Why is Stealth So Important?
Old January 9th 04, 03:50 PM
James Dandy
Default Why is Stealth So Important?
Seems to me like all the modern wars I can remember up from Vietnam
use mostly ordinary fighters and bombers.
I don't understand why such emphasis is put on that stealth stuff when
we use the same old planes from previously.
I still remember when the F-14 and F-15 came out. Don't we still use
these? Aren't they better than everyone else's stuff?
My son Billy tells me I'm out of date on such matters and that the old
Reds have stuff that is better than ours. Tell me it ain't so. I saw
on tv one night a show on the History Channel that showed a new plane
that did amazing flying but I can't recall its name. It was a Red
plane tho.
I don't have much interest in stealth so long as we keep pounding them
Arabs with B-52 bombs! God bless the almighty B-52.
Since I'm out of date maybe you guys can fill me in on the latest.
What makes a stealth aircraft better? If they are so good how come we
don't own many? What if they were all destroyed, wouldn't we still be
able to fight with the proven stuff?
Many thanks,
James Dandy
Old January 9th 04, 05:42 PM
Ed Rasimus
On 9 Jan 2004 07:50:56 -0800, (James Dandy)
In 1966, while I was flying the F-105 over N. Vietnam, we lost one
every 65 missions. In 1991, during Desert Storm we lost one fixed wing
aircraft every 3500 mission. In 2003 in Iraqi Freedom we lost one
fixed wing aircraft in 16,500 mission.
So, we're going to send you into aerial combat, how do you want your
odds of survival?
Are you still driving the car you bought in 1970? Are new cars better?
plane tho.
Everyone has been developing not only aircraft, but avionics and
weapons as well. Flying 30 year old stuff isn't a good way to make it
to retirement.
Stealth aircraft are more survivable. We don't have many, because the
military competes for $$$ against the welfare princesses and
redistribution of wealth candidates who run for election on a platform
of taking from "them" and giving to the masses. If they were all
destroyed, we'd be in deep kimchi. They are the "proven stuff."
Many thanks,
James Dandy
Ed Rasimus
Fighter Pilot (USAF-Ret)
"When Thunder Rolled"
Smithsonian Institution Press
ISBN #1-58834-103-8
Old January 9th 04, 06:19 PM
Ed Rasimus
On Fri, 9 Jan 2004 09:50:55 -0800, "Tarver Engineering"
I think we can pretty well know the iris on the J-75 was taking out 1% of
the F-105s.
Are you referring to the turbine Christmas tree? Failures of the
Christmas tree which held the three stages of turbine blades caused a
number of unexplained losses. I mention the bailout of Joe Vojir on
takeoff at Korat as well as the loss of Buzz Bullock and Dain Milliman
in takeoff accidents caused by turbine failure in When Thunder Rolled.
The AB nozzle (iris) didn't cause any accidents that I know about.
And, the nozzle is not synonymous with the speed brake petals or
pizzas (which were removed in '65).
When Ed posted here that the F-105's brakes could not hold the
airplane in AB, I could see that iris stuck open/closed/half way between.
No afterburner equipped aircraft that I know about can be held by
wheel brakes in AB. Carrier aircraft get into AB for launch by
employing a "hold back". The F-4, for example, couldn't be held in
military power by the wheel brakes. Engines were checked at 100% one
at a time. Takeoffs were done with a runup to 85% prior to brake
release, then to mil and finally to AB.
Ed Rasimus
ISBN #1-58834-103-8
Old January 9th 04, 06:23 PM
Tarver Engineering
"Ed Rasimus" wrote in message
the F-105s.
I am refering to the AB nozzle, the iris at the back. It was a high failure
rate item, if stuck open offered the operator power in AB settings only, if
stuck in between, only lead sled power settings were available.
The AB nozzle was a sticky part of the J-75.
I don't believe the F-4 had the nozzle problems associated with the J-75 AB.
Old January 10th 04, 06:02 AM
Scott Ferrin
On Fri, 09 Jan 2004 18:19:16 GMT, Ed Rasimus
the F-105s.
wheel brakes in AB.
I remember reading somewhere that an F-111 could do it. (Not the Fs
though)
Old January 10th 04, 05:38 PM
fudog50
Yes, in addition to a 60,000 (?) lb rated holdback chain.
the F-105s.
Ed Rasimus
ISBN #1-58834-103-8
Old January 10th 04, 07:42 PM
Tarver Engineering
"fudog50" wrote in message
The F-105 had to be chained down for trim.
of
the F-105s.
between.
Ed Rasimus
ISBN #1-58834-103-8
Old January 9th 04, 08:15 PM
Denyav
One of the many "wrong" lessons learned in Vietnam,the ideas of Boyd&Co and
Stealth proponents are only two of them.
Vietnam was a proxy war,NV had full support of the other superpower and
China,whereas IRaq was a completely isolated third world country.Moreover,2003
Iraq Freedom operation started after 10 years of intense "preperations" and
further weakening Iraqi defences ,even if US used B-17s during Iraqi Freedom
(DSII),we probably would not lose even one of them either.
Only one conflict in last half century is comparable to Vietnam and its Yom
Kippur war .
FYI during first two weeks of Yom Kippur War Arab armies launched well over
7000 SAMs aganist Israeli aircraft.
Do you know how many SAMs launched aganist US aircraft during DSI and DSII?
Even aganist a small and weak country with improvisation skills,like Serbia,the
performance of Air Force was moderate at the best as a quote from Gen.Jumper
explains "Missions over Serbia on day 78 were as dangerous as they were one day
1"
Your next opponent might be Taliban,Iraq,Zimbabve,Ruanda,Backwardistan etc but
there is no guarantee for that.
Stealth homebuilt C J Campbell Home Built 1 September 15th 04 08:43 AM
SURVEY on manuals - most important for builders, but never good?? T-Online Home Built 0 January 23rd 04 04:37 PM
F-32 vs F-35 The Raven Military Aviation 60 January 17th 04 08:36 PM
How long until current 'stealth' techniques are compromised? muskau Military Aviation 38 January 5th 04 04:27 AM
Israeli Stealth??? Kenneth Williams Military Aviation 92 October 22nd 03 04:28 PM
