#101
I snipped the true nonsense part, the "spiral down to death" thing.
Well, then it's not "utter and complete nonsense", there's just a somewhat nonsensical conclusion. And even that isn't "utter nonsense", as tail icing which is masked by an autopilot can =actually= cause a "spiral down to death". Mx has his flaws, but this group has taken to attacking everything he says, no matter whether it is totally wrong, somewhat wrong, or just has a spelling error, and also attacking him ad hominum. This is unacceptable behavior, and is also counterproductive (it increases noise). Not with all autopilots. Some S-Tecs don't use trim. True. One must be aware that one is or isn't using that kind of autopilot. The basic point however is still valid. Autopilots can hide a developing problem, sometimes leading to an unpleasant surprise. Jose -- "There are 3 secrets to the perfect landing. Unfortunately, nobody knows what they are." - (mike). for Email, make the obvious change in the address. |
#102
#103
Recently, Jose posted:
I snipped the true nonsense part, the "spiral down to death" thing. Well, then it's not "utter and complete nonsense", there's just a somewhat nonsensical conclusion. And even that isn't "utter nonsense", as tail icing which is masked by an autopilot can =actually= cause a "spiral down to death". One gets plenty of clues that something is going awry prior to this happening. If those clues are ignored... Mx has his flaws, but this group has taken to attacking everything he says, no matter whether it is totally wrong, somewhat wrong, or just has a spelling error, and also attacking him ad hominum. This is unacceptable behavior, and is also counterproductive (it increases noise). As I see it, the group treats everyone posting here with the same kind of scrutiny, and usually only becomes beligerent when they are grossly insulted, so in that light let's not overlook Mxsmanic's *many* insults to group members, explicit and implied. Not with all autopilots. Some S-Tecs don't use trim. True. One must be aware that one is or isn't using that kind of autopilot. The basic point however is still valid. Autopilots can hide a developing problem, sometimes leading to an unpleasant surprise. It appears that you are describing another form of pilot error. If one believes that they can set an autopilot and then take a nap, *that* is the problem, not the behavior of the autopilot. IMO, a pilot must understand the behavior of their equipment, be it FADEC, autopilots, aux fuel systems, or whatever. Given that so few accidents can be charged to the failure of these devices, it may be reaching to claim that some unreasonable level of danger is presented by their use. Neil |
#104
#105
#106
("Thomas Borchert" wrote)
Well, the FAA requires redundancy, Ford doesn't. At Ford ...Certification is Job 1 Montblack Built FAA Tough |
#107
group members, explicit and implied. Fine. Don't respond to him. But to take a statement that is =not= "utter rubbish" and call it that does disservice to the statement, and those reading it. That which =is= utter rubbish should be called that. But that which is only partly misleading, if it is responded to, should not be called "utter rubbish". Ignore a post you wish to ignore. But if one chooses to respond (that is, after all, a choice), then one should respond carefully and correctly. Autopilots can hide a developing problem, sometimes leading to an unpleasant surprise. It appears that you are describing another form of pilot error. Yes, it certainly would be a pilot error. But the underlying statement (which is the reason it would be a pilot error) is still correct. Autopilots =can= hide a developing problem. It is part of piloting to ensure that they are not successful in the attempt. Given that so few accidents can be charged to the failure of these devices, it may be reaching to claim that some unreasonable level of danger is presented by their use. It is "reaching" to claim that. Nonetheless, there is risk. Pointing that out is not "utter rubbish". It is the reason pilots can't get away with taking a snooze while George flies. Jose -- "There are 3 secrets to the perfect landing. Unfortunately, nobody knows what they are." - (mike). for Email, make the obvious change in the address. |
#108
![]() "Mxsmanic" wrote in message ... Morgans writes: The Continental has every injector controlled by two computers. The spark is controlled by a different computer for each cylinder, with each of the two plugs in the cylinder having a different computer. There are dual sensors of each type of sensor. There are two electrical systems for each set of computers. Everything is protected from lightning strikes, and the associated surges. Catastrophic failure is usually caused by software, not hardware. Absolutely not true by any stretch of the imagination. Another theme for the Twilight Zone. |
#109
![]() "Mxsmanic" wrote in message ... Thomas Borchert writes: Sure. And anytime you have that direct linkage, that linkage can fail catastrophically just the same. No. Direct linkages have very limited failure modes, none of which is usually catastrophic. Analog, physical systems rarely have catastrophic failure modes. Absolutely not true. |
#110
![]() "Montblack" wrote in message ... ("Thomas Borchert" wrote) Well, the FAA requires redundancy, Ford doesn't. At Ford ...Certification is Job 1 At Ford...a billion dollar loss per quarter is Job 1. Montblack Built FAA Tough |
Is this a Complex Plane? | [email protected] | Piloting | 12 | December 7th 05 03:19 AM |
Commercial rating: complex aircraft required aircraft for practical test? | Marc J. Zeitlin | Piloting | 22 | November 24th 05 04:11 AM |
Complex / High Performance / Low Performance | R.T. | Owning | 22 | July 6th 04 08:04 AM |
Experience transitioning from C-172 to complex aircraft as potential first owned aircraft? | Jack Allison | Owning | 12 | June 14th 04 08:01 PM |
Complex Aircraft Question | Chris | General Aviation | 5 | October 18th 03 04:40 AM |
