How much fuel do you prefer to carry?
Old August 8th 08, 08:43 PM posted to rec.aviation.piloting
Mxsmanic
Default How much fuel do you prefer to carry?
When you fly, how much fuel do you prefer to carry? Do you just load enough
to meet the FARs? Do you like to add a fudge factor? If so, how much? Do
you prefer to fly with full tanks irrespective of the length of the flight?
Is it significantly more expensive to fly with the tanks topped off for every
flight on small aircraft, or does it not make much difference?
Old August 8th 08, 09:11 PM posted to rec.aviation.piloting
More_Flaps
On Aug 9, 7:43*am, Mxsmanic wrote:
When you fly, how much fuel do you prefer to carry? *Do you just load enough
to meet the FARs? *Do you like to add a fudge factor? *If so, how much? *Do
Depending on the flight -always 10% for contingencies but often more
on long x-country up to full tanks or MAUW.
Cheers
Old August 8th 08, 09:24 PM posted to rec.aviation.piloting
bdl
As with all things aviation... It depends.
How far am I going? More than I can go there and back (+1 hour)?
Whats the fuel situation there? Is it expensive? Is it even
available? I once did a hunting trip to the bootheel of Missouri to
an old airstrip that had no amenities. Just a runway. No building,
no phone, no fuel especially, not even a windsock. And not much
around. In that case I carried full tanks to make sure I could make
it back.
Whats the weather like? Am I likely to have to do multiple
approaches? Would an extra hour of gas (beyond FAA reqs) give me more
outs?
How much do I need to carry? 6lb/gal can mean the difference between a
230lb person and a 180lb person.
For me and my airplane its usually a matter of having it at "tabs"
which is 34 gallons versus full which is 48 gallons. I seldom go with
less than tabs. But then again don't often go with both tanks full.
The plane will fly more efficiently when it has less weight.
I haven't flown MSX enough in a while. Is weight even a factor in
performance? I know the default W&B's usually have full tanks.
Course with flight simulator you can always add more fuel
inflight. :-)
Brian
N9093K
Old August 8th 08, 10:09 PM posted to rec.aviation.piloting
Mxsmanic
bdl writes:
performance?
(I presume you mean FSX.) Yes, weight is taken into account and has an
obvious effect on behavior and performance. In simulation, fuel costs
nothing, so I usually fly with full tanks on small aircraft. On large
aircraft I fly with several hours' more fuel than I need.
inflight.
That would be cheating. You can also set unlimited fuel, but that's cheating,
too. Still, fuel-exhaustion scenarios aren't that interesting to simulate so
I just load more than enough fuel for every flight.
Old August 9th 08, 03:27 AM posted to rec.aviation.piloting
BT
you don't fly... you operate a computer
"Mxsmanic" wrote in message
bdl writes:
performance?
inflight.
cheating,
so
Old August 9th 08, 12:08 AM posted to rec.aviation.piloting
How far am I going? *More than I can go there and back (+1 hour)?
Whats the fuel situation there? *Is it expensive? *Is it even
available? *I once did a hunting trip to the bootheel of Missouri to
an old airstrip that had no amenities. *Just a runway. *No building,
no phone, no fuel especially, not even a windsock. *And not much
around. *In that case I carried full tanks to make sure I could make
it back.
Whats the weather like? *Am I likely to have to do multiple
approaches? *Would an extra hour of gas (beyond FAA reqs) give me more
outs?
I haven't flown MSX enough in a while. *Is weight even a factor in
performance? *I know the default W&B's usually have full tanks.
inflight. *:-)
Brian
N9093K
In that we are rarely pushing gross weight in an M20J, almost always
with full tanks.We fly away half a tank, switch to the full wing, and
burn most of that. We always land while we are still cruising on that
wing, switching to the initial tank, if it has more fuel, early in the
approach. Since we burn 9 gals an hour or so at cruise, there is lots
of range available. If it's IFR and we don't have a sold gold
alternate with a total fuel burn of 45 gallons or less we are not
going. That's 4 plus hours at 150 knots, more than enough range for
nearly every mission.
Old August 8th 08, 09:37 PM posted to rec.aviation.piloting
Paul kgyy
Since my plane has rubberized bladder tanks, I always fill them before
putting the plane away.
I start looking for a place to refill when I am down to a 1 hour
reserve, though if IFR might be more conservative depending on
conditions.
Old August 8th 08, 10:10 PM posted to rec.aviation.piloting
Mxsmanic
Paul kgyy writes:
How does the type of tank influence this?
Old August 8th 08, 11:00 PM posted to rec.aviation.piloting
Viperdoc[_3_]
The only time you have too much fuel is when the airplane is on fire. The
type of tank is not simulated in MSFS, so you don't have to worry.
Old August 10th 08, 02:08 PM posted to rec.aviation.piloting
Stealth Pilot[_2_]
On Fri, 8 Aug 2008 17:00:50 -0500, "Viperdoc"
The only time you have too much fuel is when the bloody thing is on fire.
the famous quote of Sir Charles Kingsford Smith.
One More Reason I Prefer GA Kyle Boatright Piloting 19 December 27th 06 11:53 PM
Is it a habit we prefer mechnical instruments? [email protected] Home Built 80 April 28th 06 04:05 AM
Does V-22 Go Twices as Far, carry Twice as Much? Nick Lappos Rotorcraft 26 October 12th 05 08:11 PM
Headset wanted - prefer David Clark Marty from Sunny Florida Aviation Marketplace 0 October 5th 04 02:54 PM
things to carry Gary Drescher Piloting 62 July 20th 04 03:08 AM
