Why don't voice radio communications use FM?
Old September 2nd 06, 01:40 PM posted to rec.aviation.piloting
Mxsmanic
Default Why don't voice radio communications use FM?
Perhaps this is a naive question, but: Why don't voice radio
communications for aviation use FM radio instead of AM radio? I
realize there's substantial inertia in the installed base of AM
equipment, but surely one could allocate some new frequencies to FM
and use them in parallel for some years to ease the transition.
The reason I ask is that improper and misunderstood radio
communication is a leading cause of accidents, and so it seems that
anything that can make that communication clearer would greatly
improve safety. I can barely understand what I hear on the radio. It
is true that the communication is very standardized, making it easier
to guess what is being said, but the results are pretty unpleasant if
one guesses wrong.
On a related note, it has occurred to me that one could develop
voice-recognition systems that understand the speech of a pilot and
then repronounce what he says in an extremely standard synthetic
voice. This could also improve understanding, especially for
non-Anglophone pilots who speak with heavy accents. The same systems
could clean up the speech so that it is absolutely standard, with no
missing or added words. Of course, the issue here is that the system
would be stuck if it cannot recognize what is being said, or if a
completely non-standard utterance is made by the pilot. A natural
extension of this would be systems that recognize standard phrases in
one language and translate them to another, but that would be even
more dangerous if the system ever failed.
Still another idea is special training systems that listen to a
pilot's speech and transcribe it, and point out any problems with
understandability. Again, this would be most useful for
non-Anglophone pilots, but it would work for anyone. If a machine can
understand a pilot's speech clearly, then a human being should
certainly be able to understand it that much more easily.
Old September 2nd 06, 01:43 PM posted to rec.aviation.piloting
Steven P. McNicoll[_1_]
"Mxsmanic" wrote in message
news
Wouldn't that reduce the available frequencies?
Old September 2nd 06, 05:00 PM posted to rec.aviation.piloting
RST Engineering
Yeah, Steve, it would. But I think we might be able to swap (on a long term
swap basis) the VHF com band for stuff up between 600 and 900 MHz. that have
very limited usage. Not only could we get way more bandwidth, but the
antenna size is cut by a factor of 6 or so.
nk.net...
news
Old September 2nd 06, 06:42 PM posted to rec.aviation.piloting
Mxsmanic
Steven P. McNicoll writes:
For a given audio bandwidth, FM tends to require somewhat more radio
bandwidth, as I recall, but the audio bandwidth of aviation radio is
already so limited that I don't think this would be an issue. The
gain in clarity would outweigh any loss of audio fidelity, assuming
that the same channel widths were used.
If frequencies were reallocated (instead of allocating new ones), that
would be different. That would also obsolete older equipment much
more quickly, which might not be acceptable. But there must be some
space somewhere that could be added to the frequencies, or perhaps
some band so rarely used that it could be reassigned.
Old September 2nd 06, 06:54 PM posted to rec.aviation.piloting
RST Engineering
You recall incorrectly.
Old September 2nd 06, 07:15 PM posted to rec.aviation.piloting
Mxsmanic
RST Engineering writes:
Perhaps. Theoretically it should require exactly the same bandwidth,
but I seem to recall reading that typical implementations used more
bandwidth. In any case, you don't need much for voice communication.
The advantage of FM would be the reduction of noise. Digital over FM
would be still better.
Old September 2nd 06, 02:12 PM posted to rec.aviation.piloting
Peter R.
A leading cause of accidents? Where did you get this statistic?
one guesses wrong.
Guess? If a pilot or controller is not able to comprehend the other side's
transmission, there is no guess. "Say again?" is the phrase of choice and
it is used all over the frequencies.
Peter
Old September 2nd 06, 06:45 PM posted to rec.aviation.piloting
Mxsmanic
Peter R. writes:
From the NTSB and several books on the subject.
It's routine in linguistics to unconsciously guess. A person
listening to familiar sounds in a familiar context will "fill in the
blanks" for any sounds that cannot be unambiguously distinguished, and
he will do this without thinking. If he guesses wrong, trouble can
result, and accidents have happened in aviation for this reason (the
most famous probably being the one at Tenerife).
Old September 2nd 06, 07:46 PM posted to rec.aviation.piloting
Peter R.
Have a name of one of these books that claims that aviation communication
is the leading cause of aviation accidents?
You imply that this is a very common occurrence. Sorry, but I am unable to
accept your premise without some evidence to back up this claim.
My understanding of the accident at Tenerife is that it had more to do with
a fateful heterodyne and a captain who was asserting his own way, rather
than misunderstood communications.
Peter
Old September 2nd 06, 08:17 PM posted to rec.aviation.piloting
Mxsmanic
Peter R. writes:
Some of the words on the cockpit recording are impossible to
understand even today. That's pretty strong evidence that
misunderstood communications had an important role in this accident.
In fact, there are several instances of misunderstood radio
communication involved.
I Hate Radios Ron Wanttaja Home Built 9 June 6th 05 05:39 PM
AirCraft Radio Communications [email protected] Rotorcraft 0 November 13th 03 12:48 AM
