Mechanics of Elevator Trim. In Detail.
Old June 16th 08, 05:27 PM posted to rec.aviation.student,rec.aviation.piloting
Default Mechanics of Elevator Trim. In Detail.
On Jun 15, 9:42 pm, Le Chaud Lapin wrote:
On Jun 15, 3:30 pm, wrote:
On Jun 9, 12:36 pm, Le Chaud Lapin wrote:
On Jun 9, 1:19 pm, Gig 601Xl Builder
You never learned of trim until MSFS and you are going to design an
airplane. Fabulous!
Is it really necessary to understand the particular way it was done in
C172 to achieve the same result?
The same thing could be achieved using more electronics, less
mechanics, and the controls might be entirely different.
#1. Learn to fly first.
#2. Study the construction of aircraft, best done by taking an
aircraft maintenance course.
I think the difference here is that I am not looking for something
evolutionary. I think that is a dead-end road. There is so much in
the world to learn, that if a researcher were to take this approach to
every attempt to advance a field, breakthroughs would hardly occur. In
fact, I think it is precisely this mentality that makes the current
process not as fruitful as it could be.
Perhaps the epitome of this type of thinking can be seen on the first
page of this site: http://www.roadabletimes.com/
Question: "How does one make a flying car?"
Answer: "One could start by taking a car and putting wings on it."
This is silly, and it is obvious to everyone now that it is silly, but
to at least one individual, it was not. That man spent countless
hours purusing a dream that would never materialize because his
approach was fundamentally flawed.
Now if one were to take the objectives of CAFE/PAV to make a new type
of vehicle:
http://www.cafefoundation.org/v2/pav_home.php
..and begin by starting with a "reference" design, that person might
share the same fate of he who made the "flying car" of the first link.
Some of you think it is foolish to embark upon a research path without
having a thorough understanding of what has been done. I think not. I
think, in many cases, one can be too familiar with what has been
done. Common knowledge does not necessarily liberate the mind. It
might stifle it. And if it seems arrogant not to follow the path
already tread by great designers, I think it would be even more
arrogant, after having studied what the great designers have done, to
think that one would make extraordinary advancements beyond what those
greats have done, within the same path.
True breakthroughs often require a breach of continuity, and
significant technological advancement occurs when those breaches occur
at semi-regular intervals.
A good example is vacuum tubes versus transistors.
Absolutely zero knowledge of vacuum tubes is required to understand
transistors. There is a bit of ancillary knowledge, like
thermodynamics, band-theory, and electrodynamics that is immediately
transferrable from vacuum tube theory to transitor theory, but
knowlege of vacuum tubes themselves is inessential.
But both act as amplifiers. Both essentially accomplish the same
thing as elements in a larger system.
Now imagine, toward the end of the vacuum tube era, that someone had
proposed to make a new type of amplifier that would be better on
almost every imaginable axes, but that person had no intention of
spending any time studying vacuum tubes. Would it have been necessary
to study vacuum tubes?
This is essentially what you are saying about PAV's. You are saying
that, the best way to proceed is to learn all I can about convential
aircraft. Why is that necessary? It presumes that the method by which
the objective is accomplish is similar to what has already been done
(tractor model, for example).
A better approach might be to make no assumptions at all, but focus on
the end result, then work backward, evaluating extant technologies
(applicable in, say, 2010), keeping a respectible distance from the
prevaling models of aicraft design, just as transitor theorist might
deliberately keep a respectable distance from vacuum tubes.
#3. THEN think about designing an airplane. No worthwhile design that
I'm aware of has ever been put forward by someone who was unfamiliar
with the way things are now and why they are that way, but I have seen
designs built by folks who "knew better" than everyone else. One of
those, built by a local guy who would take no constructive criticism
of his ideas, stalled at circuit altitude and dropped him, hard, on
the surface of the earth. He was such a stubborn guy that he got up
and walked away, but he neither built nor flew any more airplanes.
Needless to say, this design was neither inspected nor approved nor
licensed to any standard whatever.
A good way to win is avoid races where number of entrants is 1. It
would be extremely hard for someone in my opinion to make notable
improvement on existing aircraft design. The world is filled with high
skilled, highly trained, thoroughly experience, professional aircraft
designers who spent their lifetimes aiming for that extra 5%.
Extra 5% is not going to make a PAV, so if there is any chance of
succeeding at all, one should avoid paths where best-case scenario is
a 5% improvement.
