Thielert (Diesel Engines)
Old February 16th 08, 04:40 PM posted to rec.aviation.owning,rec.aviation.piloting
Capt. Geoffrey Thorpe
Default Thielert (Diesel Engines)
"Capt. Geoffrey Thorpe" The Sea Hawk At Wow Way D0t C0m wrote in
news:rPqdneICDN7xgSvanZ2dnUVZ_i2dnZ2d@wideopenwest .com:
Oh dear, My opinion of you has increased form non existent to having
noticed you're alive.
What? I'm supposed to be all happy about that or something?
You aren't just clueless, you're mxclueless...
Geoff
  #93
Old February 16th 08, 05:17 PM posted to rec.aviation.owning,rec.aviation.piloting
Bertie the Bunyip[_25_]
news:X9ydncJRLrhkjCranZ2dnUVZ_gednZ2d@wideopenwest .com:
No, you're not supposed to be anything.
You really know how to get to my insecurities, don't you?
Bertie
  #94
Old February 17th 08, 03:42 PM posted to rec.aviation.owning,rec.aviation.piloting
"WingFlaps" wrote in message
On Feb 16, 12:01 pm, Bertie the Bunyip wrote:
"Capt. Geoffrey Thorpe" The Sea Hawk At Wow Way D0t C0m wrote f.
Can you actually name any common rail diesel (in any application) that
will run without the computer?
Nope. I know the older common rail ones didn't have an electronic
computer, but the thielert does.
In the first common rail engines, wasn't it a hydraulic (rather than
mechanical cam) system that controlled the injector valve?
They are electro-hydraulic. The high pressure injectors are triggered by the
mid pressure hydraulics which are triggered by solenoid valves controlled by
the engine computer. There ain't no mechanical backup - no way - no how. So,
a common rail diesel is 100% dependant on electricity to run. Just like your
Lycoming which won't run if the mags don't send enough electrons to the spark
plug at the right time with NO mechanical backup - no way - no how.
Geoff
  #95
Old February 17th 08, 04:22 PM posted to rec.aviation.owning,rec.aviation.piloting
Stan Prevost
I haven't really been following this thread, but I thought I would interject
something I just learned about Thielert diesels.
A local flight school which also rents out airplanes, just got a DA42
Twinstar. An engine quit during a flight a few days ago. The pilot shut it
down, then later attempted a restart. It started back up and ran fine for a
few minutes, then quit again. No anomalous indication on any of the engine
instrumentation.
Turns out that an oil filter in a gearbox, I believe it was, was clogged.
The computer senses that and shuts the engine down. No warning, no
indication of trouble, just shuts it down, or takes it down to very low
power. Saves the engine in preference to the pilot. This seems to not be a
rare event with these engines.
"Charles Talleyrand" wrote in message
This data is from 2006, they Thielert has not released a 2007 annual
report yet.
The annual report for Thielert, which makes diesel engines for certain
single-engine Cessnas, Pipers, and Diamonds, shows an increase in
sales of aircraft engines from 22 million Euros to 31 million Euros.
That's a 44% increase. It's probably over 1000 engines in total.
They are the third largest piston engine maker in the world (which
surprises me, I would have thought Lycoming, Continental, and Rotax).
The total market for piston aircraft engines is about 13,000 including
both new planes and the larger replacement market.
They aim to sell helicopter engines in 2009.
The best quote from the annual report: "We aim to achieve a market
share in piston aircraft engines of over 50% in the medium term. The
necessary demand and customer base are already in place."
Maybe diesel engines are catching on??????
  #96
Old February 17th 08, 04:37 PM posted to rec.aviation.owning,rec.aviation.piloting
WingFlaps
On Feb 18, 4:42*am, "Capt. Geoffrey Thorpe" The Sea Hawk At Wow Way
What engine computers were used in the 1940's and 1950's?
Cheers
  #97
Old February 17th 08, 05:31 PM posted to rec.aviation.owning,rec.aviation.piloting
Ford PROCO. Texico was working on one in the 50's also, but I don't recall
the name. Can't recall the others.
What COMMON RAIL diesels were made in the 1940's and 1950's?
Can you name a single COMMON RAIL diesel that didn't have a computer?
Geoff
  #98
Old February 17th 08, 07:21 PM posted to rec.aviation.owning,rec.aviation.piloting
Morgans[_2_]
Yep; Ford tractors! g
  #99
Old February 17th 08, 08:14 PM posted to rec.aviation.owning,rec.aviation.piloting
WingFlaps
On Feb 18, 6:31*am, "Capt. Geoffrey Thorpe" The Sea Hawk At Wow Way
No need to shout, I know we are talking about common rail engines.
Now, I'm not sure that thermoinic valve computers were ever used on a
diesel engine but I don't recall hearing of any computer on a 1950's
Cummins PT or even a 1940's Cooper Bessemer.
Cheers
  #100
Old February 17th 08, 08:41 PM posted to rec.aviation.owning,rec.aviation.piloting
that will run without the computer?
by the mid pressure hydraulics which are triggered by solenoid valves
controlled by the engine computer. There ain't no mechanical backup -
no way - no how. So, a common rail diesel is 100% dependant on
electricity to run. Just like your Lycoming which won't run if the
mags don't send enough electrons to the spark plug at the right time
Two injectors per cylinder, are there?
Apples and oranges, sunshine..
Bertie
Thielert (Diesel Engines) Charles Talleyrand Piloting 108 February 19th 08 04:59 PM
diesel 160-200HP engines geo Home Built 27 April 2nd 04 04:27 PM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Home Built 3 September 13th 03 12:44 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M General Aviation 2 September 13th 03 12:44 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Rotorcraft 2 September 13th 03 12:44 AM
