*********A DEFENCE FOR MXMORAN***********
Old March 9th 09, 01:13 AM posted to rec.aviation.piloting
Ibby
Default *********A DEFENCE FOR MXMORAN***********
His original statement was there are only a dozen or so switches and
buttons.
No, I believe his original statement related to those buttons which
are required for the pilot to manually control the aircraft and over
ride the active route in the Flight Management Computer and those
buttons are on the Mode Control Panel which is a portion of the panel
above the 'glass cockpit' and below the window. The overhead panel
and many other panels are NOT required during the majority of flight,
they are for pre-flight and engine starts. The majority of the
console between the pilot and his first officer are for radio,
navigation radios, TCAS, transponders, weather tracking controls,
autobrakes, passenger signs etc.
I keep posting this typical approach and landing of a real 747-400.
Whilst the FMC has the active route ATC require the pilot to retain
certain headings, altutude and speeds which are ALL entered via these
'dozen or so switches', watch it and you will see. This isn't coming
from my perspective or MXs but Boeings
http://www.youtube.com/watch?v=5ShBOtPiuNM
Ibby
  #92
Old March 9th 09, 01:22 AM posted to rec.aviation.piloting
Ibby
Some of us appear to have a very abbreviated sense of what is "right"
To posit that an airliner's Inertial Navigation System is "kinda like
GPS" is akin to stating that the aileron controls work like a steering
wheel! Neither approximation will get the ship safely to port.
Yours is a dangerous and irresponsible contribution.
The IRS system IS a system that provides positioning data of the
aircraft to the Flight Management Computer but is not as accurate as
modern GPS so my comments stand correctly. They perform the SAME
function but GPS use is more common now.
The 747-400 uses both an IRS and GPS data. NOTAMS will display which
countries are GPS certified. The Pilot must configure the Flight
Management Computer when flying over these countries so that the the
IRS positions aren't updated with an innaccurate GPS position
Ibby
  #93
Old March 9th 09, 02:45 AM posted to rec.aviation.piloting
buttons.
I believe the original discussion was about someone with no clue
finding the correct button to push to do a particular thing amongst
ALL the buttons one would see.
Jim Pennino
Remove .spam.sux to reply.
  #94
Old March 9th 09, 10:43 AM posted to rec.aviation.piloting
Mxsmanic
Ibby writes:
The IRS is more accurate over short distances and times, but the GPS is much
more accurate over long distances and times, whence the utility of using both.
GPS accuracy is not country-dependent, since it is a space-based system. I've
never heard of GPS certification for countries; can you point me to a typical
NOTAM for this?
  #96
Old March 9th 09, 09:24 PM posted to rec.aviation.piloting
Ibby
Jim Pennino
Remove .spam.sux to reply.- Hide quoted text -
- Show quoted text -
Yes that is correct Jim but then it very quickly changed because of
everyones attitude towards MX (rightly so at times) stating that his
aquired 'familiarisation' of a certain aircraft through a simulator/
game would have NO bearing on what sat forefore you on the real
flightdeck and this is where I stepped in to partially agreeing with
MX's views (not his methods of response as others here just talk back
in the same manner). I personally have FSX, a default installation is
pretty **** for aircraft systems and flightdecks to put it bluntly.
The default 747 bears virtually NO similarity to what is on a real 747
flightdeck with hardly anything modelled and most switches having NO
effect. Good quality payware aircraft like PMDG 747-400X HAS a
photorealistic 3D Cockpit which you can look around with the right pc
hardware (TrackIR). Every button, every switch, every panel, every
display on the glass cockpit IS the same as the real one. You can
Google for real images till your heart is content or use the official
Boeing sites or the likes of Airliners.net to compare sim to real.
Most ppl on this forum just denounce it bears ZERO resemblence to the
real flightdecks for which they model yet somehow the Trades
Description Act has yet to be brought in and these Vendor's prosecuted
for 'pretending' they bear a similarity.
Ibby
  #97
Old March 9th 09, 09:41 PM posted to rec.aviation.piloting
Ibby
GPS accuracy is not country-dependent, since it is a space-based system. *I've
NOTAM for this?
I am quoting from Angle of Attacks comprehensive video guide on the
FMC's POS REF page.
They state that the 'GPS NAV (ENABLE) button (Line Select 5 Right)
toggles the GPS position (default is on) 'as some countries do not
meet certain standards for GPS navigation', 'the GPS will then try to
correct an accurate IRS position with an inaccurate GPS position,
knowing what countries this happens in are part of the NOTAMS that a
pilot would get in his pre-flight with dispatch'. I wasn't aware of
this either so it would need looking into if you're curious
  #98
Old March 9th 09, 10:45 PM posted to rec.aviation.piloting
Maxwell[_2_]
"Ibby" wrote in message
news:37ca905f-4782-461c-9453-
You're even more lame than Mxie
  #99
Old March 9th 09, 10:47 PM posted to rec.aviation.piloting
Maxwell[_2_]
As the blind leads the blind.
  #100
Old March 10th 09, 12:20 PM posted to rec.aviation.piloting
Mxsmanic
Ibby writes:
FMC's POS REF page.
I suspect Angle of Attack (which I have for the 767) has got something wrong
or isn't stating something clearly. While it is possible to jam GPS locally,
in the absence of jamming, the accuracy of GPS is the same just about
everywhere, although it declines slightly near the poles (but not over any
specific country).
[email protected] Glenn Alderton[_2_] Aviation Photos 14 January 5th 07 02:35 AM
UK Defence Shakeup Ian MacLure Military Aviation 0 July 22nd 04 03:40 AM
U.S. pilot has new defence Otis Willie Military Aviation 0 June 30th 04 10:50 PM
Bulldozing US Homeland Defence. Tamas Feher Military Aviation 44 June 13th 04 10:12 PM
USA Defence Budget Realities Stop SPAM! Military Aviation 17 July 9th 03 02:11 AM
