Confusion about when it's my navigation, and when it's ATC
Old January 3rd 07, 02:35 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Confusion about when it's my navigation, and when it's ATC
I fly from KLAX to KLAS, using the FMC to handle most of the flight.
With the routing I put in, the FMC decides on some default altitudes
and includes required altitudes for the arrival and departure
procedures I select. Part of what it does is to create a descent
schedule from the nominal cruise altitude to the arrival procedure.
So I leave KLAX and my last explicit instruction from ATC is "climb
and maintain FL290," which is my programmed and filed cruise altitude.
Now, my question is this: If the FMC has a programmed descent in its
route, do I let the FMC start the descent where it sees fit, or do I
force the aircraft to maintain FL290 until ATC explicitly clears me
for my own navigation or for a lower altitude? And if ATC's last
instruction had simply been "resume own navigation" or "proceed as
filed," would that mean that I'd be free to begin the descent whenever
the FMC (or I) decides it's best?
In situations where I can begin the descent at my discretion (assuming
that own navigation implies this), should I tell ATC that I'm leaving
my cruise altitude? If the FMC has a continuously changing estimate
of lower altitudes in the descent profile, what should I give as my
target altitude? The next fix that has a specific altitude? (Such as
a fix in the arrival procedure)
Climbing I think I understand. If I'm told to resume own navigation,
or cleared as filed in the first place, I climb per my flight plan/FMC
profile. If ATC says maintain X, I stay at X until ATC tells me to
resume own navigation or instructs me to change altitudes. But the
descent part still has me a bit confused.
Old January 3rd 07, 02:49 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
John Theune
Are you flying IFR? if so then ATC will tell you what altitude to be at.
Resume own navigation refers to routing not altitude. VFR is a
different set of rules.
Old January 3rd 07, 03:04 PM posted to rec.aviation.ifr
Jim Carter[_1_]
-----Original Message-----
Posted At: Wednesday, January 03, 2007 8:49 AM
Posted To: rec.aviation.ifr
Conversation: Confusion about when it's my navigation, and when it's
ATC
Subject: Confusion about when it's my navigation, and when it's
ATC
at.
He's not flying in the system, but rather he's trying to program his
flight simulator scenarios. This is a case of learning the mechanics
without understanding the system.
MS - why don't you get a copy of the instrument flying handbook or the
TERPS manual, or some other good text and learn the system? Every one of
the questions you've been asking are addressed in those and in the AIM
and FARs. These are the information sources that aspiring pilots use in
their pursuit of knowledge.
Old January 3rd 07, 03:42 PM posted to rec.aviation.ifr
JD
Online version of the AIM: http://www.faa.gov/ATPubs/AIM/index.htm
Old January 16th 07, 02:13 PM posted to rec.aviation.ifr
Jim Carter[_1_]
Posted At: Wednesday, January 03, 2007 9:42 AM
ATC
ATC
one of
AIM
in
"Page Not Found
Sorry, but the page you have requested has moved or no longer exists.
Please use the links provided below to find the resource you were
looking for:
Home
FAA Home"
Try
http://www.faa.gov/airports_airtraff...tions/atpubs/a
im/
Old January 3rd 07, 03:44 PM posted to rec.aviation.ifr
Mxsmanic
Jim Carter writes:
For instrument flight, they work the same way.
I have the IFR handbook, but it doesn't go into extreme detail for
phraseology, or I've missed it.
Every one of
So what do you discuss on rec.aviation.ifr?
Old January 3rd 07, 04:41 PM posted to rec.aviation.ifr
Paul Tomblin
Corner cases - cases where the rules say one thing and common sense says
another, where the rules seem to contradict each other, or things that
weren't covered in normal IFR training. It's not here to act as a
person's CFI-I.
Paul Tomblin http://blog.xcski.com/
Nazis are part of *every* government, everywhere, in all of human
history. They're just not always called that.
-- J.D. Baldwin
Old January 3rd 07, 05:12 PM posted to rec.aviation.ifr
Mxsmanic
Paul Tomblin writes:
person's CFI-I.
Are you the moderator?
Old January 3rd 07, 03:21 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
mad8
i wonder if his simulator's ATC tells him to hang himself he will? (one
can only hope)
Old January 3rd 07, 03:50 PM posted to rec.aviation.ifr
JD
can only hope)
MS, don't let post like this bother you. ANY interest in aviation is
good. Real pilots are in general one of the most POLITE bunch of people
you'd ever want to meet and hang out with. It's a a close knit
community. A lot of GA pilots like to hang out at the local airports
and do nothing but "hanger flying", i.e. sit around and talk about
aviation (and other topics).
Try it sometime, and join a local chapter of the EAA (experimental
aircraft association). You'll learn a lot more from talking to folks
than from reading posts like Mad's.
