#111
Neil Gould wrote:
The FARs address minimum fuel levels when you arrive at your destination. If you have less than the required amount when you land, you are in violation. Not true. The FARs state that you have to *plan* the flight so that, if all goes as planned, you have a certain amount of fuel in reserve. Nothing says you actually have to have that amount when you land. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
#112
![]() Roy Smith wrote: In article , Newps wrote: Avoid JPI like the plague. My club has been installing JPI's on most of our planes. It is true that they're over-priced, and have totally inscrutable user interfaces, but this is true of almost all avionics. What in particular makes you not like JPI? Their attitude towards their customers. Customers are a necessary evil to JPI. |
#113
On Sat, 20 Aug 2005 04:00:49 GMT, "Jay Honeck"
wrote: That is possibly the dumbest thing I've ever read in these newsgroups. IMHO, proper fuel management means never even coming *close* to running a tank dry, let alone doing it intentionally. And now you expect us to call you names, too? Readthe other posts here, and you may learn that it is not as simple to judge as you make it. I'm sorry, was I calling someone a name? I thought he was quoting an article? I have read all the posts in this thread with great interest. Nothing said here has come close to explaining how the minimal utility you might get from running a tank dry could possibly overcome the very real danger that the engine might stop. The engine isn't going to stop. It will most likely quit developing power, but other than being quieter, the prop keeps right on spinning. Turn the fuel selector to a tank that still has gas in it and the engine will go right back to developing power. If you are quick it only sounds like a hick up. My statement stands -- it's a dumb idea. I might think differently with a carbureted engine, but this pretty much goes back to the debate of instructors pulling the mixture or throttle on power outs, except this is of a far shorter duration. I've had tanks un port on a "missed" while climbing out. Now that will get your attention. The old Deb doesn't have any baffles in the tanks so any approach want's to be on the fullest main. On cross countries if you don't burn the one side down you are going to be carrying a lot of gas and losing about an hours flying time. I've had one complete engine failure, but it wasn't due to running a tank dry. That too, gets your attention right away. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#114
How about a corroded, iced or otherwise inoperable selector valve?
Valves do fail. I can conceive of a situation in which the selector handle might simply break off. And what's the likelihood of carb ice when power tails off due to fuel starvation? That might interfere with the restart. "RST Engineering" wrote in message ... Jay, you were in the newspaper biz too long to use "always", "never", and words of that finality in your thinking. Would I teach running a tank dry to a student? Most likely not. Would I recommend the procedure be taught on a BFR? Most likely not. Would I run one dry with trees, rocks, or water underneath (say, from Scottsbluff to Sacramento)? Most likely not. Would I run one dry where there are nothing but airports and soybeans underneath? I might. Depends on what I'm trying to accomplish. I think Deakin knew what he was talking about and expected at least a MODICUM of intelligence on the part of his readers. Let's think about why an engine would not restart with one dry. The only reason I can see for this happening is if the fuel flow from the full tank could not get to the engine. Air bubble? Not with any sort of positive pressure. Fuel handle snap off in your hand? Not likely. Give me a failure mechanism that is likely. Jim "Jay Honeck" wrote in message news:iQRNe.266478$x96.133671@attbi_s72... In fact, I would never have guessed that this kind of a hair-brained "fuel management" procedure would merit a serious discussion in these newsgroups. To even contemplate running a tank dry in the air, let alone propose it as a standard -- even beneficial (?!) -- procedure, makes for astonishing reading. |
#115
C'mon George, tell us what you REALLY think of them {;-)
Jim "George Patterson" wrote in message news:9d4Oe.1416$IG2.824@trndny01... Roy Smith wrote: What in particular makes you not like JPI? For me, I avoid them because they're absolute *******s. I will not support them with my money. |
#116
Jay,
Sorry, even Einstein had dumb ideas. This is one of Deakins... Well, while you're certainly entitled to your opinion, it might be prudent to not offer it in such absolute terms in this case. It might be wise to say something like "I wouldn't do it, but if it works for you guys, so be it." Instead, you try to offer pseudo-facts about alleged accidents caused by this. To which, with all due respect, I say: THAT is dumb BS. -- Thomas Borchert (EDDH) |
