Differences between automotive & airplane engines
Old February 10th 06, 01:26 AM
Chris Wells Chris Wells is offline
Senior Member
First recorded activity by AviationBanter: Oct 2005
Default Differences between automotive & airplane engines
How are "normal" airplane engines tuned to run at a lower rpm? What changes would have to be made to an automotive engine to shift the power band down accordingly?
Old February 10th 06, 04:13 AM posted to rec.aviation.homebuilt
short answer: give it cubic inches in a ratio of 2 to 3 times its rated
horsepower.
Old February 10th 06, 05:09 AM posted to rec.aviation.homebuilt
The most common way to move the "power band" into a useable prop rpm
range is to use a gearbox or PSRU. Most of the auto conversions I've
heard of utilize this approach.
Dave
Old February 10th 06, 05:37 AM posted to rec.aviation.homebuilt
Dear Chris,
They are not 'tuned' to run at lower rpms, they are DESIGNED to do so.
Indeed, although both are engines, in purely engineering terms they
have surprisingly little in common.
In mechanical terms the two main differences between variable-speed
engines, such as found in cars, and 'normal' aircraft engines are in
the cam timing and the sizing of the bearings. But you're really
looking at an entirely different engineering philosophy, in that with
an aircraft engine reliability is given a higher priority than any
other factor.
Another major difference is the ratio between nominal and peak power.
The service life of a car's engine is based on a nominal output equal
to about 25% (or less) of the engine's peak output. That is the level
of output the engine is expected to produce for approximately 98% of
its service-life. The only time it will be asked to produce more is
when accellerating or climbing a grade. By comparison, the nominal
output of an aircraft engine is about 70% of its peak (or take-off)
rating, dropping to about 55% if the objective is to achieve maximum
time between overhauls.
A major problem in the on-going contraversy about converting car
engines for use in airplanes is that most Americans are not well versed
in automotive engineering and the best example of that may be seen in
the comments produced any time an engineer uses the term.
'Automotive,' of course, means ANYTHING that moves under its own
power and 'automotive engineering' covers everything from the space
shuttle to motorbikes... unless you happen to be one of the millions of
superbly ill-educated Americans who use 'automotive' when they mean
'automobile.' This is far more than grammatical nit-picking, in that
it is impossible to carry on a meaningful dialogue without properly
defined terms.
A by-product of that lack of education is how Americans view
'horsepower,' typically insisting that 50hp (at 5000rpm) is EXACTLY THE
SAME as 50hp (at 1000rpm). Indeed, most will whip out their calculator
and 'prove' they are identical :-) But as the Wright brothers
discovered more than a hundred years ago, horsepower is not a factor in
the equation of flight. With powered flight, the factor we must
concern ourselves with most is thrust. Working back through the
equation, for a given propeller efficiency & rpm we will eventually
arrive at a given quanta of torque which then may be converted into
units of 'horsepower,' should we wish to do so, although it serves no
useful purpose. But when we DO use 'horsepower' we must be careful to
never use it in isolation, always identifing the rotational speed at
which that 'horsepower' is being produced.
And along about here someone will discover the simple solution of
putting a gear-train between the thing producing all that lovely
'horsepower' and the propeller producing all that necessary thrust.
Indeed, the more astute will point out that the Wright brothers did
exactly that, using an arrangement of bicycle chains as a a
torque-multiplier :-)
-R.S.Hoover
Old February 10th 06, 04:26 PM posted to rec.aviation.homebuilt
"Kyle Boatright" wrote:
"Alan Baker" wrote in message
In article .com,
Absolutely and utterly wrong.
It is *torque* which must always be associated with the rotational speed
at which it is being produced.
Alan Baker
Alan,
You do understand that if you know the HP at a given rpm, you can easily
calculate torque.
KB
Yes. But if you know torque without knowing RPM, you can't tell what
performance you can get out of an engine, but if you know horsepower,
you do know what performance you can get.
Alan Baker
Vancouver, British Columbia
"If you raise the ceiling 4 feet, move the fireplace from that wall
to that wall, you'll still only get the full stereophonic effect
if you sit in the bottom of that cupboard."
Old February 10th 06, 03:46 PM posted to rec.aviation.homebuilt
Read that first sentence again. He's not wrong; he just
didn't specify "torque" for those who don't know the relationship
between it and RPM and HP.
When you say "absolutely and utterly" it should be used
only where it applies. Clearly, that's not here.
Old February 11th 06, 03:10 AM posted to rec.aviation.homebuilt
On Fri, 10 Feb 2006 16:28:10 GMT, Alan Baker
In article .com,
But that's my point. He is absolutely and utterly wrong, when he says
that you need to know the rotational speed before you know all you need
to know when you know the horsepower.
With horsepower, you can use gearing to get any rotational speed you
want; the horsepower remains constant. Torque changes with gearing.
Yes, you CAN use gearing, at the expense of complexity.And efficiency.
Much better to design the engine to produce the power you need at the
speed you need it. However, sometimes you trade efficiency and
durability for weight - and a geared 1.2 liter 80 hp engine running
at 6000 RPM can weigh significantly less than a direct drive 2.7 liter
engine providing the same power at 2800 rpm. (well, about 40 lbs less,
anyway)
Newbie Qs on stalls and spins Ramapriya Piloting 72 November 23rd 04 04:05 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
automotive parts on airplane engines Wallace Berry Home Built 15 September 28th 03 02:55 AM