Adding electronic controls to something like a trim tab on a
lightplane is one of those "better" ideas that has no basis in
reality. It adds complexity, which adds failure points and cost and
weight, none of which are welcome.
I hear a lot of mechanics say this about cars. I think there should
be a qualification made thos these types of statments:
"It adds complexity, which adds failure points and cost and weight,
none of which are welcome, unless the person integrating the
electronics is an electrical engineer unperturbed by the idea of
adding electronic controls to a mechanical system."
It is no more accurate than manual
trim.
Perhaps not. But a computer will outperform a human 10x to 1x if the
goal is to optimize fuel consumption with automatic trim control.
There is literally countless scenarios where combination of software/
electronics would far exceed capabilities of a pilot to achieve same
objective.
As aviation advances, there will be much more employment of
electronics and software.
I am simply saying, whatever will exist 50 years from now (when many
of us will be dead, heheh)...whatever that thing is...start thinking
about *that* now, not something that was designed in 1950.
-Le Chaud Lapin-
The guys who invented the transistor (Brattain and all)
understood electricity and were engineers who could design and build
electronic devices. That's the equivalent of knowing how to fly and
how to build aircraft. They were not new to electronics, they didn't
stumble across semiconductors by accident. Solid-state selenium diodes
(not to mention crystal diodes) had already been in use by then for
some time, and so they built on the knowledge of other folks.
Numerous flying cars have been built from scratch, not based
on existing automobiles. It's not something new. Molt Taylor's Aerocar
(late '40s or early '50s; Google it) was certified and produced in
small numbers, but the compromises necessary to achieve flight in a
vehicle that also has to fit on the road and operate in traffic mean
it's a poor car and a poor airplane, and didn't sell well enough to
justify continuing with it. Electronics and computers can't fix the
hard limitations of physics. Over the years I've been around aviation
I can't recall how many attempts have been made in my own time to
build such a machine, and none of them are visible today. It seems
that only the naive attempt it, and find out the hard way about
compromises that ruin the whole idea.
But don't let me discourage you. Maybe some other folks will
be spared the grief just be watching you try it.
Dan
  #102
Old June 16th 08, 05:42 PM posted to rec.aviation.student,rec.aviation.piloting
be a qualification made thos these types of statments...
A good example of an "improved" system in lightplanes was the
electric flaps in 150s and 172s. The old system involved a lever and
some cables. The lever was pulled up to 10, 20, 30 or 40 degrees, so
the lever was the flap position indicator and the cables were the only
other weight involved. The effort to pull the lever up was a point of
complaint with some feeble pilots.
The electric flap system has a gearmotor driving a jackscrew,
microswitches on the jackscrew nut sleeve to limit its travel, a DPDT
momentary switch on the panel, a special wirewound potentiometer in
the wing to follow the bellcrank to drive a flap position indicator on
the panel, and cables and pulleys from the right wing (where the motor
is) to the left wing to drive the left flap.
So now we have the same cables and pulleys (although a little less
of them), a switch that fails regularly (the springs that center it
break), and cable bundle whose connectors at the wing roots and flap
motor assemble get wet and corrode), microswitches that get oil in
them off the jackscrew threads (meaning that sometimes the flaps won't
come down, or worse, that they won't retract on a go-around), a five-
pound motor and jackscrew (which lowers useful load), a special
potentiometer that wears out and costs more than $500 from Cessna and
isn't available anywhere else (bought one a few years ago), a flap
position indicator that costs $475 (bought one last year), and the
loss of the option of raising the flaps right at touchdown to get max
weight on the wheels for braking on short strips, which annoyed no end
a lot of the bush guys who relied on that feature. At least Cessna
left things alone in the 180 and 185, airplane flown by real pilots
who didn't mind pulling a lever.
You can decide if this was an "improvement." Lots of owners who
have had to have this system fixed don't think so.
Dan
  #103
Old June 16th 08, 06:55 PM posted to rec.aviation.student,rec.aviation.piloting
Le Chaud Lapin
On Jun 16, 10:08*am, "Ken S. Tucker" wrote:
On Jun 15, 9:16 pm, Le Chaud Lapin wrote:
On Jun 15, 6:34 pm, "Ken S. Tucker" wrote:
I concur with Dan on his last two posts, yeah that's
rare, but anyway...
I designed and tested (models) of a fantastic plane,
but when I chose between putting my wife and kids
in my fantastic plane or into a proven (safe) C172,
I chose the C172.
