#91
Michael Ash wrote in
: In rec.aviation.student Gezellig wrote: Michael Ash pretended : In rec.aviation.student Gezellig wrote: On Fri, 30 May 2008 01:20:04 -0500, Michael Ash wrote: Joking aside, if your straps were loose enough that you could slump forward, that *would* affect your CG which would in turn affect your trimmed airspeed. There's another issue that I just thought of that I don't think anyone has mentioned yet, though. Won't you get into a graveyard (bad terminology for this scenario, as you're already dead) spiral? After all, if you could stay straight and level just by taking your hands off the controls you wouldn't need to fear IMC with no gyroscopic instruments. So it seems that if you start high enough, the correct answer to this question would be whatever the terminal velocity of your fuselage is without its wings. Am I off base here? You fly until gassless, stall, nose down, then descend too rapidly, striking the ground with the wings ripped off. Works for me. You don't stall, because when the engine quits the airplane will start to descend, maintaining approximately the original airspeed. At what point do you expect to lose the wings via "the correct answer to this question would be whatever the terminal velocity of your fuselage is without its wings."? If you enter a spiral dive as I surmised, the wings fall off either when you exceed Vne or when you exceed the maximum loading the wings can support, whichever comes first. However it would seem that whether this happens or not will depend on the airplane in question. Well, the wings won't come off as you exceed VNE. You have a good 10% on top of that before anything will happen. Something nasty will at the load limit, though. Not the published one, of course, but at 50% over that. At the published load limit you are guarunteed that the airplane will not permanently deform. 50% over that you're guaunteed it will remain in one piece. Over that you're on your own. It;s not quite as tidy as all that, though and with most light planes it's probably flutter that's going to pull it apart and that will probably be brought on by a combination of load and speed. This is not to say it's safe to operate at or near the red line or load limit. It isn't. Bertie |
#92
Michael wrote in
: On May 30, 6:25*pm, Dudley Henriques wrote: I would respectfully disagree. An Extra 300, as do most high performance aerobatic airplanes has neutral static stability, but your vanilla Cessna or Piper with dihedral is designed with positive static stability in mind. The positive static stability, when present, is slight. More to the point, it is only slightly positive around the zero point. Once an excursion in roll gets past a few degrees, the stability is negative (for a while) and the new stability point is in a significant bank (or non-existent). As for dynamic stability, it really isn't much of a factor in lateral stability. The ailerons if mass balanced around the hinge line by weight, and if comparatively free in movement, usually assure that the pure lateral movement is heavily damped. And that's the point. Dynamic stability is generally mildly negative, and once a slight displacement from zero occurs, the restoring force from the mild positive static stability starts a very mild oscillation that will eventually take you outside the area of positive static stability. Once that occurs, dynamic stability is indeed no longer important. Even a plane with comparatively good lateral stability will eventually wind up in a spiral once something like turbulence disturbs it. In some cases it won't happen - combine a very stable plane with very smooth air, and it might fly wings level for a long time. It has happened. Also note that the stability improves with lower weight (this is true of the longitudinal axis as well - that's why the allowable cg range on most light airplanes is wider at lower weights) so we do have these stories of planes without pilots flying just fine for hours. I recall one particular sad incident where a Pilatus Porter dropping jumpers lost the yoke - it literally came off in the pilot's hands. The pilot elected to bail out (which was, IMO, the wrong call - a plane can be landed with rudder, throttle, and trim). His parachute malfunctioned, and the pilot died. The plane eventually ran out of fuel and 'landed' in a field. After a few minor repairs, it was flown out. These things do happen, but they are the exception. Under most normal conditions, the combination of neutral or weakly positive static stability and negative dynamic stability in the lateral axis will eventually put the plane into a