#91
Peter Dohm wrote:
"Dudley Henriques" wrote in message ... Capt. Geoffrey Thorpe wrote: "Bertie the Bunyip" wrote in message .. . wrote in : ... The typicl spin accident, if there is such a thing, is the famous overcooked turn onto final. I watched two guys die after doing that on a tight, low, turn to a short final... Geoff What gets them isn't really the turn per se, but the way that turn is flown. The combination of the increased stall speed due to the turn coupled with some excess inside rudder causing a skid as the stall breaks is a perfect pro-spin setup. The two ingredients for spin are present; stall and a yaw rate coupled simultaneously . You can get away with a tight low turn if it's coordinated and you feed in enough power to offset the drag rise; or even better yet an unloaded tight descending turn if some altitude and some radius need to be scrubbed off,(I don't recommend doing these BTW :-) but it's that lack of attention to the extra needed thrust as the drag rises in the turn and cheating a bit with inside rudder to "force that nose around that will get you killed. -- Dudley Henriques Since I probably qualify as hopelessly unqualified, and also since both of you have already described this in different words, I should probably "keep my mouth shut"; but from all I have heard, things happen much more suddenly as part of an uncoordinated accellerated stall. I never personally got to explore the accellerated stall portion of the envelope, and only had an accellerated stall demonstrated to me once. That once was by a pilot who was so proficient, smooth and coordinated that the stall was a complete non-event and we simply flew out of it and continued the turn as though nothing had happened. And, yes, this was in a Cessna 152 that was appropriately certified for that sort of work. However, viewed in another manner, the guy (who was a high time instructor) would have been the perfect candidate to train new instrucors to let their students kill them... When I resume flying, as I plan to do, I also plan to more fully explore the accelerated stall area of the envelope--in an appropriate trainer of course. Peter Good idea. Reason for this is that the majority of accidental stall incidents will be accelerated. It takes a pilot seriously asleep to gently allow an airplane to stall accidentally at power off and 1g. Accelerated stall is an area of flight that all pilots should be completely familiar with. I spent MUCH more time with accelerated stall than simple power off stalls at 1g with every student I taught to fly. I only wish all instructors did the same. -- Dudley Henriques |
#93
![]() "Dudley Henriques" wrote: better yet an unloaded tight descending turn if some altitude and some radius need to be scrubbed off,(I don't recommend doing these BTW :-) Why not, Dudley? This is a maneuver I use quite often because I like to make power-off landings. Am I on the verge of augering in without realizing it? -- Dan T-182T at BFM |
#94
Dan Luke wrote:
"Dudley Henriques" wrote: better yet an unloaded tight descending turn if some altitude and some radius need to be scrubbed off,(I don't recommend doing these BTW :-) Why not, Dudley? This is a maneuver I use quite often because I like to make power-off landings. Am I on the verge of augering in without realizing it? Good question. Let me explain. In posting on the forums where student pilots might be involved, when discussing things like unloaded descending turns from base to final, I try not to post comments without a "warning" of some kind. The reason I do this is that although well trained pilots can and indeed make turnds like this all day long in perfect safety, they are still in the category of a tight turn made at low altitude and I don't want anyone getting hurt trying to something based on what I have said on a forum. Becoming capable to make a turn like we are discussing is part of a pilot's training that should be accomplished in the airplane with a competent instructor there on the job to make sure the pilot learns how to make such a turn properly. Once this is accomplished, most pilots won't even think about making that turn. They will know from where they are in the pattern, how tight the turn has to be, and whether or not the conditions are within safe parameters or outside safe parameters. In other words, it's safe enough if done properly as I'm sure you are aware, but only after a thorough examination of the factors involved. Just as an aside; I always covered late base to final turns with my own students before solo! -- Dudley Henriques |
#95
![]() wrote in message ... I went over to the student board a while back. Someone, who I believe was not yet even a student pilot, was all on about how spins should not be allowed because they were too dangerous to be taught. That's a complete and total crock. Getting ready to go do them again for the CFI rating. I did them during my private training, but it was so long ago and not for a rating that theoretically they could fail me because we didn't wear parachutes. Aww...bummer. Have to go have fun in a C-152 again. During my Commercial checkride the examiner said that instructors need to put more emphasis on stall entry recognition and spin avoidance since, often as not, spins occur during departure or approach at altitudes far to low for spin recovery to occur. -c |
#96
![]() "Ron Wanttaja" wrote in message This spin entry was different. There I was, about a seventy-degree left bank, pulling hard on the stick to impress my buddy in the back seat, and WHAM. Ol' N1660G snapped to the right, went inverted, and tucked into a whirling dervish of an upright spin. Wow! I had spin training working on my PPL too, but if that happened to me my first time out with pax, I wonder if I'd ever gotten back on that horse. Needless to say, your practice paid off. -c |
#97
