I need to trace an IP address
Old April 24th 08, 06:10 AM posted to rec.aviation.piloting
Dudley Henriques[_2_]
Default I need to trace an IP address
Does anyone have a means to trace to t least a general location the
following IP address?
72.191.163.46
Many thanks
Dudley Henriques
Old April 24th 08, 06:59 AM posted to rec.aviation.piloting
Jim Logajan
72.191.163.46
Many thanks
Probably somewhere in Texas - possibly Houston area (could be way out in
the countryside though). Obviously can't be sure. It's an IP address
belonging to RoadRunner, according to the DNS authority section. The
reverse DNS lookup yields the name:
cpe-72-191-163-46.elp.res.rr.com
Traceroute from my location a few moments ago terminated at:
gig0-1.elpstxh5-ubr2.elp.rr.com
The traceroute went through what appears to be a router in the Dallas area
and then possibly in Houston, based on guesses from probable host name
conventions used by RR.
Maybe someone with better tools and info can provide more accurate info.
What makes you interested, if I may ask?
Old April 24th 08, 07:06 AM posted to rec.aviation.piloting
72.191.163.46
Many thanks
Thanks for the feedback. I'm on a Mac and I don't have a DOS prompt.
After I posted I found the Network Utility with a Ping and Traceroute
Tab, so I just got the same data you did. Looks like Texas.
Reason is nothing sinister really; curiosity about a Usenet prankster.
Dudley Henriques
Old April 24th 08, 09:00 AM posted to rec.aviation.piloting
Stefan
Fire up Terminal.app and you'll a much more powerful tool: a Unix
prompt. ;-)
Old April 24th 08, 09:03 AM posted to rec.aviation.piloting
Jay Maynard
elp == El Paso.
No, but you do have a Unix command line: it's in Applications/Utilities/
Terminal.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC (ordered 17 March, delivery 2 June)
Old April 24th 08, 09:43 AM posted to rec.aviation.piloting
Michael Henry[_2_]
If you're using OS-X you've got something much, much better than a "DOS"
prompt. You've got a proper UNIX shell!
Old April 24th 08, 11:10 AM posted to rec.aviation.piloting
WingFlaps
72.191.163.46
Many thanks
Use terminal and all the rich tools of UNIX are at you disposal.
Cheers
Old April 25th 08, 06:19 AM posted to rec.aviation.piloting
Martin Hotze[_2_]
uhh .. oohh.
then use the shell that came with your OS (terminal).
#m
Old April 25th 08, 01:39 PM posted to rec.aviation.piloting
uhh .. oohh.
#m
Found it. Getting used to a new OS after switching from a PC :-)
Dudley Henriques
Old April 24th 08, 01:22 PM posted to rec.aviation.piloting
72.191.163.46
Many thanks
Thanks everybody who answered . I have it sorted out.
Dudley Henriques
"British trace missile in copter strike to Iran" Mike[_7_] Naval Aviation 8 March 10th 07 08:20 PM
Convert StrePla trace to IGC without StrePla? Jeremy Zawodny Soaring 5 January 11th 07 04:20 PM
Pegasus/TRACE Launch Photos Posted Brian Webb Military Aviation 0 February 21st 04 03:50 PM
Web address for TEAM??? DL152279546231 Home Built 4 January 14th 04 04:53 PM
Trace files for Minden, NV area in IGC WSViewer format Jerome Conners Soaring 1 December 2nd 03 04:55 PM
