#101
Stubby,
Once enough time has elaspsed, the neurotic fears about nuclear energy is go away. Are you familiar with the term "half-life"? Assuming you are, compare the half-life of nuclear waste with that of human cultures you expect to safe-keep it. Then, think again about those fears. -- Thomas Borchert (EDDH) |
#103
On Tue, 19 Jul 2005 14:50:28 GMT, "Dudley Henriques"
dhenriques@noware .net wrote: wrote in message roups.com... ISTR there's only one company that still makes TEL (I think it's in the UK?) When they decide the cost isn't worth it, what then? Sure, the lower HP Lyc's and Cont's can probably run mogas without issue, but the higher HP turbo'd engines won't be so happy without lead. The FADEC mod being developed by Aerosance might be a solution for some engines by computerized ignition retarding, but that's not a cheap fix. Anyone read anything more about the coming end of avgas? Don't know about the small airplane folks, but the warbird guys are going to be mad as hell. We have the power back on a P51 now to 45 inches on takeoff because of the fuel restriction. Any lower and the damn airplane will be taking off at cruise power!! :-) Dudley henriques Pretty soon you'll be carrying as much water as fuel, or are you already using water injection? That is about the only thing I can think of, at present, that would allow going more boost. Actually, Ethyl Alcohol, which has a poor octane rating will raise the rating a few percent when mixed up to 10% with gas. Unfortunately it has a lot of side effects like disolving gaskets and removing protective coatings that make it an undesirable. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#104
On Tue, 19 Jul 2005 19:14:37 +0200, Martin Hotze
wrote: wrote: That's fine for new production & some retrofits, but what about all the Navajos/Twin Cessnas/Barons/etc. where re-engining would cost more than the aircraft? well, the best time to get rid of those 20-something year old planes with a 50 year old design and 100 year old steam gauges. why don't you still drive your car you had in your 60's? I still would be if it hadn't fallen apart back in the 60s. :-)) If it had over 50 to 60,000 miles it had made it well past the design limits. Remember that was the time of planned obsolescence. In the late 60s I had a Mustang that rusted out in less than 6 months. Ford would go half, but I had to use their body shop. I could get it done for less than that at the local body shop with no discount. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com #m |
#105
On Fri, 22 Jul 2005 07:56:49 +0200, Martin Hotze
wrote: "Morgans" wrote: modern European deisel automobile engines are not seen in the US Why is that? hm, maybe a uneducated guess: most (not all) Americans are not really into innovation, and most are not into anything being not "made in America". We purchase a high percentage of imported cars. Even our domestic cars have so many imported parts they now say, "assembled in America":-)). Most Americans don't have the need to travel outside of their country, so their point of view is most likely very America-centered (this also backed up with little to no information on what is going on on the other 70% of the world) The above it true from a social standpoint. . So everything coming from abroad is seen as bad. 30 years ago I'd have said yes, but now most of the imports are considered moving up to quality compared to US automobiles.. However, the car's name be it Honda, Toyota, or what ever does not indicate where it's made/assembled. It pretty much depends on the model. One might be assembled in Middle America and the other overseas. As to Diesel engines and fuel here in the states, the fuel, quite often has high sulphur content and the engines put out a lot of particulates. Between the two, this in general this has given diesel engines a bad name for being environmentally unfriendly even though examples exist that run clean. Many things keep the precision engines with good economy from being imported. Some run high compression and those develop nitrides from the high combustion temperatures. Quite likely some just don't figure it's worth the effort to go through the testing to be sold in the US. You will find that many of our engines run rich to keep the combustion temperature low and then have to pump air into the catalytic converter so the excess can be burned. At least a good portion of the reason for poorer mileage over here is due to some specific anti-pollution measure. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com #m |
#106
On Fri, 22 Jul 2005 18:26:10 GMT, "Mike Rapoport"
wrote: Yes and it is not just deciding which evil to combat (CO2, NOX, HC or SO2) but also how you decide to measure it. My understanding is that pollutants are measured and regulated by ppm which makes little sense. If car A emits 10ppm of some pollutant and car B emits 8ppm but car A uses 30% less fuel, then car A actually emits less pollutants than car B since the total amount of exhaust is 30% less. I've always wondered about the reasoning behind that as it just doesn't make sense. In some cases when they first started this and maybe even now, they reduced the ppm by actually increasing the total amount produced. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Mike MU-2 snip |