On Jan 17, 5:27*pm, Stefan wrote:
A half flick to inverted, followed by a half loop downwards. Obviously there was still some slip present, because suddenly, at 45 degrees pitch, just where the G load starts to build, that pretty landscape in front of me disappeared and all I saw was a blurry, undefined and rotating green disc. You did in that Fox out of a split-S what I almost did in the Starduster out of a loop. The difference is that the Starduster is a biplane with the wings set slightly differently (if it's rigged right) and so after you stall the top wing, you get a little time to recognize it before you stall the bottom wing. If you're sloppy enough to stall the bottom wing too, and you are even slightly uncoordinated, you're going for a ride. As an aside - I would love to fly a Fox if I could do it without having to purchase one or join a club. Where can they be rented? Surprize, I can tell you! One second or even two went by before I understood what was going on. Maybe another second to recognize to wich side the disc was rotating. And maybe a third second to sort out which foot to use. Yeah, well, that's why there's an order of magnitude difference between enough altitude for an expert to do acro safely and a novice to learn it safely. The actual recovery then was a non event, and I succeeded even to hit the axis. But since that experience I strongly believe that the usual spin demonstration (1,2,3, yank that stick back and stomp onto the pedal) is pretty much useless to prepare a pilot for that accidental spin. Well, maybe. I would argue that having practiced the recovery still has some value. How much? Well, probably not enough to subject oneself to the risk of being 'taught' to do it by someone who isn't really prepared either. Actually, I'll go a step further. I would argue that the usual stall demonstration is no more useful for preparing a pilot for that accidental stall. But see, this is where instructor experience comes in. An experienced pilot who has experimented with the edges of the envelope will have, as a minimum, flirted with inadvertent stall. Maybe an inadvertent spin as well. When that kind of instructor pilot does spin training, the risk isn't really there (which is why the aerobatic training record is pretty clean). At that point, I think an intro to spins, limited as it is, is justifiable. Michael |
#98
Michael schrieb:
As an aside - I would love to fly a Fox if I could do it without having to purchase one or join a club. Where can they be rented? Depends on where you're living :-) I know some in different places in Europe, however if you should happen to live on the other side of the pond, a search through the glider sites listed at SSA's should help. I know from earlier internet searches that two operators in Phoenix have been renting aerobatic gliders (Arizona soaring a Fox, Turf soaring a Swift) but I'm sure there are more. |
#99
Now, while it may be the case that the airplane will recover in that condition, that is speculation to me and anyone else until proved otherwise in a fairly dangerous experiment in test piloting. I think I see the disconnect here. My Cherokee is one of those planes that is placarded for spins in the Utility Category only. It's there for good reason. As the CG moves aft towards the back end of the Utility envelope, the spin tends to flatten on about the 3rd or 4th turn. The thing to remember is that this placard is directed at intentional spins. That's entirely different from the certification standards in Part 23 (or CAR 3, for older planes) that the plane must be able to recover from a 1 turn spin in the Normal Category. I wouldn't consider it speculation, since the factory was required to demonstrate the capability in a loaded airplane during certification. The only light single that I know of that has not passed spin testing during certification is the Cirrus. The reason I think that getting some spin training is a good idea is because the experience will probably help the pilot recognize what is going on while the spin is still in the incipient phase. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200801/1 |
#100
"JGalban via AviationKB.com" u32749@uwe wrote in
news:7e69c4aa98ddd@uwe: wrote: Now, while it may be the case that the airplane will recover in that condition, that is speculation to me and anyone else until proved otherwise in a fairly dangerous experiment in test piloting. I think I see the disconnect here. My Cherokee is one of those planes that is placarded for spins in the Utility Category only. It's there for good reason. As the CG moves aft towards the back end of the Utility envelope, the spin tends to flatten on about the 3rd or 4th turn. The thing to remember is that this placard is directed at intentional spins. That's entirely different from the certification standards in Part 23 (or CAR 3, for older planes) that the plane must be able to recover from a 1 turn spin in the Normal Category. I wouldn't consider it speculation, since the factory was required to demonstrate the capability in a loaded airplane during certification. The only light single that I know of that has not passed spin testing during certification is the Cirrus. No, there have been a lot of them over the years. Criteria, IIRC is that if it can't spin, you don't have to prove it;'s capability! Not that that stopped a guy I knew from trying everything he could to get a no pedals Ercoupe to spin! Bertie |
spins from coordinated flight | Todd W. Deckard | Piloting | 61 | December 29th 07 01:28 AM |
Any Spins Lately?? | Ol Shy & Bashful | Piloting | 28 | September 6th 07 10:22 PM |
Slips and spins in FSX? | Chris Wells | Simulators | 0 | December 14th 06 08:24 PM |
Spins in Libelles 301 & 201 | HL Falbaum | Soaring | 9 | February 10th 04 06:12 PM |
Thanks for the Spins Rich | David B. Cole | Aerobatics | 17 | October 26th 03 08:37 AM |
