There are some mysteries that I've encountered while learning to read
VFR charts: 1. I see airports with dashed cyan circles around them that I presume indicate Class D airspace (based on the chart legend). However, the circles are not always the same size, and I don't see any indication of their radii; how do I determine how far out the Class D circle extends (short of measuring it by hand)? Also, is there a convention for the center of the Class D circle (tower, or whatever?)? They don't seem to be centered on anything easily identifiable. 2. The legend doesn't appear to explain lines that consist of a solid cyan line with cyan dots inside. It seems to outline things like wildlife refuges or parks and stuff like that. Is this just an extra line style used for things that don't otherwise have line styles assigned, or what? Are there any restrictions or other things to know about spaces enclosed by these lines, or are they for information only? 3. I'm confused about Class E airspace. If I understand correctly, the absence of any other indication on the chart means that Class E starts at 1200' AGL, and extends to 18,000' MSL. If the shaded purple border encloses an area, it's Class E starting at 700' AGL and still extending to 18,000' MSL. If it's a shaded cyan border, it means ... Class E starts at 1200' AGL and extends to 18,000' MSL?? (The chart says "abuts Class G," but I'm not sure what they mean.) 4. The cyan chain-link Class E border confuses me. Which side is inside the Class E? The altitude is the floor of the Class E and it still extends to 18,000' MSL, right? If there are different altitudes on each side of the chain link, what does that mean, and where do I look for the other border of the airspace? For example, just west of Buckeye on the Phoenix sectional, there are chain links and stuff all over the place, and I'm having trouble figuring out what the floors are and where. Around Western Sky airport (W 113° 40' N 33° 46' roughly), I see the shaded cyan border for Class E at 1200' AGL, but in that area I see 7000 MSL, and a chain link on the right and bottom. There are chain links next to airways, too. I don't know which altitude applies where. Can anyone explain the above to me? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote: There are some mysteries that I've encountered while learning to read VFR charts: 1. I see airports with dashed cyan circles around them that I presume indicate Class D airspace (based on the chart legend). However, the circles are not always the same size, and I don't see any indication of their radii; how do I determine how far out the Class D circle extends (short of measuring it by hand)? Also, is there a convention for the center of the Class D circle (tower, or whatever?)? They don't seem to be centered on anything easily identifiable. Dashed cyan is actually class E surface area. Class D surface is dashed blue. The configuration of the airspace depends on the instrument approaches at that airport. If you need to know the radius, you can measure it by hand, but I don't see how that information is useful for VFR navigation. You just need to know the boundaries of the airspace, not the radius from an aribtrary center location. 2. The legend doesn't appear to explain lines that consist of a solid cyan line with cyan dots inside. It seems to outline things like wildlife refuges or parks and stuff like that. Is this just an extra line style used for things that don't otherwise have line styles assigned, or what? Are there any restrictions or other things to know about spaces enclosed by these lines, or are they for information only? Yes that is the boundaries of wildlife refuges and national parks. You need to stay 2000ft above the terrain. This information can be found on the inside flap of the chart, not in the standard legend box. 3. I'm confused about Class E airspace. If I understand correctly, the absence of any other indication on the chart means that Class E starts at 1200' AGL, and extends to 18,000' MSL. If the shaded purple border encloses an area, it's Class E starting at 700' AGL and still extending to 18,000' MSL. If it's a shaded cyan border, it means ... Class E starts at 1200' AGL and extends to 18,000' MSL?? (The chart says "abuts Class G," but I'm not sure what they mean.) This is a very typical confusion. Class E begins at 700' inside the shaded magenta borders. It begins at 1200' inside the shaded blue borders. It begins at 14500' outside the shaded blue borders. Now, you may not see any shaded blue borders on your chart because you may be completely surrounded by it. So there is no way to know whether you are inside or outside these borders, but since the majority of the U.S. is surrounded by these blue borders it is safe to assume that you are inside. If you go to parts of western U.S. or coastal areas you will see the blue borders. The top of the class E is 18000' where class A begins. 4. The cyan chain-link Class E border confuses me. Which side is inside the Class E? The altitude is the floor of the Class E and it still extends to 18,000' MSL, right? If there are different altitudes on each side of the chain link, what does that mean, and where do I look for the other border of the airspace? For example, just west of Buckeye on the Phoenix sectional, there are chain links and stuff all over the place, and I'm having trouble figuring out what the floors are and where. Around Western Sky airport (W 113° 40' N 33° 46' roughly), I see the shaded cyan border for Class E at 1200' AGL, but in that area I see 7000 MSL, and a chain link on the right and bottom. There are chain links next to airways, too. I don't know which altitude applies where. In some areas it may not be useful to define class E as beginning at 1200' or 700' AGL because the terrain may be uneven, or there may be a need to define class E as beginning at something other than 1200 or 700. This is where the blue chainlink is used. It is hard to tell whether you are inside of ourside the line, but it should become apparent once you identify the boundaries. |
