Any traffic please advise
Old August 26th 06, 03:53 PM posted to rec.aviation.piloting
ET
Default Any traffic please advise
Matt Whiting wrote in
ET wrote:
"Dan Luke" wrote in
"Viperdoc" wrote:
Have to agree that "looking" in response to a traffic call is
reasonable. Saying "roger" makes it unclear as to whether you
actually have the traffic in sight.
Both responses are incorrect.
"Traffic in sight (the correct response) makes it very clear that you
OK, then what do YOU say to ack. the call, but you have not yet seen
the traffic????
If I haven't seen the traffic before the ATC call, I scan for 3-5
seconds. If I can't find the traffic after this time, I reply "ATC,
N12345, negative contact on the traffic."
Matt
Hrrm, well, I'm still a student pilot (2-2000 mile+ cross countries as a
pax handling the radio though with FF) but to me that just sounds like
"I looked for 3-5 seconds and gave up..."
-- ET :-)
"A common mistake people make when trying to design something
completely foolproof is to underestimate the ingenuity of complete
fools."---- Douglas Adams
  #102
Old August 26th 06, 03:55 PM posted to rec.aviation.piloting
Jose[_1_]
If I haven't seen the traffic before the ATC call, I scan for 3-5 seconds. If I can't find the traffic after this time, I reply "ATC, N12345, negative contact on the traffic."
You must not fly in busy airspace. In the Northeast, in 3-5 seconds the
traffic controller has vectored ten airliners, cleared two IFR
departures, and had lunch. Either you respond right away or you can't
get a word in edgewise.
Jose
The monkey turns the crank and thinks he's making the music.
  #103
Old August 26th 06, 05:08 PM posted to rec.aviation.piloting
Matt Whiting
ET wrote:
"Dan Luke" wrote in
the traffic????
Matt
It doesn't suggest I've stopped looking, it suggests I've been
unsuccessful thus far. It also allows the controller to have
confirmation that I received the traffic report.
Matt
  #104
Old August 26th 06, 05:09 PM posted to rec.aviation.piloting
Matt Whiting
I live and fly in the northeast and always have. The frequency isn't
any less busy 500 ms after the call than 5000 ms after the call.
Matt
  #105
Old August 26th 06, 05:10 PM posted to rec.aviation.piloting
Dan Luke
"Ron Lee" wrote:
Dan, what is your response when you have only had one-three seconds to
look and have not yet found the traffic? This happens often.
"Negative contact."
That is the proper response, straight out of the AIM.
I have been advised of the traffic and responded with a phrase that tells
the controller all he needs to know for the moment. When things change, the
controller can give me an update or I can report "traffic in sight."
Why people think they need to give controllers warm fuzzies about this is
beyond me. Whether you are looking or not is irrelevant to the controllers.
The only information that is useful to them is whether you see the traffic
or not.
Dan
C172RG at BFM
  #106
Old August 26th 06, 05:12 PM posted to rec.aviation.piloting
Alan Gerber
Peter R. wrote:
Everything discussed up to your post applies to IFR traffic advisories as
well. However, in the case of IFR traffic advisories, additional
instructions are most likely forthcoming the moment the pilot advises
traffic in sight, such as "cleared for the visual approach," "maintain
visual separation with the traffic, climb and maintain xxx," etc.
This can happen in VFR, too. As I mentioned in another post, after
reporting traffic in sight in the pattern, I'll get "cleared to land,
number three" or whatever.
.... Alan
Alan Gerber
gerber AT panix DOT com
  #107
Christopher C. Stacy
"Steven P. McNicoll" writes:
"Christopher C. Stacy" wrote in message
If you're in VMC, then you are persumed to be looking for traffic.
If you're in IMC, you're not going to be "looking".
What the controller wants to know is if you see it right now.
"Negative Contact".
Why aren't you going to be "looking" if you're in IMC?
Because you are "looking" at the panel and there is nothing to see outside but clouds?
  #108
Old August 26th 06, 05:14 PM posted to rec.aviation.piloting
Alan Gerber
Dan Luke wrote:
"Alan Gerber" wrote:
It depends. At the Class D airport where I fly, the controller won't
clear you to land behind somebody until you report them in sight.
Really??
Sure. "Cherokee NNN, number two to land, behind the Cessna on base",
followed by "Cherokee NNN, traffic in sight", gets me "Cherokee NNN,
cleared to land, number two". (With runway number added, of course.)
.... Alan
Alan Gerber
  #109
Old August 26th 06, 05:16 PM posted to rec.aviation.piloting
Alan Gerber
Larry Dighera wrote:
What you say is true, however I was referring to en route VFR radar
traffic advisory service.
Sure. But the conversation in general is about reporting traffic in
sight -- let's try to keep the big picture here.
The situation you describe on approach is a result of the controller's
necessity to separate IFR traffic which can be either radar separation
or visual separation.
Not in this case. This was VFR, in the pattern. No IFR traffic in the
mix. It's being driven by the controller's necessity to sequence the
traffic to the runway. (Let's not get into the other issue of separation
at Class D airports, OK?)
.... Alan
Alan Gerber
  #110
Old August 26th 06, 05:17 PM posted to rec.aviation.piloting
Jose[_1_]
The frequency isn't any less busy 500 ms after the call than 5000 ms after the call.
That's not my experience. When a controller is being rapid-fire, there
is a slight pause after his transmission wherein he expects a response.
That 500 ms is quieter.
Jose
