.
Very interesting and neat.
cavelamb himself wrote:
I'll repost this one here - so it's easier to find?
HEHEHE!
http://www.sonnyradio.com/spinninglady.html
It took some doing, but by glancing to one side (and sometimes briefly
closing my eyes and trying to imagine the reverse spin) I was able to
switch the perceived rotation direction. However, I have it on good
authority that I do not have an IQ of anywhere near 160. :-)
A couple times I had a shift in perceived rotation direction without
looking away.
I think this one is awesome.
Can these really be the same color???
http://www.home.earthlink.net/~cavel....htm#samecolor
Hard to believe indeed. I decided to do an image copy from the browser and
pasted the copy into the MS Windows Paint program. Copied two square chunks
of each of the two labeled board squares and pasted them side-by-side. Sure
enough they are the same color.
  #94
Old December 5th 07, 02:32 AM posted to rec.aviation.piloting, rec.aviation.homebuilt
On Dec 4, 9:48 pm, Airbus wrote:
And the front
fan
on a turbofan is turning at around 40-50 revolutions per second, not
thousands.
Guess again.
Well, I think he made a pretty good "guess" - the GE90-115B tha powers the
777 turns (front fan) at 2550RPM, or 42.5 RPS. He probably didn't ahve to
guess much, as these facts are easily and irrefutably verified. I "guess" you
haven't learned that. . .
Not too many folks bother to do a little research. It gets
easier all the time, what with Google and all that. Things like fan
speeds are easily available, and with a tiny bit of arithmetic the
rotational speed per second is easily calculated. Some posters just
diss anything someone else says, mostly because they didn't know it
first or perhaps becuase of who is saying it.
There's a well-known phenomenon that can incapacitate pilots. A
propeller spinning so that it cuts through the sun's glare and causes
a stroboscopic effect on the pilot's eyes can result in confusion. A
frequency of less than between 25 and 55 Hz, depending on the
individual, can cause dizziness or nausea. It's called "flicker
vertigo" and the fact that it happens tells me that the human eyeball
(or at least the visual cortex) does have a frequency function of some
sort. 25 Hz on a two-blade prop would be 750 RPM and 55 would be 1650.
Some tests have found that frequencies as low as four to 20 Hz will
induce it rapidly.
See this: http://www.flightsafety.org/hf/hf_mar-apr04.pdf
When I get the prop between the sun and my eyeballs I have to
increase the RPM to get rid of it. It's painful.
Dan
  #95
Old December 5th 07, 03:14 AM posted to rec.aviation.piloting, rec.aviation.homebuilt
Tina
Here's an illusion I can't expain at all.
http://amiedotcom.blogspot.com/2005/...hat-i-see.html
been told it has to do with resolving frequencies in space, not time,
but it's way past my number crunchiing skills.
HEHEHE!
looking away.
  #96
Old December 5th 07, 03:20 AM posted to rec.aviation.piloting, rec.aviation.homebuilt
Looks to me more like a detail issue, with the resolution
that diminishes with distance causing the illusion.
Dan
  #97
Old December 5th 07, 03:34 AM posted to rec.aviation.piloting, rec.aviation.homebuilt
Harry K
On Dec 4, 9:55 am, wrote:
In rec.aviation.piloting Harry K wrote:
On Dec 3, 7:21 pm, Harry K wrote:
On Dec 3, 2:45 pm, Just go look it up! wrote:
On Mon, 03 Dec 2007 21:52:04 -0800, Airbus wrote:
In article , says...
When observed directly under artifical light that "flickers", the most
obvious being a strobe light, but there are other types of artificial
lights that have flicker.
Fine - but which ones cause you to see the propellers turning in
apparent reverse? Do you frequently operate your airplane indoors?
Propellers are usually observed in natural light, which does not flicker. At
night, on the rare occasions where you actually see the props clearly, it is
from the aircraft's own lighting, which is DC. I have nbever seen the props
turning backwards on a real plane - see it frequently in movies though. . .
Night, near one of those big off-amber ramp lights, run the RPM up and
down, there's a range where it will look like it's going backwards. I
thought it was kind of interesting.
It's something similar to the poor-man's "is my RPM somewhat right"
test, it'll appear stopped at (I forget what RPM now) RPM and if your
tach is somewhat near, viola.- Hide quoted text -
- Show quoted text -
Been a long, long time but my rusty math skills says it would be about
3600 unless I am wrong (per wife that is my normal state). That is
the 1/2 harmonic of the rpm/flicker rate. 60 X 120 = 7200. The
phenomenon should appear at 1/2, 1/4, double rate etc intervals.
Harry K- Hide quoted text -
After thinking that over...
It gets worse. There will be multiple rpm that will show the effect
under strobe conditions. With a 2 blade prop it can be sychronizing
every 1/2 rev. 3-blade prop every 1/3 or 2/3 rev, etc. in addition to
synching on the harmonics.
It isn't that bad.
Synchronization only occurs on integral fractions and engine RPM is
usually 1000 and about 2700 RPM so the possibilities are limited.
For a 2 bladed prop:
7200/2= 3600 - 1800 RPM
7200/3= 2400 - 2400 RPM and 1200 RPM
7200/4= 1800 - 1800 RPM and 900 RPM
etc.
I leave it to someone else to show how many blades you see at each RPM.
Jim Pennino
Since the prop appears stationary, you would see all the blades.
Harry K
  #98
Old December 5th 07, 03:37 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Jim Logajan
Could be. Or the optic nerve does something equivalent to a two-dimensional
Fourier transform on images and filters the high frequency components out.
(I believe many lossy image compression algorithms use an equivalent
technique. E.g. JPEG.)
  #99
Old December 5th 07, 03:38 AM posted to rec.aviation.piloting, rec.aviation.homebuilt
Tina
Nice call, I can understand that now.
Thanks
Dan
  #100
Old December 5th 07, 03:44 AM posted to rec.aviation.piloting, rec.aviation.homebuilt
Harry K
HEHEHE!
looking away.
I was curious if one-eyed people see the spin. Yep. My wife is, and
I am 1/2 vision in one. Of course a simple experiment by closing one
eye (either of mine) and it still rotates. I can see it either
direction, blinking usually changes it.
Back in the 60s I was at a remote site co-located with a radar site.
It had one big antenna formed from open meshwork. I could not tell
which direction it was rotating even though I _knew_ it was clockwise.
Harry K
Spinner strobing as a "Bird Strike Countermeasure" Jim Logajan Piloting 259 December 13th 07 05:43 AM
Saturday 072807 in Oshkosh Pt 6 - Warbird show pix I forgot to post earlier [10/33] - "Bird Dog.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 10:48 PM
"British trace missile in copter strike to Iran" Mike[_7_] Naval Aviation 8 March 10th 07 08:20 PM
Bird strike Bob Chilcoat Piloting 5 September 6th 05 07:05 AM
Bird strike Jase Vanover Piloting 16 May 17th 05 11:44 AM
