#111
Morgans wrote:
"Steve" wrote I believe that if you look at modern diesels currently being produced and sold, you'll find virtually NONE rated at more than 50-60 horsepower that are not turbo-supercharged. And equally few that are strictly mechanically blown (the Detroit Diesel 2-strokes are no longer in production). The VAST majority are, indeed, turbo-supercharged. Not true of some of our school busses that were produced in the past 5 or so years. They make up for the lack of super or turbocharging with more cubic inches. I say AGAIN... what percentage of the market is that? Tiny. And they only TRY to make up with more cubic inches- a DT466E would run rings around them. |
#112
![]() "Steve" wrote I say AGAIN... what percentage of the market is that? Tiny. And they only TRY to make up with more cubic inches- a DT466E would run rings around them. I was not taking issue with the tiny percentage concept. I did take issue with the following, and the NONE I believe that if you look at modern diesels currently being produced and sold, you'll find virtually NONE rated at more than 50-60 horsepower that are not turbo-supercharged. Not a big deal to me, one way or the other. I always found the non turbo buses under powered, compared to their turbo brothers. -- Jim in NC |
#113
![]() mastic wrote: Bryan Martin wrote: Not so. In the Otto cycle, the fuel and air are introduced to the cylinder during the intake stroke. In the Diesel cycle only the air is introduce to the cylinder during the intake stroke, the fuel in injected at the end of the compression stroke. Wrong. Mr Otto invented the four stroke cycle and it is named after him. The fuel or when it's introduced has nothing to do with it, Otto refers to the cycle. SO? He didn't mention fuel in the part you snipped. Diesel is a differant cycle named after Mr. Diesel. |
#114
mastic wrote:
1. Desiel injection timing is differant than on an Otto engine. The fuel is injected during the intake cycle on the Otto engine and the fuel is injected during the ignition cycle on the Desiel. An Otto engine is any four stroke engine, diesel, gasoline, LPG makes no difference. And there is no "ignition" stroke. BTW, it is not ignition, or intake, or combustion "cycle". There is only one cycle in either a four stroke cycle or two stroke cycle engine. What is different is the number of strokes in a cycle. Cycle means repeating operation. A two-stroke cycle engine repeats its operation every two strokes, a four-stroke repeats every four strokes. I believe if we must shorten the terms then four-stroke and two-stroke are better terms, because in both cases we are talking about what happens in one cycle, not in two or four CYCLEs. |
#115
Sport Pilot wrote:
mastic wrote: Bryan Martin wrote: Not so. In the Otto cycle, the fuel and air are introduced to the cylinder during the intake stroke. In the Diesel cycle only the air is introduce to the cylinder during the intake stroke, the fuel in injected at the end of the compression stroke. Wrong. Mr Otto invented the four stroke cycle and it is named after him. The fuel or when it's introduced has nothing to do with it, Otto refers to the cycle. SO? He didn't mention fuel in the part you snipped. Diesel is a differant cycle named after Mr. Diesel. Actually, today's Diesels can operate over several cycle types. Modern high speed Diesels as used in cars are closer to the Otto cycle than they are to Rudolph's cycle. In his original engine the fuel was supposed to be injected at a rate to create a constant combustion temperature or a constant pressure. This really would take a feedback of temperature or pressure during the combustion stroke, and was- and is- extremely hard to do. The slower the speed of the engine, the better current Diesels approach the intended Diesel cycle, as seen on an indicator diagram. The indicator diagram on high rpm Diesel auto engines look a lot like the diagram of an Otto cycle. There are people developing Diesel systems using closed loop pressure sensing to adjust fuel injection rate, but to my knowledge no Diesel car or truck engine using this feature has ever made it to production. Current production Diesels use open loop injection, so it is a hybrid cycle, somewhere between true Otto and true theoretical Diesel. |
#116
![]() mastic wrote: "MJC" wrote: "Andrew P." wrote in message link.net... Wandering aimlessly about the Web, I heard Sport Pilot say: You have most of it right. Some things you have wrong, 1. Desiel injection timing is differant than on an Otto engine. The fuel is injected during the intake cycle on the Otto engine and the fuel is injected during the ignition cycle on the Desiel. On the Desiel the fuel injection cycle starts just before TDC and ends well after TDC. The fuel ignites as soon as it hits the hot air. etc., etc. --- SNIP --- It's Diesel, not "Desiel". -- Andrew P. Well if you're going to get picky, it's "Auto" engine, not "Otto" engine. MJC Picky, picky, picky. It's not an Otto engine as such. Otto is used to refer to the standard four stroke cycle because Otto was good enough to invent the four stroke cycle. So our friend was incorrect when he said: 1. Desiel injection timing is differant than on an Otto engine. The fuel is injected during the intake cycle on the Otto engine and the fuel is injected during the ignition cycle on the Desiel. An Otto engine is any four stroke engine, diesel, gasoline, LPG makes no difference. Completely wrong, the Otto cycle has nothing to do with four stroke engines. Don is right its not four cycle, I used it incorrectly. The Otto and Diesel cycles are actually refering to the thermodynamics chart of temperature pressure and volume, they invented their cycles on paper and books, the engines we use are only close approximations. The two stroke ignition engine uses the Otto cycle as it is has the four phases of intake, compression, power, and exhaust, and the pressure is not constant. The Diesel two stroke is a Diesel cycle because it also includes the same phases and the fuel burns at a fairly constant pressure. |
#117
Here is an animated link showing the differances of the Otto and Diesel
cycles. http://www.ulb.ac.be/sma/testcenter/...osedcycle.html Notice the near instant burning in the example gives very nearly a constant volume, in actual practice some compression is going on at this time. Also during a Diesel cycle it is hard to maintain a constant pressure, it would actually drop off, especially near the end of the down stroke. |