Here's why: If my machine cracked up due to a fault
in my design, and killed my family except for me, I'd
feel obligated to shoot myself, though I wouldn't.
That said, build your machine, put it threw it's paces
then take on a passenger, who knows what the tag
"EXPERMENTAL" means on the side of the A/C,
and have fun.
Ken-
Perhaps there will not be time in my life to see a design realized,
but if I were so fortunate, I would probably do just that...get in it
myself first.
But before doing that, I would let it fly itself over a desert, since
controls would be software anyway.
That sounds like a good idea.
A 1/4 scale is good, it can be powered by a cheap
chainsaw motor.
Do you have any general ideas for a lay-out yet?
-Le Chaud Lapin-
If you lived close by, I'd give you some help.
I live in Austin, Texas.
Some locals and I have been toying around with the idea of renting a
garage for experiments, though I think that is premature. I would
rather use something like SolidWorks to create a model to verify that
the aircraft would fly first. I do have a vague vision of the form-
factor of the aircraft, but as I see it, there are two crucial things
that need to be determined before putting both feet in the water:
1. The PAV I envision relies on an unproven, unorthodox hypothesis of
the origin of lift. I say concept because there is no weird science
involved like anti-gravity machines or anything like that, but if it
were to fly, it would require a reaxmination of the prevailing
theories. This is the hardest part, and I have been concentrating
only on the lift elements. A lot of math and a prototype of certain
control surfaces would help.
2. The second problem is a problem that would be faced by any designer
of a PAV, and that is the power source. The PAV I envision would have
an extremely high reliance on electrial power (the lift engine itself
would rely on electrical power), and this is a hard problem.
Conventional fuels, in 2008, still appear to be the most pratical
approach, even if the fuel is only used to operate a generator.
As far as the engine, I cannot say what it is yet, but can say that it
doesn't use an ICE.
-Le Chaud Lapin-
  #104
Old June 16th 08, 07:10 PM posted to rec.aviation.student,rec.aviation.piloting
Le Chaud Lapin
On Jun 16, 11:27*am, wrote:
* * * * * The guys who invented the transistor (Brattain and all)
There are certain pieces of knowledge that are applicable and certain
pieces that are that. That's all I am saying. I know people who
studied aero/astro for years and had never designed and airplane, but
could if they had to. With regard to transistors, I have only been a
a clean room, and I have never operated say, a chemical-vapor
deposition (CVD) machine, but I know how it works.
The question is essentially:
"What knowledge of old is useful to create the new?"
A key word in this question is "new", which could be interpreted as
"new new" or "incrementally new". Incrementally new is best served by
examining state-of-art and making incremental improvement. New new is
best served by rethinking from a more fundamental perspective. I
contend that, in any field, there is a large percentage of researchers
who do not bother thinking about "new new", because they regard it as
a fruitless endeavor or too risky. But sooner or later, "new new"
reveals itself, and the cylce repeats.
* * * * * Numerous flying cars have been built from scratch, not based
I have link on my ready-access favorites of web browser:
so yes I have seen it, and many others. Not to criticize this design,
but there is no way I would ever make a flying car that looks like
that. Each time I see someone who has passion for making flying car
take car and mount airplane on top of it, I feel sorry for them - so
much passion...
I have noticed that a lot of people making flying cars have an
incredible urge to "just get something working", with the expectation
that , if it "works", it can be improved with tweaks over time. This
is a dangerous approach. As you noted, one typically ends up with
something of questionable design that enjoys, at best, a lukewarm
reception.
* * * * *But don't let me discourage you. Maybe some other folks will
Heheh.
-Le Chaud Lapin-
  #105
Old June 16th 08, 07:33 PM posted to rec.aviation.student,rec.aviation.piloting
Le Chaud Lapin
* * * * *Adding electronic controls to something like a trim tab on a
I hear a lot of mechanics say this about cars. *I think there should
* * * A good example of an "improved" system in lightplanes was the
* * * The electric flap system has a gearmotor driving a jackscrew,
* * So now we have the same cables and pulleys (although a little less
* * * You can decide if this was an "improvement." Lots of owners who
This is an excellent anecdote. It illustrates something I tried to
point out in another post a few months ago:
No potentiometer should cost $500.
If it is used to make sure the Queen of England does not slip and fall
while walking down a steep flight of stairs, it should still not cost
$500.