spiral. Remember, we're dealing here with a dead engine. I'm still going to stick with the spiel :-)) that says with a light GA airplane with positive lateral stability built in with the normal dihedral found on such airplanes and the engine dead, we're going to need a source for an outside the system force strong enough to offset the countering dihedral to any roll input to initiate the roll or yaw (or coupling if you wish) that would end up with the aircraft banked enough to counter the dihedral correcting it back into the normal phugoid I'm expecting. Sure - but that source will be found in the normal turbulence found on most days. There are also additional factors. First off, any side-by-side airplane with only one person on board is going to be slightly out of balance laterally. Any plane with fuel feed from a single wing tank, or a less-than-perfect 'both' feed (which is most of them) will develop an imbalance. So what we need to postulate is a plane that is tandem seating with a header tank (like an old-style Champ or maybe a Cub) and then, on a really smooth day, it might actually stay wings level. If the aircraft has dihedral, it has positive static lateral stability. That's not necessarily the case. There can be other factors that affect stability that would overcome a small amount of dihedral. Remember that most airplanes have strong yaw stability, and that weakens roll stability because yaw and roll are strongly coupled. That's interesting. I never knew that. A pretty good primer on stabilit y issues can be found he http://selair.selkirk.bc.ca/aerodyna...ity/Page5.html I know the site. His stuff is generally very good. I do have some very minor issues with his presentation on a few things. I also like the site. The particular link includes much of what I posted, including the assertion that most light planes left to themselves will wind up in a spiral. Of course as you mentioned elsewhere, this isn't the sort of discussion you would have with the average FAA ops inspector. I knew a couple who would have appreciated it in Houston. Neither one is still with the FAA. Yeah, sadly this is true. I'm just reading up to renew my instructor cert and have been reading some of the circulars on the FAAs website. Most of them are excellent, but I was just reading one about stalling cross controlled, for instance and it's crap.. Having said that, I suppose it's all good enough for basic private knowledge.. Fortunately, the examiner falls into the pragmatic category. Bertie |
#93
BTW, just about any old ragbag will fly around like a free flight airplane
until they run out of gas. For that matter so will most cessnas and the like. Bertie |
#94
On Jun 4, 9:38*pm, Michael Ash wrote:
In rec.aviation.student Gezellig wrote: Michael Ash pretended : In rec.aviation.student Gezellig wrote: On Fri, 30 May 2008 01:20:04 -0500, Michael Ash wrote: Joking aside, if your straps were loose enough that you could slump forward, that *would* affect your CG which would in turn affect your trimmed airspeed. There's another issue that I just thought of that I don't think anyone has mentioned yet, though. Won't you get into a graveyard (bad terminology for this scenario, as you're already dead) spiral? After all, if you could stay straight and level just by taking your hands off the controls you wouldn't need to fear IMC with no gyroscopic instruments. So it seems that if you start high enough, the correct answer to this question would be whatever the terminal velocity of your fuselage is without its wings. Am I off base here? You fly until gassless, stall, nose down, then descend too rapidly, striking the ground with the wings ripped off. Works for me. You don't stall, because when the engine quits the airplane will start to descend, maintaining approximately the original airspeed. At what point do you expect to lose the wings via "the correct answer to this question would be whatever the terminal velocity of your fuselage is without its wings."? If you enter a spiral dive as I surmised, the wings fall off either when you exceed Vne or when you exceed the maximum loading the wings can support, whichever comes first. However it would seem that whether this happens or not will depend on the airplane in question. If the plane is in a steady dive at 2x VNE what is the wing loading? VNE may be set by srface instability (flutter) or perhaps engine overspeed but is not set by wing loading -that is Va -at least that's my understanding. Cheers |
#95
More_Flaps wrote in