#118
Sport Pilot wrote:
Completely wrong, the Otto cycle has nothing to do with four stroke engines. Don is right its not four cycle, I used it incorrectly. The Otto and Diesel cycles are actually refering to the thermodynamics chart of temperature pressure and volume, they invented their cycles on paper and books, the engines we use are only close approximations. The two stroke ignition engine uses the Otto cycle as it is has the four phases of intake, compression, power, and exhaust, and the pressure is not constant. The Diesel two stroke is a Diesel cycle because it also includes the same phases and the fuel burns at a fairly constant pressure. I guess I'd quibble with the statement that the Otto cycle has nothing to do with four-stroke engines- it was the first successful cycle to incorporate four strokes. yes, there are other four stroke cycles, but the Otto cycle is still by far the most common. There have been several other four-strokes, several two-strokes, at least on six stroke- I suspect several also. New IC engine designs are among the most numerous US patents. Just because something is patentable, of course, does not make it good or successful, and most of these patents were for approaches that offered insufficient advantages. BTW, as I understand the new Miller cycle, I don't consider it a truly new cycle- just a clever mod on the Otto. I don't consider the Otto cycle to require valve openings at closings at the top or bottom dead center, exactly. |
#119
![]() Don Stauffer wrote: Sport Pilot wrote: Completely wrong, the Otto cycle has nothing to do with four stroke engines. Don is right its not four cycle, I used it incorrectly. The Otto and Diesel cycles are actually refering to the thermodynamics chart of temperature pressure and volume, they invented their cycles on paper and books, the engines we use are only close approximations. The two stroke ignition engine uses the Otto cycle as it is has the four phases of intake, compression, power, and exhaust, and the pressure is not constant. The Diesel two stroke is a Diesel cycle because it also includes the same phases and the fuel burns at a fairly constant pressure. I guess I'd quibble with the statement that the Otto cycle has nothing to do with four-stroke engines- it was the first successful cycle to incorporate four strokes. yes, there are other four stroke cycles, but the Otto cycle is still by far the most common. There have been several other four-strokes, several two-strokes, at least on six stroke- I suspect several also. New IC engine designs are among the most numerous US patents. Just because something is patentable, of course, does not make it good or successful, and most of these patents were for approaches that offered insufficient advantages. BTW, as I understand the new Miller cycle, I don't consider it a truly new cycle- just a clever mod on the Otto. I don't consider the Otto cycle to require valve openings at closings at the top or bottom dead center, exactly. The confusion is that Otto invented the first four stroke engine and called it the Otto cycle, not because of thermodynamics but because he put it in a motorcycle. However the thermodynamic cycle can be reproduced with a two stroke engine. Its just that the intake and exhaust cycle's are much shorter. |
#120
Sport Pilot wrote:
Don Stauffer wrote: Sport Pilot wrote: Completely wrong, the Otto cycle has nothing to do with four stroke engines. Don is right its not four cycle, I used it incorrectly. The Otto and Diesel cycles are actually refering to the thermodynamics chart of temperature pressure and volume, they invented their cycles on paper and books, the engines we use are only close approximations. The two stroke ignition engine uses the Otto cycle as it is has the four phases of intake, compression, power, and exhaust, and the pressure is not constant. The Diesel two stroke is a Diesel cycle because it also includes the same phases and the fuel burns at a fairly constant pressure. I guess I'd quibble with the statement that the Otto cycle has nothing to do with four-stroke engines- it was the first successful cycle to incorporate four strokes. yes, there are other four stroke cycles, but the Otto cycle is still by far the most common. There have been several other four-strokes, several two-strokes, at least on six stroke- I suspect several also. New IC engine designs are among the most numerous US patents. Just because something is patentable, of course, does not make it good or successful, and most of these patents were for approaches that offered insufficient advantages. BTW, as I understand the new Miller cycle, I don't consider it a truly new cycle- just a clever mod on the Otto. I don't consider the Otto cycle to require valve openings at closings at the top or bottom dead center, exactly. The confusion is that Otto invented the first four stroke engine and called it the Otto cycle, not because of thermodynamics but because he put it in a motorcycle. However the thermodynamic cycle can be reproduced with a two stroke engine. Its just that the intake and exhaust cycle's are much shorter. I am not sure what you mean by exhaust and intake "cycles". There is one cycle- the actions that the engine goes through before everything repeats. Do you mean the portions of the cycle during which the exhaust and intake take place- they definitely take less crankcase revolution angle. In the Otto cycle it is easy to break it down into four operations, each lasting one stroke. A two-stroke is more complicated, because it still has (existing, contemporary ones, do anyway) four seperate functions of intake, compression, combustion and exhaust, but have to do it in two strokes. |
BSFC vs gas mileage, 2 stroke vs 4 stroke | Jay | Home Built | 10 | August 24th 04 02:26 PM |
Diesel Jodel information..........and .........diesel plane groups | Roland M | Home Built | 1 | January 4th 04 04:04 AM |
Diesel Jodel information..........and .........diesel plane groups | Roland M | General Aviation | 1 | January 4th 04 04:04 AM |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | General Aviation | 2 | September 13th 03 12:44 AM |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | Rotorcraft | 2 | September 13th 03 12:44 AM |