"Andrew Sarangan" wrote in message oups.com... Dashed cyan is actually class E surface area. Class D surface is dashed blue. Dashed cyan is a Class D surface area, a Class E surface area is dashed magenta. |
Andrew Sarangan wrote:
Dashed cyan is actually class E surface area. Class D surface is dashed blue. Cyan is blue-green. The other color is magenta (red-blue). |
Andrew Sarangan writes:
Dashed cyan is actually class E surface area. Class D surface is dashed blue. The legend on the chart I'm looking at says the opposite. Magenta dashed lines are marked as Class E; cyan dashed lines are marked as Class D. The configuration of the airspace depends on the instrument approaches at that airport. If you need to know the radius, you can measure it by hand, but I don't see how that information is useful for VFR navigation. You just need to know the boundaries of the airspace, not the radius from an aribtrary center location. It's just hard to figure out whether I'm inside or outside the boundaries without a radius and center point. IIRC, I need to contact the tower before entering the Class D space (?). Yes that is the boundaries of wildlife refuges and national parks. You need to stay 2000ft above the terrain. This information can be found on the inside flap of the chart, not in the standard legend box. OK, I found it in the fine print (I'm looking at SkyVector). This is a very typical confusion. Class E begins at 700' inside the shaded magenta borders. It begins at 1200' inside the shaded blue borders. It begins at 14500' outside the shaded blue borders. Now, you may not see any shaded blue borders on your chart because you may be completely surrounded by it. So there is no way to know whether you are inside or outside these borders, but since the majority of the U.S. is surrounded by these blue borders it is safe to assume that you are inside. If you go to parts of western U.S. or coastal areas you will see the blue borders. The top of the class E is 18000' where class A begins. OK, thanks, that clarifies things. In some areas it may not be useful to define class E as beginning at 1200' or 700' AGL because the terrain may be uneven, or there may be a need to define class E as beginning at something other than 1200 or 700. This is where the blue chainlink is used. It is hard to tell whether you are inside of ourside the line, but it should become apparent once you identify the boundaries. OK. I confess that I don't see the logic behind so many changes in Class E altitudes; some people at the FAA must have a lot of time on their hands. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote: Andrew Sarangan writes: Dashed cyan is actually class E surface area. Class D surface is dashed blue. The legend on the chart I'm looking at says the opposite. Magenta dashed lines are marked as Class E; cyan dashed lines are marked as Class D. Blue is class D and purple of class E. I was thinking of purple when you said cyan. I guess I have to go back and relearn my colors. |
Mxsmanic writes:
In some areas it may not be useful to define class E as beginning at 1200' or 700' AGL because the terrain may be uneven, or there may be a need to define class E as beginning at something other than 1200 or 700. This is where the blue chainlink is used. It is hard to tell whether you are inside of ourside the line, but it should become apparent once you identify the boundaries. OK. I confess that I don't see the logic behind so many changes in Class E altitudes; some people at the FAA must have a lot of time on their hands. I've assumed that the reason for doing this is to identify areas in which you can expect to find IFR planes. I would guess that you don't want to have IFR planes going through areas too low or far away from antennas to have radio communications with ATC. (Could someone correct me if my guess is wrong?) Chris |
Christopher Brian Colohan writes:
I've assumed that the reason for doing this is to identify areas in which you can expect to find IFR planes. I would guess that you don't want to have IFR planes going through areas too low or far away from antennas to have radio communications with ATC. (Could someone correct me if my guess is wrong?) Isn't IFR allowed in both Class E and Class G? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic,
Isn't IFR allowed in both Class E and Class G? Yes, but along an airway or and approach, IFR traffic is much more likely. -- Thomas Borchert (EDDH) |
I've assumed that the reason for doing this is to identify areas in which you can expect to find IFR planes. I would guess that you don't want to have IFR planes going through areas too low or far away from antennas to have radio communications with ATC. (Could someone correct me if my guess is wrong?) Not where you can expect to find IFR planes, but where you can expect NOT to find VFR planes if the weather is below minimums. |
| Thread Tools | |
| Display Modes | |
