Edwards air show B-1 speed record attempt
Old October 25th 03, 04:01 AM
Gene Nygaard wrote:
Based on our review, we made eight recommendations intended to improve
the use of the metric system within NASA in accordance with national
policy and NASA guidance. We recommended NASA:
• reexamine the Agency’s effort to convert to the metric system and
develop a new approach for converting to the metric system,
• closely monitor technical interfaces between metric and English
units,
• reinvigorate the metric waiver system, and
• use the metric system as the preferred system for interactions with
the public
Gene Nygaard
Sounds pretty official to me...
-Gord.
  #102
Old October 25th 03, 04:21 AM
John R Weiss
"Tarver Engineering" wrote...
If we left things alone, instead of being globalist egotistical loons, these
problems would not occur.
If we left things alone, we would not progress.
  #103
Old October 25th 03, 04:26 AM
John R Weiss
When we engage in industry, we must use the language of that industry, as
well as the existing infrastructure. A big part of training to do
engineering is to apply a reference and measurement system applicable to the
problem. Aerospace is expressed in feet, pounds, clockwise and attempts to
use alternative SI units have resulted in problems.
The aerospace industry developed first and foremost in the USA. Before there
was such a thing as "aerospace," the fuel and aviation industries evolved with a
preference for measuring liquid fuels such as gasoline and kerosene in gallons.
By your argument, aerospace should measure fuel in gallons.
  #104
Old October 25th 03, 04:45 AM
av8r
Hi
You all might want to read the story below about the Gimli Glider.
http://www.flightsafety.org.au/articles/t0357.php
Here's an extract from the above.
Cheers...Chris
The flight from Montreal to Edmonton, including a brief stop in Ottawa,
required 22,300kg of fuel, an amount expressed as mass because of the
importance of knowing an aircraft's weight.
The mechanics needed to work out how many litres made up 22,300kg. They
could then subtract the 7,682 litres already in the tanks, and use the
fuel gauge on the refueling truck to tell when they had reached the
right number of litres to make up 22,300kg.
But the 767 was the first aircraft in Air Canada's fleet to use metric
units (kilograms) rather than imperial (pounds). Metric units were being
phased in across Canada, and the conversions were still causing confusion.
With the help of First Officer Quintal, the ground crew used the correct
procedure to calculate the weight in kilos. However, they had not been
trained in correct conversion, so the figure of 1.76 provided by the
refueling company on their refueling document, was taken to be the
required multiplier. It was typical of the numbers seen on previous
slips and they assumed that the numbers provided over the previous few
months had indicated specific gravity in the new metric system.
They decided to multiply 7,682 by 1.76. This would mean 13,597kg
remained in the tanks, requiring an infusion of 8,703kg to bring the
fuel level up to 22,300kg. They then divided 8,703kg by 1.76, assuming
that this conversion would give them the correct volume in litres.
Through this calculation, the crew determined that 4,916 litres needed
to be added from the fuel truck.
The problem was that 1.77 is the multiplier that converts litres into
pounds, not kilograms: to convert litres into kilograms you need to
multiply by 0.8. Flight 143 did not have 22,300kg on board, it had about
10,000kg, less than half the amount of A-1 kerosene jet fuel needed to
get the aircraft to Edmonton. The refueller didn't know where the flight
was headed, so no alarm bells rang for him as he poured fuel into the tanks.
Using a computer to calculate fuel also caused confusion over
responsibilities. In the past, when fuel was calculated manually, a
flight engineer's duties included checking the fuel load. Flight
engineers were a thing of the past on this 767, as a Presidential task
force, under Ronald Reagan, had determined that aircraft could be built
to be operated by two pilots instead of three, if the tasks previously
given to the second officer (flight engineer) were either fully
automated or handled by ground staff.
Responsibility for ensuring adequate fuelling had passed to the
maintenance branch. But because these men were not trained to calculate
fuel, they assumed the pilots would make sure it was done properly.
The problem was neither of the pilots was trained in this technical
task. Safety procedures had failed to keep pace with new technology.
