Phrase "landing runway" vs. "cleared to land"
Old January 18th 08, 04:46 AM posted to rec.aviation.piloting,rec.aviation.ifr
Default Phrase "landing runway" vs. "cleared to land"
There are three conditions for descending below MDA or continuing an
approach beyond DA:
1) Runway environment in sight
2) Continuously in position to descend, etc...
3) Have the established flight visibility
On Thu, 17 Jan 2008 09:44:38 -0800, "Al G"
On Wed, 16 Jan 2008 19:41:03 GMT, "Jim Carter"
No, several planes did land.
-Robert
I think you're confusing with practicality with legality. OVC represents
an
overcast which represents a ceiling. 001 OVC is 100' ceiling which is less
than any of the published minimums. 1/8 SM represents a visibility and on
the ground that is less than RVR 2400 or any of the other published
minimums.
Planes landing have nothing to do with legality if someone breaks
something
here. Your original question was why the controller used "landing runway
22"
instead of "cleared to land".
You are correct that as a Part 91 flight you can begin the approach even
if
it is reported Zero-Zero, and you are allowed to land if you have the
runway
environment in site when you reach the decision point on the approach.
You must also have the prescribed flight visibility
Nope, just the runway environment.
Al G
  #102
Old January 18th 08, 04:48 AM posted to rec.aviation.piloting,rec.aviation.ifr
Approach lights are part of runway environment...
On Thu, 17 Jan 2008 11:39:46 -0800 (PST), "Robert M. Gary"
On Jan 17, 11:28 am, "Al G" wrote:
"Barry" wrote in message
if
runway
FAR 91.175 is pretty clear that the prescribed flight visibility is
required to land:
(d) Landing. No pilot operating an aircraft, except a military aircraft of
the United States, may land that aircraft when--
(1) [refers to use of enhanced vision systems]; or
(2) For all other part 91 operations and parts 121, 125, 129, and 135
operations, the flight visibility is less than the visibility prescribed
in the standard instrument approach procedure being used.
Also, as I've already posted, 91.175(c) prohibits even continuing below DH
unless you have the prescribed visibility.
My apologies, I thought you were talking about the Prevailing
Visibility, as reported by the tower. The flight visibility, is determined
by the pilot. The tower can be calling it 1/8 mile, RVR 600', but if I can
see the environment from the DH, I have demonstrated 1/2 mile flight vis.
But there is no requirement you see the environment from the DH, only
the approach lights.
-Robert, CFII
  #103
Old January 18th 08, 04:51 AM posted to rec.aviation.piloting,rec.aviation.ifr,rec.aviation.student
90-100 on the approach, when landing decision is made, pull the power
and glide to the runway.
In a Cherokee you'll be at touchdown speed at the Fixed Distance
Marker, or damn near to it, with one notch of flaps.
On Thu, 17 Jan 2008 11:14:57 -0800 (PST), "
On Jan 17, 1:59 pm, "Barry" wrote:
Applying full flaps when the runway is in sight seems to introduce
overly complex reactions at the most critical phase of flight (low and
slow).
I think it's more important to stay stabilized on the approach while still in
the clouds and on instruments - I don't want to change speed or configuration
until I'm visual. Then the choices a
90 KIAS with approach flaps is nice and stable.
1) Full flaps at 1.3 Vs, stabilized all the way to the flare as a large
airplane would - but that would mean 65 knots or so in a Cherokee
2) Full flaps at 90 or 100 knots - which would require a lot of power and be
much different from all other phase of flight
3) No (or partial) flaps at 90 or 100 knots - my preference.
Barry
90-100 knots to land? In a Cherokee?
The NTSB reports are rife with airplanes wrecked after skidding off
runways after touching down too fast (and there are probably 2x as
many wrecked that the NTSB doesn't hear about).
Landing too fast results in all sorts of bad endings.
1.3 x Vs1 fpr landing works every time, all the time. Add whatever for
gusts and you don't have to change techniques, IFR or VFR.
Dan
  #104
Old January 18th 08, 04:56 AM posted to rec.aviation.piloting,rec.aviation.ifr
Steven P. McNicoll
"Judah" wrote in message
You mean controllers never forget?
No, I mean what I write.
  #105
Old January 18th 08, 05:25 AM posted to rec.aviation.piloting,rec.aviation.ifr
In rec.aviation.piloting Judah wrote:
"Steven P. McNicoll" wrote in news:13osru9nohbb0b0
@corp.supernews.com:
It doesn't work that way.
Of course not, all controllers are superhuman beings that never forget,
never get distracted, never make a mistake, never cough, sneeze, or
blink, never have a bad day, always get enough sleep, never get ****ed
at the boss, and don't catch a cold or any other disease that plagues
mere mortals.
If there was a procedural "error", the controller was poorly trained.
QED.
Jim Pennino
Remove .spam.sux to reply.
  #107
Old January 18th 08, 01:26 PM posted to rec.aviation.piloting, rec.aviation.ifr, rec.aviation.student
On Jan 17, 9:15 pm, "Robert M. Gary" wrote:
I only teach in Monneys but I'm not sure why you would need to be
faster without flaps. Even if I used flaps I wouldn't change the speed
on the approach. Are you flying ILSs in a 172 at 50 knots such that
you need flaps?
Nope --100-90 KIAS in an A36, 90 KIAS in a 172. Approach flaps set in
the A36 and 10 degrees in 172.
But either way you have full flaps once you go visual so the landings
distance is the same in each technique.
While that may be the case in a particular Mooney or Cherokee or
Skyhawk, this method will not work in a faster (more slippery)
airplane.
Try this next time -- see what happens to the ILS needles when your
student drops full flaps once the runway is in sight.
Once you're visual holding the needles in the middle is trivial
because you are looking at the runway.
Do you ever practice ILS all the way down to touchdown? If not, you
may want to try it -- it's a good confidence boost.
Dan
  #109
Old January 18th 08, 04:28 PM posted to rec.aviation.piloting,rec.aviation.ifr
Marco Leon[_4_]
"Newps" wrote in message
That was wrong on the controllers part.
Wouldn't it be covered under here? Maybe he forgot to specifically say
"runway xx unsafe?"
3-3-2. CLOSED/UNSAFE RUNWAY INFORMATION
If an aircraft requests to takeoff, land, or touch-and-go on a closed or
unsafe runway, inform the pilot the runway is closed or unsafe, and
a. If the pilot persists in his/her request, quote him/her the appropriate
parts of the NOTAM applying to the runway and inform him/her that a
clearance cannot be issued.
b. Then, if the pilot insists and in your opinion the intended operation
would not adversely affect other traffic, inform him/her that the operation
will be at his/her own risk.
PHRASEOLOGYRUNWAY
(runway number) CLOSED/UNSAFE.
If appropriate, (quote NOTAM information),
UNABLE TO ISSUE DEPARTURE/LANDING/TOUCHAND-GO CLEARANCE.
DEPARTURE/LANDING/TOUCH-AND-GO WILL BE AT YOUR OWN RISK
Phrase "landing runway" vs. "cleared to land" Robert M. Gary Piloting 168 February 5th 08 05:32 PM
"First Ospreys Land In Iraq; One Arrives After 2 Setbacks" Mike[_7_] Naval Aviation 50 November 30th 07 05:25 AM
Old polish aircraft TS-8 "Bies" ("Bogy") - for sale >pk Aviation Marketplace 0 October 16th 06 07:48 AM
"Airplane Drivers" and "Self Centered Idiots" Skylune Piloting 28 October 16th 06 05:40 AM
