Experimentals To Be Banned To Rural Airports?
Old August 29th 08, 12:18 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
T. \Tim\ Timothy Haag aka HyoogeUmp56[_4_]
Default Experimentals To Be Banned To Rural Airports?
http://www.avweb.com/eletter/archives/avflash/1199-full.html#198676
Old August 29th 08, 12:27 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Mxsmanic
By definition, experimental aircraft have unknown characteristics. It makes
sense that you'd want to test them out away from heavily populated areas.
Boeing and other civilian and military manufacturers don't test out their new
designs at LAX.
Old August 29th 08, 12:55 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
designs at LAX.
Uttern nonsense.
You haven't a clue what "experimental" means.
Jim Pennino
Remove .spam.sux to reply.
Old August 29th 08, 01:08 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Bob F.[_2_]
"Mxsmanic" wrote in message
makes
new
designs at LAX.
First an "experimental" aircraft in aviation talk is just another
classification. The characteristics may be well known and just doesn't fit
into any other class.
Secondly, I have personally flown a number of experimental Boeing aircraft
into LAX when I worked for the flight test group there. I believe B747-100
s/n 1 is still classified as experimental. And I flew B401, 2 and 3 (the
first 3 747-400 designated a/c). They too were classified as experimental
and flew into a lot of large airports with heavy population.
Regards, Bob F.
Old August 29th 08, 01:16 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Rich Ahrens[_2_]
on 8/28/2008 7:08 PM Bob F. said the following:
makes
their new
designs at LAX.
fit into any other class.
aircraft into LAX when I worked for the flight test group there. I
believe B747-100 s/n 1 is still classified as experimental. And I flew
B401, 2 and 3 (the first 3 747-400 designated a/c). They too were
classified as experimental and flew into a lot of large airports with
heavy population.
Another epic fail for Anthony...
Old August 29th 08, 06:55 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Mxsmanic
Bob F. writes:
My impression is that many aircraft are called experimental in order to get
around certain troublesome regulations.
How many hours had they flown elsewhere before they visited those large
airports?
Old August 29th 08, 07:15 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Bob F. writes:
And your "impression" is wrong.
It does not mean the airplane is "experimental" in the sense of being
unknown, new, or unproven, nor does it mean that it is home built.
All experimental means is that the manufacturer, whoever that may be,
didn't go through the process to certify the aircraft in one of the
other catagories with the FAA.
The Anatov AN-2 has been made for about 50 years by several former
Soviet block countries, has been used the world over for everything from
transport, military, and airline use, and is probably the most produced
aircraft in history.
Since the Soviet countries had no interest in certifying their aircraft
with the FAA and there were no reciprocal agreements as there are with
some other countries, guess what it is registered as if you buy one and
register it in the US?
Jim Pennino
Old August 29th 08, 08:13 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Bertie the Bunyip[_25_]
Mxsmanic wrote in
Bob F. writes:
doesn't fit into any other class.
to get around certain troublesome regulations.
That's because you're clueless.
Bertie
Old August 29th 08, 10:21 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Bob F.[_2_]
Bob F. writes:
fit
get
And my impression was that you were talking about an aircraft that was
unsafe for flight.
aircraft
B747-100
experimental
airports?
I don't know exactly, in the case I cited, dozens probably. Everett (Payne
Field), North of Boeing field was built for 747 development because
manufacturing and test facilities were too small and there was no place to
expand since the city was built tightly around the airport. Many maiden
flight took place at Boeing Field and nearby Renton (same situation). It
was a matter of conveniences that Everett was used for their latter flights
and as far as I know, there was never a crash in the neighborhood. Early
maiden flight aircraft actually have a very good statistical record.
Regards, Bob F.
Experimentals To Be Banned To Rural Airports? T. \Tim\ Timothy Haag aka HyoogeUmp56[_2_] Piloting 214 September 9th 08 11:02 PM
Experimentals To Be Banned To Rural Airports? T. \Tim\ Timothy Haag aka HyoogeUmp56[_3_] Owning 129 September 9th 08 11:02 PM
2nd cellphone for retrieve/rural areas US chris Soaring 6 May 4th 08 07:47 PM
Red Arrows banned from olympics - British PC strikes again stevehaley Soaring 13 October 5th 07 07:01 PM
Airshows should be banned...Now! Tetherhorne P. Flutterblast Military Aviation 28 June 15th 04 02:43 AM
