#101
On Tuesday, February 26, 2013 11:14:14 AM UTC-5, Bill D wrote:
However, there is a difference between airplanes and gliders WRT the T&B. An airplane T&B displays a "standard rate turn" (2 minutes per 360 turn) as two needle widths. (Needle on the "doghouse" for the old guys.) That's 6 times too sensitive for a glider where the typical turn rate is 20 seconds per turn. Turns to a heading are much easier with an airplanes slow turn rate. It's interesting to see how the TruTrak is marketed on the Cumulus website. He raises the "standard turn rate" issue. http://www.cumulus-soaring.com/trutrak.htm |
#102
On Tuesday, February 26, 2013 3:46:37 PM UTC-7, son_of_flubber wrote:
On Tuesday, February 26, 2013 11:14:14 AM UTC-5, Bill D wrote: However, there is a difference between airplanes and gliders WRT the T&B. An airplane T&B displays a "standard rate turn" (2 minutes per 360 turn) as two needle widths. (Needle on the "doghouse" for the old guys.) That's 6 times too sensitive for a glider where the typical turn rate is 20 seconds per turn. Turns to a heading are much easier with an airplanes slow turn rate. It's interesting to see how the TruTrak is marketed on the Cumulus website. He raises the "standard turn rate" issue. http://www.cumulus-soaring.com/trutrak.htm I'm probably wrong saying 6 times too sensitive. A 1 minute T&B is the traditional glider instrument. However, think how large a 1 minute turn would be in a glider. |
#103
Just to answer a couple of questions
Cloud flying is permitted in Regional and National competitions in the UK as I type. This may change. The most common scenario for getting caught above cloud is when wave flying. I set a waypoint on the GPS away from the high ground, deploy full airbrake and trim to 55kts. From then on you can sit back and enjoy the ride. I know this works in wave conditions where the air is smooth. I have used it to descend in clear air, never had to use it for real. Everytime I have tried it the glider has started to gently spiral but remains stable as long as you keep your hands and feet clear of the controls. There is little turbulence to disturb the glider until you are below the wave, normally this means you are clear of cloud as well. The glider I used was an ASW17 with the double paddle airbrake mod. Flaps at +1 or zero |
#104
I just don't have faith in it and the slip ball seems never to be centered.
Maybe I'm just out of practice... :-) "Peter von Tresckow" wrote in message ... "Dan Marotta" wrote: Gyros are not disallowed except in competition (in the USA, at least). I have a functional J-8 attitude indicator in my hangar but it's too heavy and power hungry to install in my panel. Not to mention that I've already stated my firm intention to stay out of clouds. I'd be a lot happier with the attitude indicator than I am with the TruTrak. I'm not at all impressed with it. "Alan" wrote in message ... In article son_of_flubber writes: "son_of_flubber" wrote in message snip ...Why not equip gliders (with a turn and bank indicator) and pilots (with training) to safely handle a few minutes of cloud flying if it is a non-zero possibility On Monday, February 25, 2013 10:50:52 AM UTC-5, Dan Marotta wrote: That's a pretty naive question. Pretty much ALL of my questions are naive due to my lack of much experience and training. It's good for me to reminded of that from time to time. Thanks for your answer. I would agree and disagree with Dan about this. Obvious reasons include expense (gyros are expensive), weight, and power. The training would probably be a big deal as well -- the single engine private pilot requirement is for 3 hours of flight training in manuvering solely by reference to instruments. Even so, the record of accidents after non-instrument rated pilots wander into weather is not good. I think that few would want to mandate these instruments be in gliders. On the other hand, I have read postings describing sudden rain encounters that forced a pilot to suddenly and unexpectedly have to fly by instrument reference, in conditions where visibility had been substantial (perhaps 15 miles) a few instants before. I can see where a running gyro instrument in the panel could be a useful safety instrument for the glider pilot who was also an instrument competent airplane pilot. I would not want to see such be required, but it pains me to see situations where such capability would be disallowed. Alan Dan just out of curiosity, what about the trutrack don't you like??? Pete |
#105
Maybe, just for kicks, I'll try that in my LAK-17a at the end of a wave
flight. "Bill D" wrote in message ... On Tuesday, February 26, 2013 9:47:24 AM UTC-7, Dan Marotta wrote: "Bill D" wrote in message ... On Monday, February 25, 2013 5:04:31 PM UTC-7, Dan Marotta wrote: Way back when, I tried the "benign spiral" in my LS-6a. I found it to be dynamically unstable in pitch and, after a few cycles without touching the stick, it was ready to loop or break Vne. Did you use full dive brakes? To tell the truth, I don't recall - probably not. I think I used the published (in Soaring) procedure but I don't remember if it called for full dive brakes. My understanding of the "benign spiral" is the air brakes MUST be open to stabilize the glider and prevent over speed. |