As the investigation later concluded: 'Air Canada ... neglected to
assign clearly and specifically the responsibility for calculating the
fuel load in an abnormal situation.'
The investigation attacked Air Canada's training procedures, noting
'both flight crew and maintenance personnel seemed to be somewhat
mesmerised by the complex, computerised characteristics of the 767. They
did not appear to have sufficient background knowledge of these aspects
of the aircraft. They did not appear to have received sufficient
training about some of the critical aircraft systems, in particular, the
fueling system.'
  #105
Old October 25th 03, 06:15 AM
Jim Thomas
Wait. How about the 100, 200, 400, etc. meter swim and track and field
races? Not to mention the world altitude flying records, which are in
meters. And more and more...
John Keeney wrote:
But nobody weighs things in "grams", it's always "kilograms".
Nor do the measure things in "meters" (as was stated concerning
building a house) they measure in "milimeters".
  #106
Old October 25th 03, 07:19 AM
B2431
snip
All fuel is bought as weight, that is how an aircraft works. The fact that
you pay for volume is a book keeper's issue.
I have never seen anyone buy avgas by weight for small GA aircraft like the
Cessna 172.
Dan, U. S. Air Force, retired
  #108
Old October 25th 03, 02:42 PM
Pat Norton
Tarver Engineering wrote:
Why change from the units of aerospace to some other arbitrary
set of units in the first palce?
That question does not parse. The problem is not a 'change' from setA
to setB. The problem is multiple units for the same thing. UnitX
coexists with unitY (and perhaps unitZ). You may wish to ask:
Q1. "Why do we want to reduce the co-existence of multiple units for
the same thing?"
Q2. "If that is what we want, then which ones should be eliminated in
which circumstances?"
The units of aerospace are controlled by Annex 5 of the ICAO Chicago
convention.
"The standardized system is based on the International System of Units
(SI) and will eventually eliminate the use of different units of
measurement for the same quantity and provide for the standardized
application of all units of measurement for those quantities used in
air and ground operations. It is nevertheless necessary to retain for
the foreseeable future the use of some commonly used non-SI units [in
parallel with SI units], such as the foot [in parallel with the metre]
for the measurement of altitude.
www.icao.int/icao/en/pub/memo.htm
Over a long period, the problem is being resolved. The trend is
towards metric, not away from it. North American aviation converted
from F to C in 1996. US military airports now give Terminal Area
Forecast visibility in metres. All without a fuss.
Similarly there was no fuss in British and Irish aviation when they
dropped the use of many imperial units. The units used in aviation in
Britain and most most countries are now:
nautical mile = long ranges (navigation)
....spoken as 'mile'
metre, cm, mm = short range
(visibility, runway length, rain, snow)
foot = altitude
knot = horizontal speed
ft/min = vertical speed
hPa = pressure
°C = temperature
kg, metric ton = weight
litre = fuel volume
statute mile, fahrenheit = not used
Why is anyone working in NASA Operations
that does not know aircraft units?
One of the more bizarre features of NASA is that they quote height in
nautical miles.
  #110
Old October 25th 03, 02:51 PM
Alan Minyard
On Fri, 24 Oct 2003 20:51:10 +0200, Andreas Parsch wrote:
Alan Minyard wrote:
Actually, the unit of mass is the gram.
Of course the gram is a unit of mass, but it's not _the_ unit (depends
on the definition of "_the_" ;-) ). All I said is that the kilogram is
used in SI to derive units, and not the gram (as in 1 N = 1 kg m / s^2).
Andreas
I look at it as "a kilogram is 1,000 grams, therefore the underlying "unit"
of mass is the gram". Simply a matter of semantics, and I suppose
that the two definitions are interchangeable. :-)
Al Minyard
Bush's guard record JDKAHN Home Built 13 October 3rd 04 09:38 PM
Space Elevator Big John Home Built 111 July 21st 04 04:31 PM
U.S. Troops, Aircraft a Hit at Moscow Air Show Otis Willie Military Aviation 0 August 28th 03 10:04 PM