This same phenomenon is present today. I have a bunch of aviataion
related newspapers and magazines that I read see parts and what they
cost. I look especially at electronics parts. The prices are
outrageous. Whatever the excuses - regulation, low-volume - these
prices are simply ridiculous. In many cases, the exact same product
is sold in a different consumer context for a 40% mark-up.
There is rigidity of innovation in the entire aviation industry. Much
of the technology really is 50 years old. New technology is
integrated in patchwork fashion at a sloth's pace. There are many
places where metal is used but plastic would be just as good, but
plastic cannot be used because the designer insists on adding plastic
incrementally.
Much of the new technology's benefit is only realized when gross re-
examination of the design of the system is permitted. Otherwise one
ends up with a $200,000 aircraft with a 90% cost-reduction on a part
that originally cost $400, making new cost $199,960. What good is
that?
This is why I see opportunity. Electrical, and especially software
engineers, have great opportunity to eliminate mechanized control in
aviation (and many other industries for that matter). But as implied
by your anecdote, it should not be done as an afterthought, after
months of haggling where the engineering department finally decides to
"integrate" more electronics, with foot-dragging, coporate in-
fighting, special hiring of disposable engineers skilled in
electronics to contribute to a system that is fundamentally regarded
by the old guard as mechanical...it should be done in context where
the engineering team is _fundamentally_ predisposed to employ software
and electronics at low-cost throughout.
I thought http://www.terrafugia.com was a team, filled with bunch of
MIT grads, that might take this approach, but they themselves stated
in one article that they would refrain from going after the Big-Kill,
meaning pervasive software systems throughout. I think this is
unfortunate.
-Le Chaud Lapin-
  #106
Old June 16th 08, 10:47 PM posted to rec.aviation.student,rec.aviation.piloting
Regulation, and the risk of liability, makes all aircraft stuff
expensive. That's not the manufacturer's or designer's fault; that's
OUR fault, those of us who choose to rent or buy airplanes and proceed
to do stupid things with them and get ourselves killed or maimed,
whereupon the manufacturer is sued for many millions because his
product was "defective." Defective because it could not protect me
from my own stupidity. And juries swallow this.
Besides that, the low production numbers make these things more
expensive.
As far as a different lift process, man has been using what Nature
perfected a long time ago: the airfoils as used by birds, controlled
by tails as used by birds. Flapping-wing technology still hasn't been
figured out but someone will do it soon, although it guarantees a
rough ride.
If you want a different lift system, check out the bumblebee.
There's something related to spanwise vortex lift going on there, and
the guys who have had deep-stall crashes in canards (notably the
Velocity) have had some experience with it. Lots of lift generated at
well below stall speeds with an unexpectedly low sink rate. Sometimes
it's a survivable crash. There's potential there.
Dan
  #107
Old June 17th 08, 03:43 AM posted to rec.aviation.student,rec.aviation.piloting
Michael Ash
In rec.aviation.student Le Chaud Lapin wrote:
On Jun 16, 11:27?am, wrote:
? ? ? ? ? The guys who invented the transistor (Brattain and all)
I'm sure they could design a *bad* airplane. Designing a good one takes
experience, not just theoretical knowledge.
That's miles away from being able to actually invent them from scratch.
I contend that "new new" simply does not exist. *All* advances are
incremental. To the extent that any advance appears to be revolutionary,
it is only because its predecessors are not widely known.
A great example of this is the transistor. To the general public, it looks
like this great sudden flash of innovation. Looking at the actual history
of the field, it was the culmination of years of incremental advances.
If you think I'm wrong, I'd love to see some counterexamples. Especially
if you can give counterexamples which not only were not incremental, but
which were invented by someone who was not already an expert in the field.
Mike Ash
Radio Free Earth
Broadcasting from our climate-controlled studios deep inside the Moon
  #108
Old June 17th 08, 04:51 AM posted to rec.aviation.student,rec.aviation.piloting
Le Chaud Lapin
"new new" or "incrementally new". *Incrementally new is best served by
examining state-of-art and making incremental improvement. *New new is
best served by rethinking from a more fundamental perspective. *I
a fruitless endeavor or too risky. *But sooner or later, "new new"
There is no such thing as quantized progress in technology of course.
Anything that looks like a wheel can be traced back 1000's of years.
"New new" is a relative concept. One must assess how new is is the
new new relative to what others consider to be the state-of-the-art at
the time.