#106
At 00:20 27 February 2013, Dan Marotta wrote:
Maybe, just for kicks, I'll try that in my LAK-17a at the end of a wave flight. "Bill D" wrote in message ... On Tuesday, February 26, 2013 9:47:24 AM UTC-7, Dan Marotta wrote: "Bill D" wrote in message ... On Monday, February 25, 2013 5:04:31 PM UTC-7, Dan Marotta wrote: Way back when, I tried the "benign spiral" in my LS-6a. I found it to be dynamically unstable in pitch and, after a few cycles without touching the stick, it was ready to loop or break Vne. Did you use full dive brakes? To tell the truth, I don't recall - probably not. I think I used the published (in Soaring) procedure but I don't remember if it called for full dive brakes. My understanding of the "benign spiral" is the air brakes MUST be open to stabilize the glider and prevent over speed. A couple of years ago I was in a particulars UK comp called Enterprise I was enjoying the comp and making up the numbers and every one new Justin Wills was going to win ,former world champion and he understands the rules. Could flying is permitted and I know Justin cloud flys because I watched him disappear above .Next day while grid squatting I made a point of looking at Justin's panel ,no horizon but 2 turn and slip. For the many non Brits Enterprise was set up 30 years or so ago as an alternative to circuit racing ,the idea being to get as much out of the day as is possible and the following day Justin and the day winner do an extensive debrief explaining the desitions they made both routing and met so we can all learn and make better desitions .I recommend looking at there web site and you will be able to read the ethos more succinctly I hate this spell checker. |
#107
So what's the etiquette for cloud flying in comps? So here we are, four of us climbing happily at 4 kts under a great big towering cu, no more than 150 vertical feet of separation total. Conditions are poor up ahead but with another 3 or 4 thousand feet we can all make it to the finish with good speed and no further climbing. The first guy disappears into the fog. Now what? Just curious.
T8 |
#108
At 17:56 27 February 2013, Evan Ludeman wrote:
So what's the etiquette for cloud flying in comps? So here we are, four of= us climbing happily at 4 kts under a great big towering cu, no more than 1= 50 vertical feet of separation total. Conditions are poor up ahead but wit= h another 3 or 4 thousand feet we can all make it to the finish with good s= peed and no further climbing. The first guy disappears into the fog. Now = what? Just curious. T8 As you will know from my post I bottled,and it is a historic fact there was a mid air in cloud in a worlds back in the 60's I think David Innes was one it was re written in sailplane and gliding about 10 years ago .As I said enterprise is some what different so there is less chance you will be gaggle flying . Some one will explain I am sure but you need to announce you intentions and position on the comp frequency and change to cloud frequency and re transmit and if you have more courage than me wait till they call clear then off you go. Plonckers need not apply ,I consider anyone without a ATPL a ploncker. |
#109
The UK procedure when cloud flying is not to enter from below if somebody else has climbed into it until there is at least 500 ft separation. Then each calls out altitude (amsl) periodically to maintain separation.
It seems to work. No collisions in cloud since this and other procedures were introduced. FWIW, in my experience it is rare to be climbing in the same cloud as others anyway, but on the few occasions I have done it, it worked OK. Chris N |
#110
On Wednesday, February 27, 2013 3:53:37 PM UTC-5, Chris Nicholas wrote:
The UK procedure when cloud flying is not to enter from below if somebody else has climbed into it until there is at least 500 ft separation. Then each calls out altitude (amsl) periodically to maintain separation. It seems to work. No collisions in cloud since this and other procedures were introduced. FWIW, in my experience it is rare to be climbing in the same cloud as others anyway, but on the few occasions I have done it, it worked OK. Chris N How do you keep from getting hit by airplanes flying in the same cloud? Presumably IFR airplanes are flying in cloud. Curious UH |
| Thread Tools | |
| Display Modes | |
| Pulp Fiction, pt 3 - dare devil aces 1943 12.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | April 4th 07 02:54 PM |
| Pulp Fiction, pt 3 - dare devil aces 1934 01.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | April 4th 07 02:54 PM |
| Mounting a turn coordinator on the tail? | Tim Auckland | Instrument Flight Rules | 25 | August 6th 06 07:16 PM |
| Is a Turn Coordinator an electric motor or powered by fan? | kickinwing | Piloting | 5 | June 11th 05 01:25 PM |
| Opening up a turn coordinator | Robert M. Gary | Piloting | 2 | March 27th 04 07:52 AM |
