#91
Mxsmanic wrote in
: Jeff Dougherty writes: The only custom-built military version of the Baron was the T-42A Cochise, used by the U.S. and Turkey. Everyone else who used it (mostly sundry African nations) seems to have bought off the shelf from Beech. A quick look at pretty much any photo of the T-42 reveals that it is equipped with regular seats, the only special feature of which appears to be upholstery. I didn't think it very likely. How would you eject from a Baron anyway? Explosive panels directly over your head? Presumably. The canopies of fighter jets are probably stronger than the roof over the head of the pilot in a Baron, so if those canopies can be blown clear or sliced, so can the roof of the Baron. Your idiocy grows day by day. soon you will be in a universe of stupidity all your own... Well done. Bertie |
#92
"Viperdoc" wrote in
: I now have about 500 hours in my Baron, and of course have studied them extensively. The military model ejection seat was in fact an early version of the MB7, made by Martin Baker. They consisted of a cannon shell to eject the pilot, co-pilot, and rear seat passengers through the roof of the plane, as you suggested. Once the cannon shell fired, a rocket charge ignited, clearing the seat and rider from the plane, and contained an automatically opening chute, with an attached raft and survival kit, similar to the ACES-II seat. Each seat weighs around 600 lbs. It's use has been credited with saving many Baron crews over the years. Wow, I stand corrected. Did the cockpit face rearwards also? Like in Captain Scarlet? Bertie |
#93
Mxsmanic wrote in
: John Mazor writes: For someone who has spent so much time with computer programs, your grasp of logic is remarkably deficient. A simple exercise in set theory can disprove that all opinions are equal. Opinions are not abstract mathematical entities. Quite correct, but my opinion that the earth is round and that you are an asshole are both beyond reasonable discussion. Bertie |
#94
Mxsmanic wrote in
: John Mazor writes: Because you posit your opinions as though they had factual support equal to those of people who actually know WTF they're talking about. No, I do not. Yes, you do. That is the inference of others who interpret my lack of wimpy deference to the alpha dogs as some sort of aggressiveness. They have a tremendous emotional investment in everything they post and read; I do not. Because you don;'t know anything Bertie |
#95
Mxsmanic wrote in
news ![]() Ron writes: It doesn't matter. Flying is aviating in the air no matter what your aircraft is. No, sorry, it's apples and oranges. It's **** and shinola. Your ass and your elbow.. Flying a tin can doesn't qualify you to fly a fighter jet or airliner. Flying a fighter jet doesn't qualify you to fly an airliner or tin can. And so on. And you aren't qualified to fly a rubbr band powered stick and tissue model. Tell you what, you succesfully build and fly one and you can come back with a frsh opportunity to actually speak as someone who has aviated! But you won't.... Bertie |
#96
Mxsmanic wrote in
: B A R R Y writes: Neither do instrument pilots. Exactly. Nope. You don't have zero vis. You can hit "P", and get up and walk away. There is no connection between the two. That's right. Maybe we're getting through after all. Bertie |
#98
#99
"Viperdoc" wrote in
: Actually, the rear seat passengers also faced to the rear, to work the avionics packages.. They generally consisted of a Sperry radar system capable of air to air detection, and this equipment weighed several hundred pounds as well. The original Baron was designed as a light recon/attack aircraft, and mine still has the hard points for the addition of drop tanks, or two 500lb Mark 82 bombs under the wings. Later versions can carry either the AIM-9 infrared missile, or the AIM 120 AMRAAM. The associated radar package is mounted in the nose. A mean machine! Unlike the civilian version, the early military version of the Baron had twin Wright 18 cylinder R-3860 engines, each capable of producing over 800HP. This gave a top speed of over 350knots, burning 200gallons an hour. Wow, so cool! Were they the R-3860 W4N,s or the VW1109's? I hear the VW 1109s tended to overheat slightly when you used the galley. Did you keep it in the optional revetment under a retractable swimming pool? This is why I like flying my Baron- it has such a great military history, although it never gained wide spread acceptance. I'm surprised that it's history is not better documented, but it must be on the internet somewhere. Anthony must obviously be too pre-occupied to do the research on the plane that he claims to know so well. Obviously. I'm a little surprised at this, actually. His research is usually so thorough. Bertie |
#100
Mxsmanic wrote in
: writes: Maybe you can get VATSIM to require a diversion to some other unexpected airport at some random time during cruise, to spice it up. That is determined mostly by the weather, not VATSIM. Or, how about simulating an instrument failure, or loss of communications. Occasionally people simulate emergencies on the network; in fact, they have a lot more simulated emergencies on the network than you would expect in real life, especially improbable things like multiple jet engine failures. However, these are often the kiddies on the network who have the wildly improbable emergencies. I simulate emergencies about as often as they occur in real life, and so I have yet to simulate an emergency thus far. Oh, and BTW, in one night last week, I had a pack failure on one airplane which required a descent, then an alt hold problem (only in VNAV, so it was manageable just by reverting to alt hold) and then a windscreen fire on another airplane on the next sector. All in well maintained airplanes, BTW, not dogs. I've had six engine shutdowns (four actual failures and two precaurtionaries) just in turbines, and about the same number in pistons, some in singles. So, if you want to argue with me you're going to have to up the failure rate a bit. Oh wait, you never argue with me. wonder why? Bertie |
Frustrated with finding flight sims | [email protected] | Simulators | 8 | March 14th 05 09:33 PM |
Av mags and sims.... | Don Parker | Simulators | 7 | August 11th 03 05:48 PM |
A few thoughts on Flight Sims | Don Parker | Simulators | 6 | August 1st 03 06:19 PM |
A few questions about Flight Sims and equipment | Dave Pearson | Simulators | 0 | July 29th 03 09:05 AM |
