Why not use the F-22 to replace the F/A-18 and F-14?
Old February 22nd 04, 05:54 AM
Tony
Default Why not use the F-22 to replace the F/A-18 and F-14?
"R. David Steele" wrote in message
They are planning to bring the FB-22 (bomber
version that carries 30 2000 lbs bombs) online in the future.
And to think that the B2 only carries 16 2000 lb bombs.
Old February 22nd 04, 06:18 AM
Ragnar
Umm, not 30 x 2000 lb bombs. 30 x SDBs (small diameter bombs), that weigh
about 265 lbs each.
Also why not market the C-17 to the air freight community?
Because the C-17 couldn't compete in the mainstream commercial air freight
business. Costs way too much when compared to 747s and such.
Old February 22nd 04, 06:19 AM
Ragnar
"Tony" wrote in message
news:QoXZb.12374$lQ2.9128@okepread02...
Yes, but when the SDB comes on board, it will carry about 150.
Old February 22nd 04, 07:44 AM
John Keeney
Should we be thinking of using the FB-22 Raptor as a replacement
for the F/A-18 (and the F-14)? I know that the current F-22 was
not designed to be heavy enough for naval use, but it could be
re-engineered. They are planning to bring the FB-22 (bomber
Why not upgrade it then?
There are stresses from carrier ops that just aren't allowed for
in the design of Air Force fighters, mainly having to do with the
landing and arrestment. Unless the plane is designed with these
forces from the start, you basically have to redesign the plane's
frame (which means moving dang near *everything*) to get it
ready.
This way there would be cross over between the FB-22 and the F-35
(engines especially).
The C-17 was marketed to commercial users with the government
offering incentives. The plane has design elements for its
military missions that make it less economical to operate in
the civilian world that civil designs.
Old February 22nd 04, 07:57 AM
fudog50
The Tomcat is gone quicker than you can think....
There is a big push by CNO to axe the F-14 sooner than planned, like
now is too late...watch and see.
The F/A-18 (I assume you mean the B/C/D models) already has a
replacement, E/F. I don't think you are following current Naval
Aviation very well.
There is no need to replace the E/F Hornet, it will be pulling
fighter/CAP/FAC/Bomber/tanker etc. duties for the next 10 years.
Totally capable of performing all the above, with no current or future
enemy threat that can match it.
On Sun, 22 Feb 2004 04:20:49 GMT, R. David Steele
Old February 22nd 04, 08:01 AM
fudog50
Sorry forgot to add the Jamming/SEAD/Harm shooter duties on the EF-18G
(growler) as well....
Aviation very well.
Old February 22nd 04, 12:18 PM
John Carrier
Old February 22nd 04, 12:22 PM
John Carrier
Not as easy as it sounds, re-engineering usually involves rather extensive
redesign of the internal structures. The F-111 was designed multi-service
from the get-go and we all know what a raging success the B model was.
Do you really believe a fighter will carry 60,000 pounds of ordnance or is
that a typo?
R / John
Old February 22nd 04, 01:58 PM
Thomas Schoene
The Navy looked at adapting the original F-22 under the Naval Advanced
Tactical Fighter program in the late 80s and early 90s. The work needed for
the conversion was too much and the design ended up being basically the same
engines and avionics in a new aircraft. For example, they needed swing
wings to get the aproach speed down to carrier limits.
The FB-22 strikes me as having some real problems in carrier compatability,
even compared totthe base F-22. What's the approach speed of a heavy tailess
delta like that, for example?
Tom Schoene Replace "invalid" with "net" to e-mail
"If brave men and women never died, there would be nothing
special about bravery." -- Andy Rooney (attributed)
Old February 22nd 04, 02:44 PM
Andrew C. Toppan
We already have a replacement for the F-14 in service - the F/A-18E/F.
The switch-over is well underway already.
Since the F/A-18E/F is brand new, it won't need replacement for a long
time yet.
30x2000 pound bombs? Twice the payload of the B-2....very impressive.
Because you can't just "upgrade" the aircraft to be carrier capable.
This was studied a long time ago. The "upgrade" would be a complete
redesign of the aircraft, which would be very expensive and time
consuming, and entirely unnecessary.
Andrew Toppan --- --- "I speak only for myself"
"Haze Gray & Underway" - Naval History, DANFS, World Navies Today,
Photo Features, Military FAQs, and more -
http://www.hazegray.org/
Replace fabric with glass Ernest Christley Home Built 38 April 17th 04 11:37 AM
Why not use the F-22 to replace the F/A-18 and F-14? Guy Alcala Military Aviation 265 March 7th 04 09:28 AM
Why not use the F-22 to replace the F/A-18 and F-14? Guy Alcala Naval Aviation 2 February 22nd 04 06:22 AM
RAN to get new LSD class vessel to replace 5 logistic vessels ... Aerophotos Military Aviation 10 November 3rd 03 11:49 PM
Air Force to replace enlisted historians with civilians Otis Willie Military Aviation 1 October 22nd 03 09:41 AM