That brings another point. Conception and perfection of the new
cannot be an instantaneous act. Development of the new occurs over
time. So again, newness must be considered within the context of the
state of the art. For example, if a new PAV were created, in 2008,
that satisfied the challenges put forth by CAFE, one could always
claim that its design builds upon the work of others, even though the
general public might regard it as a technological breakthrough:
1. Fully glass cockpit? Not new, the LCD's come from ViewSonic, and
has been done already anyway.
2. Software-controlled autostabilization? Not new. Uses long history
of PID and other control theory. Other aircraft do it.
3. Electric generator? Not new at all, on an airplane, or otherwise.
4. Vertical Take-Off & Landing? Old concept. Other aircraft do it.
5. Side-mounted joystick controls instead of a yoke? Not new. Many
aircraft have them.
6. Elimination of foot-pedals? Done already.
7. New means of lift? (no comment..heheh)
8. Elimination of mechanical controls? Not new.
9. Ultra-quiet? Not new. Other aircraft have been made to be ultra-
quiet.
You get the point. With sufficient argument, everthing new can be seen
as old. Even with transistors, one could argue that sand has been here
since very early days of earth, and to some extent, were conducting
long before scientists discovered semiconduction.
Determining whether something is evolutionary versus revolutionary is
inherently subjective, making the truth thereof vulnerable to the
prejudices of the obvservers. Because we have no omniscient being
willing to serve as impartial judge, another path to objectivity must
be found. Strangely, one of the best places to look is toward those
who have no familiarity at all with the intricacies of the subject.
Then, if the criteria of CAFE for a PAV were satisfied, atomically and
simultaneously, for a total cost of say $50,000, we might not regard
it as a revolutionary step, but the general public would.
So revolutionary design, by definition, has a temporal element. The
designer cannot claim revolution if the features of the new are
disseminated in a diarrhetic mode where the period of presentation is
so long that the observers become bored with progress.
A revolutionary system requires the simultaneous application of many
advanced concepts, across technological disciplines, at once.
Hah..tempting, but as mentioned, no matter what I name, the
contraption could always be regarded as evolutionary.
Nevertheless, the notion that revolutionary ideas exist, even though
they are inextricably evolutionary, still prevails.
Here is an example from NASA:
http://www.nasa.gov/home/hqnews/2005..._concepts.html
-Le Chaud Lapin-
  #109
Old June 17th 08, 06:57 AM posted to rec.aviation.student,rec.aviation.piloting
Ken S. Tucker
rare, but anyway...
I chose the C172.
and have fun.
Ken-
myself first.
chainsaw motor.
-Le Chaud Lapin-
I'm currently near Vernon BC.
Perhaps a rotary wing?
Interesting, electrics have made good advances,
maybe regenerative braking during descent such
as some vehicles use while going down hill.
Solar cells on the top of the wings are proven
practical to keep the batteries up to full charge
while sitting on the ground.
doesn't use an ICE.
Mean, Green and Lean!
Ken
  #110
Old June 18th 08, 03:23 AM posted to rec.aviation.student,rec.aviation.piloting
Le Chaud Lapin
rare, but anyway...
I chose the C172.
and have fun.
Ken-
myself first.
chainsaw motor.
-Le Chaud Lapin-
theories. *This is the hardest part, and I have been concentrating
only on the lift elements. *A lot of math and a prototype of certain
Hah...I realized two nights ago before going to bed that the form of
the airfoils about the aircraft is essentially unlimited. What is
really important is understanding why there is a net upward force on
the airfoil. Once that is understood, the sky is the limit. I have
purposely refrained from imagining all the different forms of airfoils
for the time being. It would only use brain cycles I must research
for tedious problems in number theory at present. But my guess is that
the airfoil forms could range from a bland planar to the ultra-
exotic. And yes, the standard rotary wing might be a component.
Does not hurt, if the weight problem can be eliminated.
doesn't use an ICE.
Green is definitely an objective. Electronics is the way to move
forward.
I was looking at the the Honda Clarity FCX today.
http://en.wikipedia.org/wiki/Honda_FCX_Clarity
Apparently they were able to get the size of fuel cell to that of
chassis of desktop computer.
-Le Chaud Lapin-
F-100 detail Pjmac35 Aviation Photos 0 July 26th 07 10:29 AM
Finding "Neutral" Position on Piper Elevator/Trim Tab [email protected] Owning 10 December 7th 06 01:43 PM
Detail pops in too late in FS2004 CatharticF1 Simulators 0 August 27th 03 03:25 AM
