#91
#92
terry writes:
You see the fact that the volume of the atmophere or of space is infinite is quite irrelvant because nobody wants to know what the average density of the whole atmophere is ( which of course will approach zero depending on your definition of where the atmsophere actually ends). It is very highly relevant. If you increase the temperature of the atmosphere, for example, the pressure does not rise, because nothing constrains the atmosphere--it simply expands. Atmospheric pressure comes from gravity, which is a constant, and not from any constraints applied to the volume of air, of which there are none. In the highest portions of the atmosphere, the temperature rises to several thousand degrees, but the pressure remains extremely low. At the surface, you might see variations in absolute temperature of 1/3, but you won't see variations in pressure anywhere near that magnitude. |
#93
WingFlaps writes:
So how do you explain the rather well known lapse rate? It depends on which lapse rate you have in mind. Solar heating at the surface produces a static temperature gradient, the environmental lapse rate. Light to which the atmosphere is transparent is absorbed at the surface and converted to heat. Part of this is reradiated, but at lower frequencies that may be reflected or absorbed by the atmosphere, the rest heats the air at the surface directly by conduction. So, overall, the air is always warmest at the surface. There are some anomalies higher in the atmosphere. Parcels of air that rise in the atmosphere will cool as the pressure in the atmosphere drops, and this is responsible the adiabatic lapse rate. In both cases, the correlation is between temperature and altitude, not temperature and pressure. |
#94
Mxsmanic wrote:
writes: Neither the atmosphere of the Earth nor the universe are infinite. We don't know if they are infinite or not. Babbling nonsense. Current estimates are the universe is about 160 billion light-years in diameter. If the universe isn't infinite, nothing in it can be either. -- Jim Pennino Remove .spam.sux to reply. |
#95
Mxsmanic wrote:
terry writes: You see the fact that the volume of the atmophere or of space is infinite is quite irrelvant because nobody wants to know what the average density of the whole atmophere is ( which of course will approach zero depending on your definition of where the atmsophere actually ends). It is very highly relevant. If you increase the temperature of the atmosphere, for example, the pressure does not rise, because nothing constrains the atmosphere--it simply expands. Atmospheric pressure comes from gravity, which is a constant, and not from any constraints applied to the volume of air, of which there are none. In the highest portions of the atmosphere, the temperature rises to several thousand degrees, but the pressure remains extremely low. At the surface, you might see variations in absolute temperature of 1/3, but you won't see variations in pressure anywhere near that magnitude. Nope. The ideal gas law doesn't apply over the entire Earth's atmosphere because the entire atmosphere isn't in equilibrium. It does apply locally where equilibrium can be approximated. In the highest portions of the atmosphere, the ideal gas law has significant error because the molecular size becomes significant, in which case one must use something like the van der Waals equation. -- Jim Pennino Remove .spam.sux to reply. |
#96
#97
Mxsmanic wrote:
WingFlaps writes: So how do you explain the rather well known lapse rate? It depends on which lapse rate you have in mind. Solar heating at the surface produces a static temperature gradient, the environmental lapse rate. Light to which the atmosphere is transparent is absorbed at the surface and converted to heat. Part of this is reradiated, but at lower frequencies that may be reflected or absorbed by the atmosphere, the rest heats the air at the surface directly by conduction. So, overall, the air is always warmest at the surface. There are some anomalies higher in the atmosphere. Parcels of air that rise in the atmosphere will cool as the pressure in the atmosphere drops, and this is responsible the adiabatic lapse rate. In both cases, the correlation is between temperature and altitude, not temperature and pressure. Nope. Air molecules don't have altimeters to tell them the altitude. -- Jim Pennino Remove .spam.sux to reply. |
#98
Mxsmanic wrote in
: writes: Neither the atmosphere of the Earth nor the universe are infinite. We don't know if they are infinite or not. I do, send me $25 and I'll tell you. Bertie |
#99
Mxsmanic wrote in
news ![]() terry writes: You see the fact that the volume of the atmophere or of space is infinite is quite irrelvant because nobody wants to know what the average density of the whole atmophere is ( which of course will approach zero depending on your definition of where the atmsophere actually ends). It is very highly relevant. If you increase the temperature of the atmosphere, for example, the pressure does not rise, because nothing constrains the atmosphere--it simply expands. Wow, a truly magnificent lack of understanding of how weather works to add to all the other dumb feathers in your tinfoil hat. Bertie |
#100
Mxsmanic wrote in
: WingFlaps writes: So how do you explain the rather well known lapse rate? It depends on which lapse rate you have in mind. The one which states that as the temperature rises, the two molecules in your head take a siesta. Bertie |
yrb-49-taxi.jpg | [email protected] | Aviation Photos | 2 | September 25th 07 09:50 PM |
Hanoi Taxi | john smith | Piloting | 0 | April 27th 06 03:48 AM |
License To Taxi? | SteveT | Piloting | 29 | October 16th 05 04:57 PM |
Leaning for taxi | Jim Rosinski | Piloting | 28 | September 12th 04 03:53 AM |
taxi in reverse? | [email protected] | Owning | 20 | February 21st 04 12:26 AM |