#107
On Sat, 23 Jul 2005 07:45:56 -0600, Newps wrote:
Martin Hotze wrote: On Fri, 22 Jul 2005 17:53:28 GMT, Don Tuite wrote: But you can't buy a new one in the state. and what about Canada? are there any new diesels available? you still can go up there and import one. Maybe. The pollution laws are different and we have much stricter laws than Canada. Any car/truck you import will have to meet the smog and safety rules we have here. For American cars/trucks sold in Canada probably not that big a deal. You'd want a new speedometer head as they use that stupid metric system up there. That's why they make felt marking pens. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#108
On Sun, 24 Jul 2005 05:58:43 -0400, Cub Driver
wrote: On Sat, 23 Jul 2005 11:50:09 -0700, Sylvain wrote: the cars there seem to have both markings on their speedometer So do those sold "here" -- in the U.S. It's been that way for twenty They do? I drive a Toyota 4-Runner and it only has MPH. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com years, it seems to me, though it may be because for twenty years I've only bought Hondas. -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net In Search of Lost Time: www.readingproust.com |
#109
On Fri, 22 Jul 2005 09:24:41 +0200, Thomas Borchert
wrote: Morgans, modern European deisel automobile engines are not seen in the US Why is that? The market is different. Nobody cares about gas consumption in the US. Everbody wants ridiculously BIG cars in the US, whereas European cars What would make you think that? Other than the "Hummers" and the really expensive *big* SUVs people are looking at mileage. The big problem here is people who drive into town 3 and 4 times a day taking their kids to soccer, hockey, baseball, foot ball, or some kind of practice. People are too independent to car pool. are mostly way smaller. And you guys have this obsession about "buying American". So you don't always get the best ;-) I drive an SUV, because it was the closest I could get to a combination car and pick up truck. The thing is half full, or more, most of the time. OTOH I only make a few trips into town a week and those are generally to the airport. I combine those trips into stops at the hardware store, computer store, Lowe's, Home Depot, etc... I may even pick up a sub on the way home. BTW the SUV is imported and gets as good a mileage as any car I've driven so far. It's a long ways from my wife's Chrysler Mini, mini van though. She gets close to 40 in all around driving. OTOH with nigh onto 200,000 miles it's almost time to bury the thing. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#110
"Roger" wrote in message
... [...] If car A emits 10ppm of some pollutant and car B emits 8ppm but car A uses 30% less fuel, then car A actually emits less pollutants than car B since the total amount of exhaust is 30% less. I've always wondered about the reasoning behind that as it just doesn't make sense. In some cases when they first started this and maybe even now, they reduced the ppm by actually increasing the total amount produced. I assume the laws are the way they are because the auto manufacturers want them that way. A test that measures absolute emissions would effectively be measuring the fuel efficiency of the car, along with the usual emissions control hardware. Instead, we have rules that require manufacturers to have a certain average fuel efficiency across their sold product, with each one having to meet specific relative emissions requirements. Putting a limit on absolute emissions would either mess up the way motor vehicles are sold in the US (since many vehicles just would never qualify), or it would allow high mpg vehicles to have unreasonably high emissions (along with every other kind of vehicle). The latter clearly doesn't make much sense if you're trying to improve air quality, while the former go against some very powerful lobbying. IMHO, the current system is actually pretty reasonable, and would be made much more reasonable with the use of high gas taxes. That is, measuring relative emissions ensures that all vehicles sold are playing at the same level (ignoring for a moment that different limits are applied to different vehicles ![]() emissions of pollutants. In other words, testing emissions is not directly related to trying to limit emissions. Rather, it's to ensure that all vehicles are producing about the same amount of pollutants for a given amount of fuel consumed. Now if we could just change the way fuel is consumed, we'd be in business. ![]() Pete |
Nothing like a cold splash of 100LL in the face to wake up a pilot | Peter R. | Piloting | 20 | October 1st 04 11:25 PM |
Future of 100LL? | Michael | Owning | 0 | August 2nd 04 09:29 AM |
Future of 100LL? | Michael | Piloting | 0 | August 2nd 04 09:29 AM |
How blue is 100LL? | Ben Jackson | Piloting | 26 | May 1st 04 11:10 AM |
When was the switch to 100LL? | Roger Long | Piloting | 0 | August 21st 03 11:01 AM |