#117
![]() "Seth Masia" wrote in message ... How about a corroded, You can't correct for lousy maintenance. iced or otherwise inoperable selector valve? Everybody (in the lower 48) who has had an iced valve, raise your hands? None? I thought so. Inoperable? And you departed the airport this way? Hm. Valves do fail. I can conceive of a situation in which the selector handle might simply break off. In which case you've got just about as many options as if you burn it down to a couple of gallons before you do the old switcheroo. Which is why I posted that this is an improper technique over rocks, trees, and water. And what's the likelihood of carb ice when power tails off due to fuel starvation? That might interfere with the restart. With a one to two second "off" time before restart? Not bloody likely. The exhaust stacks remain hot enough that carb heat is still effective. Am I advocating for or against running one dry? Not really. There have been times I have intentionally run one dry. THere are times I wouldn't run one dry for all the tea in China. All I want is a LIKELY scenario for a failed restart with a semifull tank selected. Jim |
#118
"Seth Masia" wrote:
How about a corroded, iced or otherwise inoperable selector valve? If you think valve (or selector handle) failure is a significant risk, then wouldn't it make sense to change tanks as infrequently as possible? And what's the likelihood of carb ice when power tails off due to fuel starvation? That might interfere with the restart. Carb ice isn't going to form in a few seconds. |
#119
Recently, Roy Smith posted:
"Neil Gould" wrote: What FAR says you may not run a tank dry? The FARs address minimum fuel levels when you arrive at your destination. I'm not aware of any such regulation. I suspect you're thinking of: 91.151 Fuel requirements for flight in VFR conditions. [...] But that only talks about how much fuel you have at takeoff, not at landing. You're (all) right; I was thinking of that FAR, and I stretched the point too FAR. ;-) I regularly fly something with two tanks and no "both" position (PA28), and my preference is to arrive at my destination with more than 30 minutes worth of fuel, period. I see no point in pushing those limits any more than seeing how much over gross I can fly. IMO, such points are just useless information. YMMV. I also think landing with 30 minutes of fuel is too little. So, how much is enough? Let's assume we can agree on an hour, which in a 180 HP PA-28 means about 8 gallons. You take off with 48 usable and fly for 5 hours, leaving an estimated 8 gallons left. Which is a more useful configuration to have at this point, an estimated 4 gallons usable remaining in each tank, or an estimated 8 gallons usable in one tank and the other one dry? I would feel more comfortable with 4 in each tank than with a dry tank. I had an interesting thing happen to me in an Archer. During an XC, a facia screw on the fuel selector had worked loose and backed out enough that when I went to switch tanks, it wouldn't go into that position. My choices were the tank I was on, or off. I'm glad the tank I was on wasn't dry, because when the A&P looked it over, it took him around 15 minutes to figure out what was wrong. Needless to say, I wouldn't have figured that out en route before hitting the ground, because I couldn't see the problem from my seated position. Stuff happens. Neil |
#120
"Neil Gould" wrote:
I also think landing with 30 minutes of fuel is too little. So, how much is enough? Let's assume we can agree on an hour, which in a 180 HP PA-28 means about 8 gallons. You take off with 48 usable and fly for 5 hours, leaving an estimated 8 gallons left. Which is a more useful configuration to have at this point, an estimated 4 gallons usable remaining in each tank, or an estimated 8 gallons usable in one tank and the other one dry? I would feel more comfortable with 4 in each tank than with a dry tank. Let's examine that. We're comparing the relative risk of two events. Event 1 is that the fuel selector valve fails when you go to switch to the tank containing the remaining 8 gallons. Event 2 is that your estimate of how much fuel is left in the tank is wrong by 4 gallons (16%). Which is more likely? |
Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 07:04 PM |
Engine running again, the good, bad and ugly | Corky Scott | Home Built | 34 | July 6th 05 05:04 PM |
It's finally running! | Corky Scott | Home Built | 19 | April 29th 05 04:53 PM |
Rotax 503 won't stop running | Tracy | Home Built | 2 | March 28th 04 04:56 PM |
Leaving all engines running at the gate | John | Piloting | 12 | February 5th 04 03:46 AM |