: On Jun 4, 9:38*pm, Michael Ash wrote: In rec.aviation.student Gezellig wrote: Michael Ash pretended : In rec.aviation.student Gezellig wrote: On Fri, 30 May 2008 01:20:04 -0500, Michael Ash wrote: Joking aside, if your straps were loose enough that you could slump forward, that *would* affect your CG which would in turn affect your trimmed airspeed. There's another issue that I just thought of that I don't think anyon e has mentioned yet, though. Won't you get into a graveyard (bad terminolog y for this scenario, as you're already dead) spiral? After all, if you coul d stay straight and level just by taking your hands off the controls yo u wouldn't need to fear IMC with no gyroscopic instruments. So it seems that if you start high enough, the correct answer to this question would b e whatever the terminal velocity of your fuselage is without its wings. Am I off base here? You fly until gassless, stall, nose down, then descend too rapidly, striking the ground with the wings ripped off. Works for me. You don't stall, because when the engine quits the airplane will start to descend, maintaining approximately the original airspeed. At what point do you expect to lose the wings via "the correct answer to this question would be whatever the terminal velocity of your fuselage is without its wings."? If you enter a spiral dive as I surmised, the wings fall off either when you exceed Vne or when you exceed the maximum loading the wings can support, whichever comes first. However it would seem that whether this happens or not will depend on the airplane in question. If the plane is in a steady dive at 2x VNE what is the wing loading? VNE may be set by srface instability (flutter) or perhaps engine overspeed but is not set by wing loading -that is Va -at least that's my understanding. That's right, but the tendency to flutter is exacerbated by load. So, if you're over redline and you're loading the wing, flutter will occur at a lower speed than if that surface was unloaded. Flutter is all to do with the elastic properties of the flight surface, so if it's loaded up you're exciting the cycle. Bertie |
#96
Michael wrote:
I recall one particular sad incident where a Pilatus Porter dropping jumpers lost the yoke - it literally came off in the pilot's hands. The pilot elected to bail out (which was, IMO, the wrong call - a plane can be landed with rudder, throttle, and trim). His parachute malfunctioned, and the pilot died. I'll file this under: "You know you're having a bad day when..." Hilton |
#97
on 6/4/2008, Dudley Henriques supposed :
http--soar.wichita.edu-dspace-bitstream-10057-754-1-t05045.pdf.webloc Linky no worky |
#98
In rec.aviation.student More_Flaps wrote:
If you enter a spiral dive as I surmised, the wings fall off either when you exceed Vne or when you exceed the maximum loading the wings can support, whichever comes first. However it would seem that whether this happens or not will depend on the airplane in question. If the plane is in a steady dive at 2x VNE what is the wing loading? VNE may be set by srface instability (flutter) or perhaps engine overspeed but is not set by wing loading -that is Va -at least that's my understanding. In a steady *spiral* dive the wing loading will be determined by your bank angle. I think you may have misread my sentence; I did not mean to imply that having the wings come off due to excess loading was in any way related to Vne, it's just due to an ever-tightening spiral, if you actually get into one and you reach the excess wing loading before you reach excess speed. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
#99
Michael Ash wrote:
In a steady *spiral* dive the wing loading will be determined by your bank angle. Can you prove that? (mathematically or non-mathematically) Hilton |
#100
In rec.aviation.student Hilton wrote:
Michael Ash wrote: In a steady *spiral* dive the wing loading will be determined by your bank angle. Can you prove that? (mathematically or non-mathematically) If it's steady, i.e. constant speed, then the loading will be equal to the arccosine of the bank angle, because you need to generate 1 gee straight up to counterbalance gravity. This is the same situation as a level turn, and the math and vectors should be discussed in any introductory book on flying. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
U.S. Navy Plans EPX Intel-Gathering Aircraft | [email protected] | Naval Aviation | 0 | February 23rd 08 02:38 AM |
FOI...lol... CFI oral? | gatt[_2_] | Piloting | 29 | January 5th 08 05:01 PM |
Q: Apple MAC Book (pro) with Intel core 2 duo running Windows XP plus soaring software | Ruud | Soaring | 1 | October 31st 06 01:02 AM |
INTEL BILL CON JOB | Cribsheet | Piloting | 0 | December 7th 04 05:40 PM |
