#101
"Matt Barrow"
But not, usually, to the pilot, and never to the pilot simply for declaring an emergency. Unless the declared emergency stems from a violation of the FAR's. Example? moo |
#102
Happy Dog wrote:
Not quite. If there's an accident with injuries An accident with injuries isn't an incident. You knew that, right? Mea culpa. You are correct. In the air, your first concern should be to get back on the ground ASAP. C'mon. *Think*. I am thinking. I'm thinking I'd rather not be responsible for a preventible death just because I was reluctant to declare an emergency. Or are you thinking that your first concern is flying the airplane? I consider that an understood. If that is your thinking, you're just being argumentative and contributing nothing here. If that isn't it, please enlighten me. -- Mortimer Schnerd, RN VE |
#103
"Mortimer Schnerd, RN" wrote in message
. com... The fellow may have been having a heart attack or a stroke... In the air, your first concern should be to get back on the ground ASAP. That will probably require priority treatment from ATC, so declare your emergency and get down. Yup. It's also a good idea, in the event of a passenger medical emergency, to request having medical personnel on hand when you land. --Gary |
#104
Thomas Borchert wrote:
Kev, For example, remember Swiss Air 111 that caught fire and then crashed off Newfoundland before they could land? (Basically because they followed the book and circled dumping fuel... so as not to be over landing weight... but the time wasted doing that killed them all.) Not so. The accident investigation showed that the time wouldn't have been sufficient even when going for a landing immediately. That doesn't mean to say they couldn't/shouldn't have acted differently. Frank, Tom, thank you for the update and correction. I should've looked up the accident report before adding that bit of melodrama. Did it turn out that it was the entertainment system wiring? I had almost gone to work for a company that designed them, and sometimes wondered how their engineers felt later on. shudder Best, Kev |
#105
Kev,
Did it turn out that it was the entertainment system wiring? I think so. Oh, and while in this case it may have been too late, I still agree with you that less "by the book" and more quick-and-dirty makes ssense in these kinds of emergencies. OTOH, hindsight is 20-20. -- Thomas Borchert (EDDH) |
#106
Matt Barrow wrote:
But not, usually, to the pilot, and never to the pilot simply for declaring an emergency. Unless the declared emergency stems from a violation of the FAR's. In that case, the pilot has not simply declared an emergency. The pilot has violated FARs. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
#107
![]() "George Patterson" wrote in message news:EQqIe.14414$2y2.11236@trndny02... Matt Barrow wrote: But not, usually, to the pilot, and never to the pilot simply for declaring an emergency. Unless the declared emergency stems from a violation of the FAR's. In that case, the pilot has not simply declared an emergency. The pilot has violated FARs. So every time a pilot violates the FAR's they must file a report? |
#108
Matt Barrow wrote:
"George Patterson" wrote in message news:EQqIe.14414$2y2.11236@trndny02... Matt Barrow wrote: But not, usually, to the pilot, and never to the pilot simply for declaring an emergency. Unless the declared emergency stems from a violation of the FAR's. In that case, the pilot has not simply declared an emergency. The pilot has violated FARs. So every time a pilot violates the FAR's they must file a report? I can come up with four different scenarios: 1) You clip class D without comms. You violated a FAR, but unless the Administrator (or rep) asks for an incident report, nothing is required. 2) You have a control fail just after takeoff from a towered airport, so (with or without declaring an emergency over the air) you turn back and land without clearance. You violated a FAR, but your emergency authority allows you to to deviate as necessary for the safe completion of the flight. A report is required for the control failure, but not required for the landing. 3) Same scenario as (2) (you have a major oil leak on takeoff and land again without clearance, say), but you were a student pilot and had a passenger. Oops. The emergency let you land without clearance, but you had (unrelated to the emergency) also busted a FAR. Report will probably be requested on just the FAR bust grin. 4) You overloaded your aircraft and/or in flight realized your W&B was so messed up that you had little control, and had to declare an emergency to land as quickly as possible. Ooops again. The FAR bust _caused_ the emergency to begin with. Scenario 4 is the worst case, of course. If breaking a FAR causes the emergency, your emergency powers can't protect you... nor can an ASRS form, if you deliberately overloaded the aircraft. (Let's say the passengers lied to you about their weight... that would mean you didn't deliberately screw up.) Cheers, Kev |
#109
Not quite. If there's an accident with injuries An accident with injuries isn't an incident. You knew that, right? Mea culpa. You are correct. In the air, your first concern should be to get back on the ground ASAP. C'mon. *Think*. I am thinking. I'm thinking I'd rather not be responsible for a preventible death just because I was reluctant to declare an emergency. Or are you thinking that your first concern is flying the airplane? I consider that an understood. That and, next, assessing the emergency and taking appropriate action. That might mean flying to an airport, right? :-) Seriously, though, I can think of a number of scenarios where getting on the ground ASAP is not the correct decision. So can you... moo |
#110
Happy Dog wrote:
That and, next, assessing the emergency and taking appropriate action. That might mean flying to an airport, right? :-) Seriously, though, I can think of a number of scenarios where getting on the ground ASAP is not the correct decision. So can you... I'm not suggesting an off-airport landing. The whole point of getting down quickly is to get the passenger to an ambulance ASAP. That means trying to land at an airport big enough to have a hospital nearby. As for assessing, didn't he already say the fellow went lights out for more than a minute? How much more information do you need to make a decision? I know I heard enough. -- Mortimer Schnerd, RN VE |
Pilots | Slick | Piloting | 4 | November 20th 04 11:21 AM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Piloting | 114 | July 22nd 04 05:40 PM |
F15E's trounced by Eurofighters | John Cook | Military Aviation | 193 | April 11th 04 03:33 AM |
Rwy incursions | Hankal | Piloting | 10 | November 16th 03 02:33 AM |
